RE: HANGAR 9 PULSE 125 XT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Ziroli SBD Dauntless - RTF
Seller:  misfit
Details:   $3,000.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: HANGAR 9 PULSE 125 XT
Page: <<   < prev  1 [2]
Login
RE: HANGAR 9 PULSE 125 XT - 12/5/2012 6:52 PM
opjose
Score: 284
Last Login: 6/17/2013
Status: offline
quote:
ORIGINAL: bikerbc
Where do you get it?Do you have to worry about timing and that sort of thing or can you just bolt the new unit on? Thanks for any help...
Yes, no timing changes to worry about and all you have to do is replace your existing unit.
All you have to do is match the spark plug receptacle size, so often you can use ignitions from slightly larger or smaller engines.
Any place that sells engines equipped with Rcexl ignitions will have replacement.
I think I paid around $24.00 for one from Hobby King, but it has to be shipped from Hong Kong.
_____________________________
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to bikerbc)
       Post #: 26
RE: HANGAR 9 PULSE 125 XT - 12/5/2012 9:08 PM
RiverLarry
Score: 100
Last Login: 6/18/2013
Status: offline
Opjose  it will work a little better if you do re set your timing to 28 deg   I change mine and it seams to run a lot better at 28
with a diff   ing.  not a # 4    R/L
Hide Signatures
(in reply to opjose)
       Post #: 27
RE: HANGAR 9 PULSE 125 XT - 12/5/2012 9:44 PM
opjose
Score: 284
Status: offline
Yup I agree it does work better, but it is not absolutely necessary.
You can plug in the new ignition and the engine will start right up. That's what I did before playing with the timing.
Fortunately the provided sensor usually has a big enough mount holes that you can adjust the timing a few degrees and eek out a bit more power.
Hide Signatures
(in reply to RiverLarry)
       Post #: 28
RE: HANGAR 9 PULSE 125 XT - 12/5/2012 11:35 PM
tailskid
Score: 199
Status: offline
What RPM's are you guys getting with the DLE20?
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
       Post #: 29
RE: HANGAR 9 PULSE 125 XT - 12/6/2012 4:17 AM
Indiomike
Score: 115
Status: offline
Yes, you can use the standard RCEXL ignition module which comes with a DLE 55 engine. If you look closely at a DLE20 ignition module you will see "#4" or "4#" on the front of the module on the lower right corner area. It is lightly stamped and does not show up well.
You may need to reset the timing on a DLE20 to 28 degrees BTDC. A couple of degrees off either way won't make a major difference. Some people have reported their DLE20 factory set at about 34 degrees. Use a degree wheel to reset your timing for 28 degrees. If you don't have one, set the hall sensor right on the engine case boss line and you will be close.
I think all DLE single cylinder engines will run very well at 28 degrees BTDC, not sure about the twins. Almost any vender who sells RCEXL ignitions will have the standard module. Priced anywhere from about $45.00 to $79.00 depending who you buy it from. I got mine from Wrongway RC. Tower has them as does ValleyView RC and many other sources.
Indiomike
Hide Signatures
       Post #: 30
RE: HANGAR 9 PULSE 125 XT - 12/6/2012 8:22 AM
bikerbc
Score: 121
Status: online
Thankyou I appreciate the help
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to Indiomike)
       Post #: 31
RE: HANGAR 9 PULSE 125 XT - 12/7/2012 6:29 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
Yes you can just change it to rcexel with the proper curve. Valley View sells the rcexel unit for $50 I think or maybe you can find a better deal? The software is a bit different in the rcexel compared to the DLE ignition unit. When installing the rcexel you have to retard the sensor as far as it will go. My friend Gordon even said he had to make the slots a hair longer. By doing this it will give you the same exact timing as the DLE unit did at full throttle. Give Tom a call at VV and he will verify that. Thankfully the XYZ 20cc he sells already comes with the rcexel ignition.
Hide Signatures
       Post #: 32
RE: HANGAR 9 PULSE 125 XT - 12/7/2012 10:55 AM
bikerbc
Score: 121
Status: online
Has anybody else had the nose over problems that could not be over come with up elevator on take off ? Mine was just too hard on props, you had to use full up when first starting your roll gradually backing off to neutral at liftoff and then it had a very tail high attitude when ever taxing till I moved the gear...I am just wondering if the newer models have this cured because this was a real problem for a while...I ordered a gear from TNT but figured out my oun cure during the wait..My cure worked so well I never switched over...TNT makes a nice gear but pricy...Next time I will try cutting my own from a road sign as I have just learned works well from a tip from Grey Beard
< Message edited by bikerbc -- 12/7/2012 3:39 PM >
Hide Signatures
       Post #: 33
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
