Small Biplane Kits or Plans    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Small Biplane Kits or Plans
Page: [1] 2   next >   >>
Login
Small Biplane Kits or Plans - 12/1/2012 4:46 AM
Steve Westphal
Score: 100
Last Login: 5/19/2013
Status: offline
Does anyone know of a 1/2 A Pitts biplane kit or plans with a span of approx 22 to 24 inches? I have seen a Royal Pitts but it has a 30 inch span. I would prefer it to be a bit smaller so I can use one of my TD .020's on it.
_____________________________
Steve Westphal
Hide Signatures
       Post #: 1
RE: Small Biplane Kits or Plans - 12/1/2012 4:56 AM
combatpigg
Score: 376
Status: offline
If you can find plans, the Goldberg .60 sized Ultimate Bipe scales down to 24 inches and makes a nice flyer with a Norvel .074. You'll need to rethink the construction details to keep it light, but the basic layout works really well.
I used 1/16" diameter bamboo skewers for the cabane struts and a real long drill bit to drill the holes between both wings in 1 shot while the plane sat in a jig. The actual drilling and skewering was real easy after just a little time was spent to temporarily hold the wings and fuselage in place.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to Steve Westphal)
       Post #: 2
RE: Small Biplane Kits or Plans - 12/1/2012 5:46 AM
skaliwag
Score: 100
Status: offline
I made this one with foam and flew it at SMALL about 5 years ago. Fluging weight with a GWS S2 minus battery is 5.9oz. May have the drawings around if interested.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
(in reply to combatpigg)
       Post #: 3
RE: Small Biplane Kits or Plans - 12/1/2012 3:52 PM
buzzard bait
Score: 115
Last Login: 5/16/2013
Status: offline
If it's a Pitts you want then get a Herr Pitts Special in the FF section at Sig. It's 24 inches and much more scale than the one meant for RC, which is 30 inches anyway.
Lots of people convert these to electric RC, but I'm sure it would suit a TD 020 extremely well with the proper mods.
Jim
Hide Signatures
(in reply to skaliwag)
       Post #: 4
RE: Small Biplane Kits or Plans - 12/1/2012 4:50 PM
skaliwag
Score: 100
Status: offline
This place has oodles and a few F/F Bipes that are meant for rubber and in the 24" range. Pee Wee or TD should fly them when beefed up in strategic areas.
http://pennvalleyhobbycenter.com/rubber/indexaircraft.htm
Hide Signatures
(in reply to buzzard bait)
       Post #: 5
RE: Small Biplane Kits or Plans - 12/1/2012 4:54 PM
skaliwag
Score: 100
Status: offline
I have been Jones'in for .020 size Bipe for a long - long time. Stumbling block for me is mounting a removable top wing and cabanes that don't tear the wing to pieces in a hard landing. I'm all ears if you all have Skaliwag proof solution.
Hide Signatures
       Post #: 6
RE: Small Biplane Kits or Plans - 12/1/2012 6:12 PM
proctor
Score: 100
Last Login: 5/9/2013
Status: offline
Hi Scaliwag,
I'm currently building a 25 1/2" span Sopwith Swallow for FF, it's a Bill Denis design,one
of our UK greats. Bills solution to your problem was to build wing cabin struts and a
section of top deck of fuselage all in one piece, which would, hopefully, knock off in a free flight arrival.
I probably got plan from Outerzone so it might be worth your time to do a search for it to see his neat solution.
The Sopwith Swallow is a parasol wing rather than a biplane of course.
John
Hide Signatures
       Post #: 7
RE: Small Biplane Kits or Plans - 12/1/2012 6:58 PM
D.J.
Score: 105
Status: offline
This shows an 049 installed but the wingspan is less than 24" . I believe that an 020 would work . Others might know better . ... D.J.
Click for fullsize
Hide Signatures
(in reply to proctor)
       Post #: 8
RE: Small Biplane Kits or Plans - 12/1/2012 7:13 PM
combatpigg
Score: 376
Status: offline
It might not look elegant, but use nylon screws that pass completely through the top wing and thread right into the framework that is below the wing. Balsa N struts with hardwood blocks mounted tight against the bottom of the top wing could be shaped to look not too ugly and thread the hardwood for #8-32 screws.
Hide Signatures
(in reply to D.J.)
       Post #: 9
RE: Small Biplane Kits or Plans - 12/1/2012 7:27 PM
acerc
Score: 221
Status: offline
This place has some nice small stuff.   http://patscustom-models.com/index.html
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 10
RE: Small Biplane Kits or Plans - 12/1/2012 9:49 PM
MJD
Score: 125
Last Login: 5/13/2013
Status: offline
Fleet Trainer 28"
I try to be pessimistic, but why bother?
Hide Signatures
(in reply to acerc)
       Post #: 11
RE: Small Biplane Kits or Plans - 12/2/2012 4:10 AM
Andrew
Score: 105
Status: offline
It's controlline, but could be easily converted if built very lightly. Span is 25".
Click to see the file in new window.Attachment.pdf
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
(in reply to MJD)
       Post #: 12
RE: Small Biplane Kits or Plans - 12/2/2012 5:44 AM
fritzke
Score: 100
Last Login: 5/18/2013
Status: offline
Super basic, not too very scale and rubber power, but it is a Pitts bipe with a 24" span!
Dave
Hide Signatures
(in reply to Andrew)
       Post #: 13
RE: Small Biplane Kits or Plans - 12/2/2012 11:39 AM
flyinrog
Score: 109
Last Login: 5/15/2013
Status: offline
I was gonna say..ask Dave he's gotta have something!!
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
Hide Signatures
(in reply to fritzke)
       Post #: 14
RE: Small Biplane Kits or Plans - 12/2/2012 2:37 PM
buzzard bait
Score: 115
Status: offline
I think there are about a dozen of us who are more interested in this than the original poster!
Hide Signatures
(in reply to flyinrog)
       Post #: 15
RE: Small Biplane Kits or Plans - 12/2/2012 5:21 PM
airraptor
Score: 130
Status: offline
LOL the OP asked for a KIT or PLANS for PITTS biplane. only one guy did that. The Herr pitts is a good choice and I even think Peck Polymers had a Pitts with a 18" span.
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 16
RE: Small Biplane Kits or Plans - 12/2/2012 9:12 PM
MJD
Score: 125
Status: offline
Yeah you're right, even me. I know I read too fast, and I read it as "looking for a biplane for a TD .020"..
Potential convert?
Dumas Pitts Specialhttp://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVET9
Hide Signatures
(in reply to airraptor)
       Post #: 17
RE: Small Biplane Kits or Plans - 12/3/2012 7:50 PM
airraptor
Score: 130
Status: offline
MJD you're correct it wasnt PP it was Dumas. I would like to see one of these fly in a full house set up with a throttled .020.
AMA # 186123
Hide Signatures
(in reply to MJD)
       Post #: 18
RE: Small Biplane Kits or Plans - 12/3/2012 9:27 PM
MJD
Score: 125
Status: offline
It seems a better size for any level of performance from an .020. 18" sounds small but for a Pitts it ain't.
Hide Signatures
       Post #: 19
RE: Small Biplane Kits or Plans - 12/4/2012 10:42 PM
small_rcer
Score: 100
Last Login: 12/4/2012
Status: offline
Wasn't there an Andrew on the west coast who had a web site with Bipe plans. He also had the PDF tile program. Can't recall his site name.
Also hosted the 1/2a design contest results for several years.
Found it. Andrew Donatelli
donatelli.net
Later: Plans seem to have disappeared from his site.
Hide Signatures
(in reply to MJD)
       Post #: 20
RE: Small Biplane Kits or Plans - 12/5/2012 12:48 AM
acerc
Score: 221
Status: offline
Here's a 18" ws pitts     http://www.dumasproducts.com/product_info.php?products_id=703
And its cheap enough to buy for the plans, then enlarge them.
Robert
Hide Signatures
(in reply to small_rcer)
       Post #: 21
RE: Small Biplane Kits or Plans - 12/5/2012 12:56 AM
acerc
Score: 221
Status: offline
The AMA also has numerous plans of almost any biplane in your size range.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 22
RE: Small Biplane Kits or Plans - 12/5/2012 3:45 AM
Steve Westphal
Score: 100
Status: offline
Thanks for pointing me back to dumas.....love their staggerwing.
Steve Westphal
Hide Signatures
(in reply to acerc)
       Post #: 23
RE: Small Biplane Kits or Plans - 12/5/2012 6:20 PM
flyinrog
Score: 109
Status: offline
Whatever happened to the guy that was you tubing a coroplast bipe?..I went and bought a sheet of it and never saw part 2 or maybe it was three? Anybody build one of those for the 049 product engine...Rog
Hide Signatures
       Post #: 24
RE: Small Biplane Kits or Plans - 12/5/2012 8:10 PM
SBS_Pilot
Score: 105
Status: offline
quote:
ORIGINAL: flyinrog
I think that the last part still isn't uploaded, but an other fellow has made his own buildvideo to complete the one Bruce Simpson started on. You'll find the link in post #58 of this thread: www.rcuniverse.com/forum/m_10446044/tm.htm
/Stefan
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
