Superglue vs Epoxy    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> Superglue vs Epoxy Page: [1]
Login
Superglue vs Epoxy - 12/2/2012 2:53 PM
mlbrenn
Score: 100
Last Login: 12/6/2012
Status: offline
I broke the body mount studs on my Monster Beatle. I superglued them back on but the one came off.
Would epoxy hold better?
Thanx for your time.
mlb
Hide Signatures
       Post #: 1
RE: Superglue vs Epoxy - 12/2/2012 3:42 PM
proanti1
Score: 341
Last Login: 1/6/2013
Status: offline
CA (super glue) is very brittle. Tire glue is CA with vinyl added, it's a bit more flexible, but still pretty brittle. Epoxy can be flexible, but can also be extremely brittle, depending on what you buy. In the case of a body post, there is just too much force applied for them to effectively be glued. One thing you can try is take a strip of gauze, spread on some epoxy, so it's nice and saturated, then wrap it around the broken part, this will sometimes be sufficient.
_____________________________
Her name was Lola. She was a show girl.
Hide Signatures
(in reply to mlbrenn)
       Post #: 2
RE: Superglue vs Epoxy - 12/2/2012 11:10 PM
SyCo_VeNoM
Score: 626
Last Login: 5/25/2013
Status: offline
or another option get a needle heat it up and jam it through the end of the part so it has something to try and stabilize it when doing the above.
I've done boot leg fiber glass with epoxy and toilet paper also and it held pretty decent on a stand that the arm snapped in half like 3 years ago, and its still holding till today
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
(in reply to proanti1)
       Post #: 3
RE: Superglue vs Epoxy - 12/2/2012 11:16 PM
1QwkSport2.5r
Score: 155
Status: offline
I used epoxy putty to fix a steering knuckle on my 13 pound LST2 monster truck. I sanded the plastic good, cleaned with acetone and wrapped the entire knuckle with putty until it cured. Still using this knuckle on the truck, repaired it 2 years ago.
Any epoxy will work, but the fortified stuff is better. Epoxy does not adhere to plastic very often, for this reason you must sand the parts and clean with acetone or lacquer thinner before applying epoxy to plastic. This method may work on a body post for awhile, it may not. If you have the stuff on hand already, try it. If not, buy new body posts to be safe. It's probably cheaper.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 4
RE: Superglue vs Epoxy - 12/2/2012 11:36 PM
The Mad Modder
Score: 341
Status: offline
The best option would be to remove all the dried super glue from the parts and use liquid solvent based model cement. It actually melts both surfaces of the broken joint together making it one piece again. Make sure the cement is made to work with ABS. I know that Testor's cement will work. Mended a broken chassis tub with it and it hasn't come apart so far.
God bless America
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 5
RE: Superglue vs Epoxy - 12/3/2012 12:08 AM
sheograth
Score: 320
Last Login: 5/13/2013
Status: offline
There shouldn't be much force on a body post, provided you drive properly
RCUniverse.com | Wattflyer.com | RCUvideos.com
Hide Signatures
(in reply to The Mad Modder)
       Post #: 6
RE: Superglue vs Epoxy - 12/3/2012 12:30 AM
yakfish
Score: 426
Last Login: 5/21/2013
Status: offline
Try JB Weld, or JB Quik.
Hide Signatures
(in reply to sheograth)
       Post #: 7
RE: Superglue vs Epoxy - 12/3/2012 7:37 AM
TheKennyKiller
Score: 462
Last Login: 1/23/2013
Status: offline
quote:
ORIGINAL: sheograth
huh? My body posts take a beating. If you drive properly, you must be doing it wrong.
Do you even RC?
Hide Signatures
       Post #: 8
RE: Superglue vs Epoxy - 12/3/2012 2:49 PM
i8tweety
Score: 133
Status: offline
I've had good success "temporarily" mending parts (suspension arms, body posts, chassis) following the tissue paper and CA method while until either the tower hobbies order arrives or pick up replacement parts (along with a spare) from the local hobby shop. I've yet to have a repair break again, but I only use them for a short period of time.
1 Bad Puddy Tat
Hide Signatures
(in reply to TheKennyKiller)
       Post #: 9
RE: Superglue vs Epoxy - 12/3/2012 6:02 PM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
This method is pretty much how I repair plastic / resin parts, etc. except I use Devcon "Plastic Welder"...it comes in the double syringe (black ) and is, I believe Methyl Methacrylate? It cures very quickly...less than 5 minutes, and works great to mount servo, and landing gear rails, etc. in fiberglass fuselages, too...very strong. Cleaning and prep is critical for a strong glue joint.
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
       Post #: 10
RE: Superglue vs Epoxy - 12/3/2012 10:10 PM
mlbrenn
Score: 100
Status: offline
Thanx everyone for your input.
I have several good things to try.
Can I find the plastic weld at Lowes?
Thanx again everyone
Hide Signatures
(in reply to proptop)
       Post #: 11
RE: Superglue vs Epoxy - 12/3/2012 10:34 PM
proptop
Score: 130
Status: offline
I think Lowes might have it...I've gotten it from Auto Zone and Advance Auto Parts.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
