3 Blade prop    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> 3 Blade prop
Page: [1]
Login
3 Blade prop - 11/29/2012 6:33 PM
acerc
Score: 221
Last Login: 5/26/2013
Status: offline
I don't know if this is the right place to ask but here goes. I have been debating on whether or not to use a 3 blade prop on a plane. Ihave heard they are not as efficient as 2 blades. I know some of you big bird flyers can give me a good idea of whether I should or not. The plane is a 33% Pitts-s1s, it will be powered by a 55cc twin. Shooting for a 20lb finished weight.
What say you?
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 1
RE: 3 Blade prop - 11/29/2012 6:46 PM
pe reivers
Score: 646
Last Login: 5/25/2013
Status: offline
If the total blade area is the same, they are more efficient than 2-blade props, according to NACA studies, and can have a higher disk loading. (more powerfor the same diameter) Exactly that is the caveat, and you need to go to smaller diameters, which lowers the power to thrust conversion efficiency somewhat. To be, or not to be, is the question. On a 55cc a two blade would be the best choice. On a 116 and upwards, the three blade would be.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to acerc)
       Post #: 2
RE: 3 Blade prop - 11/29/2012 6:58 PM
BarracudaHockey
Score: 280
Status: offline
3 blades are generally quieter too
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to pe reivers)
       Post #: 3
RE: 3 Blade prop - 11/29/2012 7:05 PM
ROGER RUSSELL
Score: 115
Last Login: 5/22/2013
Status: offline
Since the thread is labeled 3 Blade Prop I figure this is OK to ask this question and not hi jack the thread!
What would be a good 3 blade on a MOKI 150 on a 100" Ziroli Helcat?
Roger
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 4
RE: 3 Blade prop - 11/29/2012 7:19 PM
acerc
Score: 221
Status: offline
reivers, or anyone else, let's say the given two blade would be a 23x8 what would be the appropriate 3 blade and how much efficiency would be lost? Approximate of course.
< Message edited by acerc -- 11/29/2012 7:42 PM >
Robert
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 5
RE: 3 Blade prop - 11/30/2012 3:03 AM
speedracerntrixie
Score: 189
Status: offline
quote:
ORIGINAL: pe reivers
I used to fly a 150cc powered Extra in IMAC. I ended up using a 3 blade prop to help me keep the flying speed consistant. What I found was the airplane was quieter and had better downline breaking. I did loose about 15% vertical pull but the airplane had plenty to spare. For the 55 I would look into these. Size 20X10
Hide Signatures
       Post #: 6
RE: 3 Blade prop - 11/30/2012 3:06 AM
acerc
Score: 221
Status: offline
Thank's speedracer,  that is exactly what I was looking for. Experienced knowledge. The 20x10 is what I have ordered. I figure I'll start with the 2 blade and then when comfortable with the aircraft go to the 3 blade. I'm useing Beila prop's, how you like them? Or the better question, do you like them?
Robert
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 7
RE: 3 Blade prop - 11/30/2012 10:16 AM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: acerc
Use my prop power calculator http://mvvs.nl/prop-power-calculator.xls
Hide Signatures
(in reply to acerc)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
