Bud can muffler's    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Bud can muffler's
Page: [1]
Login
Bud can muffler's - 11/29/2012 5:15 AM
Ernie Misner
Score: 130
Last Login: 5/17/2013
Status: offline
Does anyone know if the Bud beer cans are still being sold that make great tuned mufflers? I'm wanting to try a BCM (bud can muffler) on my DLE 20cc. I sure can't find that bud can in the store .... ? Any reason why a mousse can or bud can won't work on a gasser like it works on glow engines?
Thanks - Ernie Misner
Hide Signatures
       Post #: 1
RE: Bud can muffler's - 11/29/2012 2:24 PM
ThumbSkull
Score: 108
Last Login: 5/18/2013
Status: offline
They were born over at the ProBro site. Do a search for DLE20 BCM or DLE20 ccp
The bud can may be slightly large for 20cc so the coke can 8.5 oz may be better.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 2
RE: Bud can muffler's - 11/30/2012 12:25 AM
Ernie Misner
Score: 130
Status: offline
Thanks Mike. Has anyone seen either of these cans in the store lately? Hopefully there'll be some around the holidays...
BTW, BCM = Bud can muffler / CCP = coke can pipe (just terms that are used like MCP = mousse can pipe) Mousse cans started the whole thing years ago. These are all used in conjunction with a Mac's header.
These give results similar to a tuned pipe setup but with a wide torque and rpm range. More power and rpms but not "pipey", good for 3D and aerobatics.
Hide Signatures
(in reply to ThumbSkull)
       Post #: 3
RE: Bud can muffler's - 12/3/2012 11:00 PM
Ernie Misner
Score: 130
Status: offline
Still looking for aluminum Coke cans, 8 oz. Anyone seeing them in the stores?
Hide Signatures
       Post #: 4
RE: Bud can muffler's - 12/4/2012 4:35 PM
wyo69cowboy
Score: 105
Status: offline
The 8.5oz Coke cans show up from time to time at convenience stores and grocery stores/Walmart, but I haven't seen any since summer around here...there's a couple guys on the ProBro site who usually have a supply and are willing to ship the empties
_____________________________
Crashing my way to being a better pilot!
Saito Club# 679
Hide Signatures
       Post #: 5
RE: Bud can muffler's - 12/4/2012 6:01 PM
Ernie Misner
Score: 130
Status: offline
Okay, actually got somewhere by calling Coke USA. (1 800 438 2653) They were able to tell me that there's only one Walgreen's store in my area that carries them. So if you can't find 'em give them a call.
Mine will be going on an OS 55AX with a mac's header. So will be looking for good info on how to mate it to the header, how to mount it to the fuselage, etc. Oh and header length....
Thanks, Ernie
Hide Signatures
(in reply to wyo69cowboy)
       Post #: 6
RE: Bud can muffler's - 12/4/2012 7:49 PM
wyo69cowboy
Score: 105
Status: offline
Here's thread for ya: http://www.****/forum/viewtopic.php?f=18&t=30111
Of COURSE this ninny site won't let me post a link to another forum Go to the P R O B R O site, and search for the thread on DLE 20 CCP testing...
Saito Club# 679
Hide Signatures
       Post #: 7
RE: Bud can muffler's - 12/7/2012 6:23 AM
John Wells
Score: 100
Last Login: 2/17/2013
Status: offline
quote:
ORIGINAL: Ernie Misner
Thanks, Ernie
Hi Ernie, here's the info that I got from Dave McDonald and it works great on my 55's;
1) The total header tube length needs to be 9" long.
2) Drill a 15/64" hole in the can cap for the exhaust outlet, then screw it back on the bottle.
3) Use an OS type F plug.
4) I used an awl to poke a hole in the side of the bottle, just big enough so I could jam my pressure / vent line in it and it would not pull out. Don't make the hole too big.
If the power boost kicks in and out right at the vertical hover throttle setting, try extending the header length another 1/4".
Avoid lengthening your header by adding long silicone header couplers. The header needs to be metal so the walls can't flex in and out like a long silicone coupler will do. Flex will cause unwanted throttle behavior. You can of course use silicone couplers to join the lengths of aluminum header tube.
You can tie-wrap the can cap to the plane. On one of my profiles, I just let the can dangle around. It's up to you. Dave screwed a plastic landing gear strap to the bottom of his wing and tied it in with a rubber o-ring around the can cap.
I lurk here on RCU and haven't posted for a while. Many years ago, I moderated here and my user name was RCU, then we changed it to my name when the site got sold. I'm on the ProBro site a lot. Let me or Dave know if you have any questions.
JW
ProBro #90
Hide Signatures
       Post #: 8
RE: Bud can muffler's - 12/7/2012 6:37 AM
Ernie Misner
Score: 130
Status: offline
Excellent info John. Thanks for taking the time to lay it all out for us. Keep in mind this is for the 55AX. If anyone does want to real all 11 pages of the CCM thread at ProBro (the above link does't work without modification) just to to The Profile Brotherhood < Engines< CCM (coke can muffler) thread. It's fun reading and thanks to Dave McDonald and all the Bro's who put in their hard work and testing. All you need to make your own tuned system for 3D, not racing, is a mac's header, mousse can or better yet this coke can, and some coupler material. Dave pointed out that you can get the high temp silicone coupler material at McMaster Carr petty reasonable. Just type in high temp silicone tubing and it will take you to the page.
Hide Signatures
(in reply to John Wells)
       Post #: 9
RE: Bud can muffler's - 12/7/2012 8:15 AM
flyinwalenda
Score: 156
Last Login: 5/19/2013
Status: online
Brian Ray
Hide Signatures
       Post #: 10
RE: Bud can muffler's - 12/7/2012 9:31 PM
Ernie Misner
Score: 130
Status: offline
BTW - although the subject line is Bud can mufflers, turns out they are too big for the 55AX, the 8.5 oz. Coke can is just right.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 11
RE: Bud can muffler's - 12/17/2012 4:40 AM
John Wells
Score: 100
Status: offline
quote:
ORIGINAL: Dave pointed out that you can get the high temp silicone coupler material at McMaster Carr petty reasonable. Just type in high temp silicone tubing and it will take you to the page.
I had no idea it could be purchased anywhere other than the LHS. Thanks!
ProBro #90
Hide Signatures
       Post #: 12
RE: Bud can muffler's - 12/17/2012 4:41 AM
John Wells
Score: 100
Status: offline
ProBro #90
Hide Signatures
       Post #: 13
RE: Bud can muffler's - 12/17/2012 5:46 AM
Ernie Misner
Score: 130
Status: offline
You can get it from Mac's Products too but more expensive. At Mc. Carr you can get it in many sizes and thicknesses, as well as 3 grades of softness! While you're there look for high temp teflon tubing too.
Hide Signatures
       Post #: 14
RE: Bud can muffler's - 2/11/2013 3:58 AM
RC MANIAC119
Score: 100
Last Login: 5/15/2013
Status: offline
I disagree!! I used the full Bud Light bottle on my 55's until I could find the Coke 8.5's. I have to say, the ONLY difference I noticed was the bigger bottle made starting the engine a tad more difficult. It seemed like the bottle had to fill up with muffler pressure before the engine would lite off!!
Transition at mid range was the same....smoother than the stock muffler, and I got the same RPM's with both cans!!!
If you can't get the Coke bottles, don't be afraid to try the Bud!!!
RC MANIAC-PRO BRO 1900-AMA# 95841
Hide Signatures
       Post #: 15
RE: Bud can muffler's - 2/11/2013 5:59 AM
Ernie Misner
Score: 130
Status: offline
Thanks, good to know the bud can works good too. Most of Dave McDonalds testing wound up with the coke can. I think the larger bud can would look better on a 60 size plane perhaps.
Hide Signatures
(in reply to RC MANIAC119)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
