how to cut aluminum??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Rcexl Opto Gas Engine Kill Switch ***FREE SHIPPING***
Seller:  swgiantscalemodels
Details:   $13.29   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> how to cut aluminum??
Page: [1]
Login
how to cut aluminum?? - 12/1/2012 2:59 AM
orthobird
Score: 105
Last Login: 5/21/2013
Status: offline
any advice?
i am trying to lighten this backplate.  keeping in mind, that when i am done, i will balance it.
it is 5" spinner
this is what i got so far and
i have decreased it by 1 and 1/8 ounce.
i have used a router aluminum bit X 2 (35 dollars)
and a  1 inch drill (30 dollars) did not work.
i could have bought the Tru turn spinner by now, but i am hard headed, so i am making a project out of it.
trying to figure out what else i can use to finish this off??
_____________________________
avoid crashing!!
Hide Signatures
       Post #: 1
RE: how to cut aluminum?? - 12/1/2012 3:53 AM
sensei
Score: 176
Last Login: 5/22/2013
Status: offline
Forget the router, it turns too fast use a drill press and get a UNI-Bit or piloted counter bores to get the job done at slower speeds. Just about any aircraft sheet metal mechanic can show you the way and will have these tools in his tool box if you know any.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to orthobird)
       Post #: 2
RE: how to cut aluminum?? - 12/1/2012 4:32 AM
hugger-4641
Score: 229
Status: offline
Was there a pic to go with your post?  Are you just trying to drill holes in it to lighten it up, or are you trying to mill down the thickness?
Jerry
AMA -922698 Nomal people scare me, but not as much as I scare them...
Hide Signatures
       Post #: 3
RE: how to cut aluminum?? - 12/1/2012 4:44 AM
sensei
Score: 176
Status: offline
OK I just saw the pics on another sight; so from where you are at to this point you are going to need a compressor, die grinder with a 1/4" collet, and 1/4" shanked fluted metal cutting bits to finish the job. You can get everything you need at very reasonable prices from Harbor Freight, just take your time and place it on the balancer many times as you go.
Bob
Hide Signatures
(in reply to hugger-4641)
       Post #: 4
RE: how to cut aluminum?? - 12/1/2012 12:38 PM
orthobird
Score: 105
Status: offline
i am unable to post pictures on this site,  anyone have any advice.
avoid crashing!!
Hide Signatures
(in reply to sensei)
       Post #: 5
RE: how to cut aluminum?? - 12/1/2012 1:21 PM
Tony Hallo
Score: 141
Status: offline
At this rate you are doing a better job lightening your wallet than the back plate.  You might want to consider buying a new lighten version!  But if you are having fun than go for it.
Tony Hallo
Hide Signatures
       Post #: 6
RE: how to cut aluminum?? - 12/1/2012 7:47 PM
orthobird
Score: 105
Status: offline
wow, i got the backplate down to 2 1/4 ounces.
it originally weighed 5 1/8 ounces.
avoid crashing!!
Hide Signatures
(in reply to Tony Hallo)
       Post #: 7
RE: how to cut aluminum?? - 12/1/2012 8:24 PM
Yank II
Score: 100
Status: offline
Fleet Brotherhood # 9
Ryan STA/STM Brotherhood # 6
Hide Signatures
       Post #: 8
RE: how to cut aluminum?? - 12/1/2012 11:48 PM
Darryl Usher
Score: 100
Status: offline
When you lighten the back plate you will need a front support for the spinner.
Darryl
Usher Tool
Hide Signatures
(in reply to Yank II)
       Post #: 9
RE: how to cut aluminum?? - 12/2/2012 2:28 AM
sensei
Score: 176
Status: offline
I read that you decided not to use your modified backplate, thats really OK because you still learned from this experience and I am sure you will apply it later down the road.
Bob
Hide Signatures
(in reply to Darryl Usher)
       Post #: 10
RE: how to cut aluminum?? - 12/2/2012 2:40 AM
orthobird
Score: 105
Status: offline
i have decided i will not be using this.  i will buy a new one. thank you all for comments.
avoid crashing!!
Hide Signatures
       Post #: 11
RE: how to cut aluminum?? - 12/2/2012 2:42 AM
orthobird
Score: 105
Status: offline
that's right bob,
i learned so much
it was fun, and it was an exercise in using high speed routers.
avoid crashing!!
Hide Signatures
       Post #: 12
RE: how to cut aluminum?? - 12/2/2012 2:43 PM
ahicks
Score: 669
Status: offline
And sweeping up alum. shavings?
Hide Signatures
       Post #: 13
RE: how to cut aluminum?? - 12/3/2012 1:40 AM
orthobird
Score: 105
Status: offline
oh yeah, and one impaled me under my eye, even though  i was wearing eye protection.  looks like i got some swelling there right now.  i press deep and there is no pain, so i do not believe there is any metal left in there.
avoid crashing!!
Hide Signatures
(in reply to ahicks)
       Post #: 14
RE: how to cut aluminum?? - 12/4/2012 10:14 PM
nitro wing
Score: 125
Status: offline
5 inch spinner, must be a big plane, shaving 2 ounces on the backplate wont to anything for CG changes, if that is why you tried to lighten it.
Take care of the eye, metal fragments can be nasty.
Hide Signatures
       Post #: 15
RE: how to cut aluminum?? - 12/11/2012 11:30 AM
orthobird
Score: 105
Status: offline
Hi Nitro, you would not believe it, but the balance of plane was within ounces.  but it turned out plane was tail heavy, so i re-ordered the backplate and spinner.
quote:
ORIGINAL: nitro wing
Click to see fullsize image.
Click for fullsize
Click for fullsize
avoid crashing!!
Hide Signatures
(in reply to nitro wing)
       Post #: 16
RE: how to cut aluminum?? - 12/11/2012 12:12 PM
orthobird
Score: 105
Status: offline
i put in 4 servos for the elevators, 2 on each stab half.  each servo has 500 ou/torque/in
each servo weighs 2 ounces.
the two extra servos is 4 ounces
but at the nose, it is equivalent to 8 ounces needed to counterbalance it.  i did not remove the two extra servos, instead, i undid all my canopy work, and removed the pilot and the instrument panel, and then i perforated the electronics tray.  by doing so, i removed over 1 pound off the plane.
avoid crashing!!
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
