Corsair    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Corsair
Page: [1]
Login
Corsair - 12/1/2012 3:12 PM
mark36ph
Score: 100
Last Login: 1/25/2013
Status: offline
Hi,
I bought a Corsair recently, but the person I bought it off didn't know what make it was. I was hoping someone here could help me out in identifying its make?
Wing Span 62 inches
Length 49 inches
Hide Signatures
       Post #: 1
RE: Corsair - 12/1/2012 3:29 PM
V2rider
Score: 100
Last Login: 5/5/2013
Status: offline
   The only Corsair in this size that I know of with flaps is the TopFlite .61 size. I guess it could be a modified H9, but the markings look like a few of the TF's that I have seen built from kits.
Hide Signatures
(in reply to mark36ph)
       Post #: 2
RE: Corsair - 12/1/2012 3:34 PM
mark36ph
Score: 100
Status: offline
I was thinking it was the Top Flight one, but does that not come with retracts in ready? This one does not have retracts.
Hide Signatures
(in reply to V2rider)
       Post #: 3
RE: Corsair - 12/1/2012 3:41 PM
Live Wire
Score: 6329
Last Login: 5/21/2013
Status: online
Does it have a metal cowl! if so it could be a Royal kit.
More pictures would help!
_____________________________
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 4
RE: Corsair - 12/1/2012 3:45 PM
mark36ph
Score: 100
Status: offline
No,  the cowl is plastic on it.
Hide Signatures
(in reply to Live Wire)
       Post #: 5
RE: Corsair - 12/1/2012 3:49 PM
DavidAgar
Score: 146
Last Login: 5/20/2013
Status: online
It could be a Top Flite kit build, which if built as per the plans, does not have retracts. The newer ARF's have retracts. Your model sure looks like the Top Flite Corsair. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
       Post #: 6
RE: Corsair - 12/1/2012 3:50 PM
mark36ph
Score: 100
Status: offline
thanks for the help. i will call it a top flight then
Hide Signatures
(in reply to DavidAgar)
       Post #: 7
V2rider
Score: 100
Status: offline
   The TF ARF comes with the retract wells installed, but it could have been the kit. With the kit it was your choice on the retracts. Being built from the kit would also explain the shine on the covering. There is one hanging in a lhs that the builder put fixed gear in and used the covering Ultracoat covering. Looks just like this one.
Hide Signatures
       Post #: 8
RE: Corsair - 12/1/2012 3:52 PM
Live Wire
Score: 6329
Status: online
I just went out into the shop and it looks just like my Hanger 9. Are the wing sheeted or just covered with covering, the H 9 is just covered with ultracote with cap stips on the leading edge. The first came out with fixed gear
Larry K AMA 36417
Hide Signatures
       Post #: 9
RE: Corsair - 12/1/2012 4:05 PM
da Rock
Score: 265
Status: online
The covering color and wingtips look very much "kit built".
Most ARFs are built with as little hand shaping as possible. The tips on your Corsair really don't look like that. The shaping done on those tips look very 'shaped'.
It really doesn't look like any of the ARFs available in the last 5 or so years.
Your measurements and most of the decals on the model in your picture match up to the TopFlite kit don't they. I'm pretty sure the kit didn't come with covering.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Good flying wit ya today
Hide Signatures
       Post #: 10
RE: Corsair - 12/1/2012 5:01 PM
alanc
Score: 105
Status: offline
You got this from Stockport, i went and had a look at it,    it wasnt for me,    tooooo much effort putting retracts in it,    its the topflite gold kit,     strange isnt it,    if you are local to this model, then you are local to me, and here we are, on a forum that is based thousands of miles away from our homes,     funny old world, innit?
Hide Signatures
(in reply to da Rock)
       Post #: 11
RE: Corsair - 12/1/2012 7:21 PM
rwright142
Score: 100
Last Login: 5/19/2013
Status: offline
I agree with the other posters. My TF came with #410 so it definitely sounds right.
In the works: 1/6 Scale F4U Corsair
CORSAIR Brotherhood # 39
Hide Signatures
(in reply to alanc)
       Post #: 12
RE: Corsair - 12/1/2012 7:23 PM
mark36ph
Score: 100
Status: offline
quote:
ORIGINAL: alanc
Indeed I did
I'm in Southport
I am looking into putting retracts in it, but first I need to find out if it flys alright!
Most likely be next weekend for its first flight.
Hide Signatures
(in reply to alanc)
       Post #: 13
RE: Corsair - 12/1/2012 8:14 PM
alanc
Score: 105
Status: offline
have you got some retracts?
Hide Signatures
       Post #: 14
RE: Corsair - 12/1/2012 8:16 PM
mark36ph
Score: 100
Status: offline
No,
I have bee searching for suitable ones for it. I don't want some cheap hobby king ones that are gonna collapse on me as soon as it touches down, but I also don't want to spend way too much on something that's not needed.
Hide Signatures
(in reply to alanc)
       Post #: 15
RE: Corsair - 12/2/2012 1:21 PM
ackroyd
Score: 105
Last Login: 4/7/2013
Status: offline
I use the H9 all metal rotating retracts in my H9 Corsair, no probs whatsoever and with some aftermarket oleos added, she looks good.
Mine is here
Chris
Hide Signatures
       Post #: 16
RE: Corsair - 12/2/2012 1:22 PM
flyer35
Score: 100
Last Login: 5/6/2013
Status: offline
I'm just finishing the TF gold kit for a club member and if your cowl is two piece (cowl and mounting ring) it is probably TF. The decals are the same as ours. We used Robart retracts and they operate fine but it hasn't been test flown yet. Winter is here in upstate NY, it'll be a long wait for our maiden. Good luck with yours.
fly it like you stole it!
Hide Signatures
       Post #: 17
RE: Corsair - 12/2/2012 7:58 PM
mark36ph
Score: 100
Status: offline
I've been looking at the robart retracts, they're quite expensive the ones i've seen. Am I looking at the right ones for around $140?
Hide Signatures
(in reply to flyer35)
       Post #: 18
RE: Corsair - 12/2/2012 8:21 PM
alanc
Score: 105
Status: offline
Sent you a PM
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.945RCU1
