P38 build problem 90" wing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> P38 build problem 90" wing
Page: [1]
Login
P38 build problem 90" wing - 12/2/2012 11:10 PM
Airshow
Score: 100
Last Login: 1/20/2013
Status: offline
What little information that is given with the build plan's
it say to Epoxy the Elevator in place fine But how will you you be able to
brake it down for transport?
Do you Just take the wing off and make a removable support for the Fuselage?
Hit that in transit and you brake out the Elevator.
I maybe missing something here /
Any idea's "?
Ps tried to upload a pic but for some reason will not let me?
More problems that another story.
Hide Signatures
       Post #: 1
RE: P38 build problem 90 - 12/2/2012 11:22 PM
TFF
Score: 143
Last Login: 5/18/2013
Status: offline
You need to add some more info like what P38. I would guess it is not removable from what you say.
Hide Signatures
(in reply to Airshow)
       Post #: 2
RE: P38 build problem 90 - 12/2/2012 11:52 PM
Airshow
Score: 100
Status: offline
Sorry no name bought from General Hobby most likely China
got on sale for $145.could not pass it up as always to good to be true
But seems to be well constructed went over all epoxy and cover just in case
Hide Signatures
(in reply to TFF)
       Post #: 3
RE: P38 build problem 90 - 12/3/2012 12:03 AM
tschuy
Score: 111
Status: offline
It would seem to me that the solid design would keep the two booms, center wing section, fuselage, vertical and horizontal stabs all as one complete assembled unit. Then have the left and right wing panels removable so that the plane can be transported. otherwise its 5 complete assemblies that will need to be assembled at the field. Two booms, fuselage, wing and horizontal stab. a lot of assembly points that need careful consideration to include strong points for assembly and logical servo connections.Cheers,
_____________________________
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 4
RE: P38 build problem 90 - 12/3/2012 12:17 AM
Airshow
Score: 100
Status: offline
I agree But this main wing splits in the middle and screws and pinned there.
the two engine fuselage when I take the wing off
with the Elevator epoxied in place have no support at all they would just hang there .
thanks for your replay a
have a great day
Hide Signatures
(in reply to tschuy)
       Post #: 5
RE: P38 build problem 90 - 12/3/2012 12:54 AM
panhandler
Score: 100
Last Login: 5/17/2013
Status: offline
Hi Airshow
Is this the kit you are refering to ? The nitro 90"
Edit : http://www.generalhobby.com/lightning-twin-engine-warbird-plane-silver-p-230.html
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 6
RE: P38 build problem 90 - 12/3/2012 1:08 AM
Airshow
Score: 100
Status: offline
Yelp but in green got it last spring
the only thing I can come up with is there is just enough room just before the Rutter to put a plastic bolt but then
I would be worried about making the tail weak.
http://www.generalhobby.com/lightning-twin-engine-warbird-plane-green-p-231.html
Hide Signatures
(in reply to panhandler)
       Post #: 7
RE: P38 build problem 90 - 12/3/2012 3:47 AM
panhandler
Score: 100
Status: offline
This model proves very well with a three piece wing conversion. Take a look at Rams thread on his highly modified Nitro P-38 . His mod and along with all others  that have put there imput into this build are a world of knowledge.
http://www.rcuniverse.com/forum/m_6913969/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 8
RE: P38 build problem 90 - 12/3/2012 3:53 AM
A6TEXAN
Score: 100
Status: offline
hey Airshow, check this out.
http://www.rcuniverse.com/forum/m_6913969/tm.htm
very informative build. im sure all your questions will be addressed.
Hide Signatures
       Post #: 9
RE: P38 build problem 90 - 12/3/2012 12:29 PM
Airshow
Score: 100
Status: offline
Now thats what I had in mind But not the rack just the support across the Fuse
Thannks for the Pic
Hide Signatures
(in reply to A6TEXAN)
       Post #: 10
RE: P38 build problem 90 - 12/3/2012 12:38 PM
Airshow
Score: 100
Status: offline
Thanks That would be great but I am not so sure. I have not been doing mod on any planes only thing I have taken a chance on has been foamys build from dollor store foam
have been fylying my twinstar to get the feel and the old P51 I have had for some years this is my 1st big boy
so I have a ton of fear for now and trying to stay on target .
Fo me to do a conversion have to see if I can get some hands on help from the Club guys here for that one
Hide Signatures
       Post #: 11
RE: P38 build problem 90 - 12/3/2012 9:34 PM
JRMS
Score: 100
Status: offline
Hello Airshow,
I still have not finished my P-38.
It still sits as my build thread far from done.
The first thing I showed in the thread was how I supported the twin booms for transport.
http://www.rcuniverse.com/forum/m_9295912/mpage_1/key_/tm.htm
And as I had said before there is so much great stuff to learn from RAM3500's build thread of his P-38,
and check out his other threads, very informative.
Murray
Hide Signatures
       Post #: 12
RE: P38 build problem 90 - 12/3/2012 11:13 PM
obiwan12
Score: 100
Status: offline
What's a rutter?
Hide Signatures
(in reply to JRMS)
       Post #: 13
RE: P38 build problem 90 - 12/4/2012 2:40 AM
Airshow
Score: 100
Status: offline
A rudder turns the plane /boat left or right
I hope you get your plane build and flying .
They have a really great sound when they fly by.
Hide Signatures
(in reply to obiwan12)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
