Flyline RC    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Flyline RC
Page: [1]
Login
Flyline RC - 11/30/2012 5:37 PM
H5606
Score: 100
Last Login: 6/17/2013
Status: offline
I wasn't sure where to post but thought I'd ask about these here. I figured there'd be more knowledgeable resposes than under Toy-grade R/C Products since its similar to control line. It looks like the manufacturer got an idea from RTP "Round-the-Pole" flying that is perhaps more popular in Great Britain. I don't own one but was wondering if it is what I've seen in some low-res video on YouTube with what I believe are Spanish speaking participants having fun with three of them. Does anyone here own one and are they worth what Walmart or Toys-R-Us is asking? Have you done any mods to increase performance?
< Message edited by H5606 -- 12/2/2012 3:27 PM >
Hide Signatures
       Post #: 1
RE: Flyline RC - 12/1/2012 1:45 AM
Clean
Score: 116
Status: offline
these?
_____________________________
Intentional landings WITH a PBF are not
the intentional design OF the PBF
Hide Signatures
(in reply to H5606)
       Post #: 2
RE: Flyline RC - 12/1/2012 2:41 PM
H5606
Score: 100
Status: offline
Thanks for responding; a bit embarrassed to say so, but yeah - those...
I know Mattel tried something like this years and years ago ('70's) with some kind of bipe but it wasn't offered very long and I vaguely remember another company with a version that allowed for multiple flyers and had the name - perhaps something like "Hot Wings?".
Hide Signatures
(in reply to Clean)
       Post #: 3
RE: Flyline RC - 12/1/2012 6:27 PM
coriolan
Score: 100
Last Login: 6/18/2013
Status: offline
RTP is still around even in NA! Some good infos in that thread:
http://www.rcgroups.com/forums/showthread.php?t=346528&page=4
But that Flylinerc stuff is very neat as a complete package RTF:
http://www.flylinerc.com/
Hide Signatures
(in reply to H5606)
       Post #: 4
RE: Flyline RC - 12/2/2012 4:52 PM
H5606
Score: 100
Status: offline
Pardon my edit; I changed the title of this thread to be more accurate. I've only seen RTP in pictures and videos. Wikipedia says there is an annual RTP event that takes place in California but I don't remember seeing coverage for this particular event anywhere.
I've never flown RTP so I'm not an authority on the subject but I thought I'd try to explain what I think I know about it for the benefit of others that may read this info. From what I gather, these Flyline airplanes are like C/L in that they are flown within the airspace of a little bit more than a half-sphere but unlike C/L in that the operator stands outside the circle and controls elevator and throttle with an R/C transmitter. Wind is most likely an issue for stability as slack in the "line" cannot be taken out by the operator even though there would be no (R/C) control loss. I assume traditional RTP is similar to this scenario albiet using a mechanical means for remote control which is closer to the purity that control line represents.
Are these airplanes able to perform stunts (loops and wing-overs) like the mfg claims? Their video shows the airplanes performing stunts but only with computer simulation.
< Message edited by H5606 -- 12/2/2012 11:38 PM >
Hide Signatures
(in reply to coriolan)
       Post #: 5
RE: Flyline RC - 1/14/2013 1:23 PM
GallopingGhostler
Score: 133
Status: offline
They probably perform as the manufacturer stated.
RTP has been around for a while. Guillows 500 series http://www.guillow.com/Series500BalsaKits.aspx are designed to fly RTP with a Cox .020 (0.33 ci) Pee Wee reed valve engine (or electric motor equivalent) and a single line to a pole.
The Sterling "M" kit series of planes with a nominal wingspan of 20 to 24 inches (508 - 610 mm) were designed to use the Cox Pee Wee .020 engine, were built like free flight stick and tissue, could be flown CL, FF and RTP. For RTP, they used a larger vertically oriented CL bellcrank with spacing of a CL handle with a bracket that was pinned (nail) to a pole driven into the ground standing several feet above the ground. CL lines from the plane were connected to the pole bellcrank. Once flying, the pole bellcrank would turn with the model. If model climbed, the vertically stationary pole bellcrank would cause a little down elevator to be applied. If it sunk, a little up elevator would be applied. Basically it was self regulating, especially in the presence of light wind.
Another setup that was available in the early 1960's was a remote CL lever outside the CL circle with linkage to an articulated CL pole bellcrank, which in turn the CL lines from the plane were connected to. It would allow one to fly the CL plane while outside the circle.
George Hostler
Clovis MADS AMA Club, Vintage R/C Society (VRCS)
Hide Signatures
(in reply to H5606)
       Post #: 6
RE: Flyline RC - 1/14/2013 8:43 PM
Jim Thomerson
Score: 160
Status: offline
Some years back there was an article in one of the magazines about flying an 020 airplane from a rotating circle on top of a pole. A servo to the control lines, a receiver, and a battery were mounted on top of the circle.
Hide Signatures
(in reply to GallopingGhostler)
       Post #: 7
RE: Flyline RC - 1/14/2013 8:55 PM
GallopingGhostler
Score: 133
Status: offline
Jim, that's an interesting concept, more than one way to skin a cat.
AFAIK now that the AMA has approved use of 2.4 GHz RC for CL functions in contests, we most likely should be seeing more RC equipment being made available.
George Hostler
Hide Signatures
(in reply to Jim Thomerson)
       Post #: 8
RE: Flyline RC - 1/18/2013 4:32 AM
john345
Score: 100
Last Login: 1/18/2013
Status: offline
I have seen a complete video online that guides user to increase the performance by different mods, but I have not tried it yet. Therefore, I have no personal experience to share. However, I will share it soon.
private jet companies
Hide Signatures
       Post #: 9
RE: Flyline RC - 1/18/2013 6:21 PM
aspeed
Score: 105
Status: offline
All of the control line speed events are round the pole.  I have been thinking maybe they should be flown from outside the circle since no one can run fast enough to keep up with them anymore.  RC would work, but would be hard to fit inside the little planes, and the vibration would hurt them.  There is a 'Revolution System' for flying outside the circle with a .35 and smaller size motor. I would like to see a video of it.  The little micro foamies would work with some tipweight and noseweight in a gym much like the above video.  I put some pics of my Cox control line leckie as it is somewhat related. It isn't able to loop. The Flyline one seems much better.  It could maybe be improved with two batteries, but would likely burn out something.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to john345)
       Post #: 10
RE: Flyline RC - 1/18/2013 8:11 PM
GallopingGhostler
Score: 133
Status: offline
Rather than fitting inside the planes, I think a good place would be at the pole. Have a powerful enough servo to control the handle.
George Hostler
Hide Signatures
(in reply to aspeed)
       Post #: 11
RE: Flyline RC - 1/18/2013 11:21 PM
aspeed
Score: 105
Status: offline
Ya, like on a monoline handle would work.  They kind of suck though, they are not very precise.  They can barely do level flight sometimes.  Two line would be fine for most planes, but not the speed stuff.
Hide Signatures
       Post #: 12
RE: Flyline RC - 1/19/2013 2:39 AM
GallopingGhostler
Score: 133
Status: offline
I'm sure there is a way to do it. The servo has reduction gears, usually limiting travel to (+) and (-) 45 degrees. If one were to modify the gearing where it could exceed that, I could see how it could control a monoline system.
George Hostler
Hide Signatures
       Post #: 13
RE: Flyline RC - 1/21/2013 6:27 PM
FlyLineRC
Score: 100
Last Login: 1/21/2013
Status: offline
Hello Everyone,
My name is Justin and I handle all of the consumer-side interaction for Creative Play International, the company  that brings you FlyLine. I would like to open myself up to any specific questions you have about our product, and I appreciate the interest you have shown. We will be making a great deal of changes in 2013 to compensate for things that we learned as a new product in 2012.
I will happily answer all of your questions openly and honestly, so feel free to ask whatever is on your mind.
Thanks again
-Justin
Hide Signatures
       Post #: 14
RE: Flyline RC - 1/21/2013 9:33 PM
aspeed
Score: 105
Status: offline
Cool, a manufacturer.  Like the original poster asked, what is the suggested price, and where are they available?  For the future, Maybe a bigger one would be cool.  It looks pretty good.
Hide Signatures
(in reply to FlyLineRC)
       Post #: 15
RE: Flyline RC - 1/22/2013 4:34 PM
GallopingGhostler
Score: 133
Status: offline
I stand corrected, aspeed.
quote:
AMA 2013-2014 CL Competition Regulations, 2. General: The use of 2.4 GHz (utilizing spread spectrum, 47 CFR Part 15) radio control to accomplish functions other than providing aerodynamic control of the model’s elevation on Control Line models is allowed, but only to the extent and in the manner specifically allowed by the rules of the individual event. All control functions must be under the direct control of the pilot and only the pilot.
Elevator control is not allowed in competition, to include CL speed events.
George Hostler
Hide Signatures
       Post #: 16
RE: Flyline RC - 1/22/2013 6:09 PM
aspeed
Score: 105
Status: offline
I wonder if a servo to twist the line at the handle would be allowed, without using a radio.  Gear drives had been used in the past but didn't work well especially on smaller planes.  Monoline handles aren't being made any more because only a handful of people use them, maybe three handfuls at the most.
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.219RCU1
