where do i get this exhaust?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> where do i get this exhaust?
Page: [1]
Login
where do i get this exhaust? - 12/2/2012 9:33 PM
sparky4lawndart
Score: 100
Last Login: 5/24/2013
Status: offline
Oh YS gods... I need a new exhaust header do-hicky...
anyone know where I can get a new on of these? i don't know if you can see but the fitting that goes into the motor is damaged...
Click to see fullsize image.
Click for fullsize
_____________________________
just let me have it... It''ll be a lawndart in no time...
Hide Signatures
       Post #: 1
RE: where do i get this exhaust? - 12/2/2012 11:44 PM
Gray Beard
Score: 314
Status: offline
Looks home made.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to sparky4lawndart)
       Post #: 2
RE: where do i get this exhaust? - 12/3/2012 12:00 AM
goirish
Score: 305
Status: online
Look at these
http://www.centralhobbies.com/Exhaust/headers.html
DX-7,RDS8000. big Bingo,1/4 Scale Cub, SeaMaster 120, Forget the health food, I need all the preservatives I can get
Hide Signatures
(in reply to Gray Beard)
       Post #: 3
RE: where do i get this exhaust? - 12/3/2012 1:52 AM
sparky4lawndart
Score: 100
Status: offline
Holy smokes, that's expensive. That's more than I paid for the plane and the motor together... ouch
HAT823
Hatori 823 Rigid Cooling Header - for the Hatori 821 Muffler
$79.99
Hide Signatures
(in reply to goirish)
       Post #: 4
RE: where do i get this exhaust? - 12/3/2012 6:27 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
A little inflation. A lot of exchange rate.
Hide Signatures
       Post #: 5
RE: where do i get this exhaust? - 12/5/2012 3:47 AM
Gray Beard
Score: 314
Status: offline
Then you got yourself a real deal. Make sure you always save your broken headers, they are the main part to a do it yourself system.
Hide Signatures
(in reply to Four Stroker)
       Post #: 6
RE: where do i get this exhaust? - 12/5/2012 7:43 PM
Four Stroker
Score: 104
Status: offline
Get a tubing flare tool and fix the old one.
Hide Signatures
       Post #: 7
RE: where do i get this exhaust? - 12/5/2012 8:24 PM
sparky4lawndart
Score: 100
Status: offline
I did... it was $20 from Orielly auto parts... those tools are only rated for soft copper tubing/pipe: it didn' work... so the guy at home depot recommends a machine shop nearby and the guy wants $100 to do the work on his lathe. I put an ad on RCGroups and here and a guy actually had the header (the exact same 12 year old part from Central hobbies) in a box...
$45 shipped yesterday... If i get it.. I'll be a happy camper..
Hide Signatures
       Post #: 8
RE: where do i get this exhaust? - 12/14/2012 7:19 PM
sparky4lawndart
Score: 100
Status: offline
guys... found a guy that the had the original header from Central hobbies and got it for $40... I got it and found that the nut would run out of threads before securing the header in... I was looking for a machinist when someone suggested I find a washer... Central hobbies didn't have it so I went to home deport.. found the closest washer to 13mm and that looks like it's going to work...
I'm a little worried about the washer introducing extra restriction for exhaust flow but we'll see. wish me luck
Hide Signatures
       Post #: 9
RE: where do i get this exhaust? - 12/19/2012 5:47 AM
sparky4lawndart
Score: 100
Status: offline
the washer from Home Deport worked out... the new header was sealed but I ran into a new problem.. The motor is leaking like a sieve... (that's an exageration)
The YS F120 is installed in a Zen 120 pattern ship.. it is mounted in a dubro like anti vibration mount and inverted.. the header wraps around points down the centerline and underside of the fuse. There is a 12 inch gap between the pipe and the header... I tried PVC first, it melted in under 120 seconds... I tried PEX (super PVC) it lasted 180 seconds... Somewhere recommended exhaust silicon tubing for diesel engines.. tried it and it didn't melt but the vibration split the hose every flight (too expensive at $5 for 3 feet of hose).
I'm writing this not to complain about exhaust but about how much fuel leaves the motor unburned. it's alarming how much fuel is everywhere after a flight (in the cowl, the belly pan, etc). There is a screen affixed to the top of the carb (i don't know if that's original). I'm wondering if there is a bad seal somewhere but that doesn't make sense... this motor can run without a header on... this motor can run rich, lean, anything (i haven't tried it yet but I'm sure the motor would run even if an elephant pooped on it). plenty of compression... starts in 2 or 3 flips... I'm waiting for the plane to die so i can put this motor into a P51 to go really fast in...
anyway.. is it normal for this motor to leak so much fuel... I have a DLE 20 and you'd be hard pressed to find anyting outside that motor except flecks of oil on the cowl...
Hide Signatures
       Post #: 10
RE: where do i get this exhaust? - 12/20/2012 12:45 AM
petec
Score: 101
Last Login: 5/20/2013
Status: offline
Get teflon tubing from Central if they still ave it and forget the silicone tubing. The teflon lasts longer and the types you had used were never meant for high temps like exhaust.
As for the mess in the cowl, is it oil from the tubing splitting? If not I'd be looking for the cause as that is not exactly normal. A little oily mess is one thing but you are describing something more than that. The screen is aftermarket and just keeps big pieces of debris from being ingested.
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
       Post #: 11
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> where do i get this exhaust?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.607RCU1
