RE: Stripped threads on OS 46AX Engine Head    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Stripped threads on OS 46AX Engine Head
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Stripped threads on OS 46AX Engine Head - 12/3/2012 11:21 PM
aspeed
Score: 105
Last Login: 6/20/2013
Status: offline
I never had much luck recutting stripped threads.  A rolform tap can sometimes mush the aluminum back in place, but a cutting tap will only make a chip which is really removing more material making things worse. Probably see you tomorrow Dennis if you are doing the indoor thing.
Hide Signatures
(in reply to Propworn)
       Post #: 26
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 12:12 AM
MetallicaJunkie
Score: 243
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: CrashedTrainer
@wcmorrison: No... i know i didn't cross thread it... it was over torqued for sure, excessively... as aspeed said.. i have learned my lesson too, the hard way... i think the poor engine head tried to cope up as much as it could but gave up in the end... anyways
@metallicajunkie: thanks... i would most definitely want to get it from you but it would cost me a fortune, i think, to get it shipped here to Pakistan all the way from the US? :/
ohhh sorry... i didnt realize you lived outside the USA..... i was gonna let you have it for 10 shipped
_____________________________
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to CrashedTrainer)
       Post #: 27
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 12:19 AM
oneaew@msn.com
Score: 132
Status: offline
i tighten my plugs finger tight no trouble and a new washer each time
Hide Signatures
       Post #: 28
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 12:20 AM
oneaew@msn.com
Score: 132
Status: offline
GO FOR A NEW HEAD THEEN YOU WONT HAVE ANY TROUBLE
Hide Signatures
       Post #: 29
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 1:32 AM
GTMUSTANGCS
Score: 100
Last Login: 12/6/2012
Status: offline
I use a nut driver and two fingers to tighten glow plugs.
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 30
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 4:45 AM
drac1
Score: 100
Status: offline
If Heli coils are readily available, then that is the way to go. Do not use a insert pressed into the head. It needs to be threaded so it will not move or come out. A Heli coil self locks once it is in. It is also much stronger than the aluminium so you won't have the same problem again.
When you fit the plug, once it bottoms out just a slight nip is all that is required.
There is no such thing as too much power.
Hide Signatures
(in reply to GTMUSTANGCS)
       Post #: 31
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 12:33 PM
on_your_six
Score: 264
Status: offline
You guys are incredible... you will spend $20 for a helicoil to fix a part that costs $20. Le't see... I would like a repaired part more than a brand new one NOT.
If the cost of a repair is more than one-half the cost of the brand new part... I will take the new part every time, no question. My time is worth something. Dealing with repaired junk is no picnic. I want value for my dollar spent.
Hide Signatures
(in reply to tiffitech)
       Post #: 32
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 1:09 PM
drac1
Score: 100
Status: offline
quote:
ORIGINAL: on_your_six
An earlier post said they could have the repair done for 5 or 6 dollars. If that is the case, then that would be the way to go.
As for repaired junk, if their is nothing else wrong with the head then that is money well spent. A stainless steel heli coil in a aluminium head is far better than screwing into aluminium.
IMO that should be done as a part of the manufacturing process.
It would take me no more than ten minutes to heli coil a head. That is time well spent.
Hide Signatures
(in reply to on_your_six)
       Post #: 33
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 4:38 PM
Propworn
Score: 193
Status: offline
Buying a helicoil kit for single use may not be cost effective if the original part is readily available and inexpensive. I originally purchased mine to repair a cylinder head on a friends OPS boat motor. The OPS like the EEEEEENNNNNYYYYYYAAAAA are engines from a bygone era so any kind of support in the new world is hard to come by. Since the original purchase I have used the helicoil kit time and time again so it has paid for itself. Some confidence with a tap and sizing the length of the helicoil is necessary, though not that difficult if careless one can screw up a head beyond repair.
Dennis
Hide Signatures
(in reply to drac1)
       Post #: 34
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 4:47 PM
Propworn
Score: 193
Status: offline
I used to think when someone said EEEEENNNNNYYYYYYAAAAA they were referring to braying of wild horses however after observing the fractured finger dance at the field I came to realize it really meant “BAD JU JU”
I digress back to the topic at hand. If you purchase by chance a helicoil kit and learn to install it properly you may become everyone’s new best friend. All kidding aside it’s great to be able to help your friends out if you have the opportunity.
Dennis
< Message edited by Propworn -- 12/5/2012 11:50 PM >
Hide Signatures
       Post #: 35
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 5:02 PM
mscic-RCU
Score: 100
Last Login: 6/6/2013
Status: offline
Throw away the cross shaped driver and get a regular nut driver. It will keep you from over-tightening the glow plug
Hide Signatures
       Post #: 36
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 5:50 PM
captinjohn
Score: 247
Status: offline
Talking about cylinder heads, I bought a .90 Supertiger at a yardsale for a good price. It is like new...but the head was missing. I would like to find a good used one.  Thanks   Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 37
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 9:21 PM
Sport_Pilot
Score: 233
Status: online
I think the heli coil cost more than $7 bucks, even more than the $20 Mr. Lee asks.  Mostly because of the special size and small volume.  So is this repair a heli coil or just retapping the head.  If it is the latter don't do it.  But $7 for a heli coil is a steal.  And a heli coiled head is much better than a new non heli coiled head.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 38
RE: Stripped threads on OS 46AX Engine Head - 12/4/2012 11:50 PM
jp1961
Score: 100
Last Login: 6/17/2013
Status: offline
I would say if you can get the head new, then replace it. I'd use a Helicoil on a head that's no longer available. I have a Bridgeport and could make this repair in 15 minutes, however I've never been able to find 1/4-32 helicoils. Not sure if they only supply them to Clarence Lee.
Jeff
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 39
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 12:26 AM
Propworn
Score: 193
Status: offline
http://www.blindrivetsupply.com/Recoil-14-32-UNEF-Thread-Repair-Kit-10-Inserts-In-Kit-34040-32_p_3626.html
quote:
ORIGINAL: jp1961
Jeff
Hide Signatures
(in reply to jp1961)
       Post #: 40
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 2:51 AM
aspeed
Score: 105
Status: offline
$ 0.68 each, and 10 min.  $3 each if you need to buy the installation kit to do 10.  If you do 2 heads, the kit has paid for itself.  I bought the Turbo tap, so the smaller motors may work better.  I have to make the whole head on some motors, but it's a hobby, right?  In most cases, a helicoil is considered an upgrade.  For a head, I think there is a chance of leakage because there is a possibility of leaking at two threads.  The other brand insert with a shoulder looked better to me, or a Nelson plug mod. if a new head isn't made or purchased.   A Turbo or Nelson style head will give an increase in performance which is always a good thing.
Hide Signatures
       Post #: 41
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 4:22 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
>>> As Clarence Lee said 40 years ago. Get a 1/4-32 die and clean up the threads of each new glow plug before using >>>
+1 - Clarence Lee repeated that in his Engine Clilnic article not too long ago. He said the glow plug threads are rolled instead of cut and they need to be cleaned up. If not, when you tighten the plug. there will be 'too tight' spots. Those tight spots tend to weld themselves to the aluminum in the head if you have a hot run. Then when you pull the plug out the next time, bingo, out comes the threads with it. I did get myself a die and ran every old plug I had through it. Not to worry, it didn't take excess material off leaving the plug loose in the head. It just cleaned the high spots off of the threads real nice. I'm sold.
Hide Signatures
       Post #: 42
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 4:56 AM
drac1
Score: 100
Status: offline
I have never had a problem with tight or binding glow plugs during 16 years of flying. I have never stripped a thread either. I find that a couple of drops of oil on the thread to lubricate is all that is required. A slight nip once the plug has bottomed and all is good.
Most people generally over tighten most bolts. They don't need to be as tight as you would think.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 43
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 2:31 PM
CrashedTrainer
Score: 100
Last Login: 6/18/2013
Status: offline
Got the head back after the repairs...the guy inserted a brass bush with threads inside of it...it doesn't look like a very neat job but i am hopeful that it will do the trick, lets see ... otherwise i will have to get a new engine head... :/
Click to see fullsize image.
Click for fullsize
Click for fullsize
Best Regards,
CrashedTrainer
Hide Signatures
(in reply to drac1)
       Post #: 44
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 2:57 PM
aspeed
Score: 105
Status: offline
Looks like it should work.  It is fairly flush on the inside from what I can see on the pic.  If the plug is flush on the bottom of the inside, and it doesn't leak, then you are better than new.
Hide Signatures
       Post #: 45
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 3:43 PM
drac1
Score: 100
Status: offline
Looks like corrosion around the insert? If it is, I don't know how successful the repair woul be.
Hide Signatures
(in reply to aspeed)
       Post #: 46
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 4:10 PM
aspeed
Score: 105
Status: offline
Likely loctite, or epoxy.  It is a different country, who knows what they have over there for brand names.
Hide Signatures
(in reply to drac1)
       Post #: 47
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 4:34 PM
CrashedTrainer
Score: 100
Status: offline
yeah...that is some sort of epoxy... it is not corrosion that i can tell you...
Best Regards,
CrashedTrainer
Hide Signatures
       Post #: 48
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 5:11 PM
drac1
Score: 100
Status: offline
It will be interesting to see how the epoxy copes with the heat. Keep us informed.
Hide Signatures
       Post #: 49
RE: Stripped threads on OS 46AX Engine Head - 12/5/2012 5:48 PM
Mr Cox
Score: 102
Status: online
Looks like you'll a long reach plug now, instead of the medium reach OS plugs.
Hide Signatures
(in reply to drac1)
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Stripped threads on OS 46AX Engine Head
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.703RCU1
