Adjusting Savage X 4.6 Brakes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> Adjusting Savage X 4.6 Brakes
Page: [1]
Login
Adjusting Savage X 4.6 Brakes - 12/3/2012 2:25 AM
JohnP2
Score: 268
Last Login: 5/19/2013
Status: offline
I've noticed that the braking on my Savage X 4.6 have decreased with each run....to the point now I'd say there are "no brakes" on the it. I found this out the hard way during a speed run tonight (luckily the street was empty and I let the vehicle coast to a stop).
I understand how to adjust brakes/linkage on buggies, but the MT seems a little different. On initial glance, there seems to be two ways to adjust the brakes:
1. Adjust the plasting screw next to the spring (I know I should use fuel tubing, but there is a spring on for now).
2. The vertical arm on looks like it can be modified by dropping the arm down some and then re-tightening the screw.
Above all, I want to ensure I don't employ drag. However, at this point I have NO brakes on the Savage, and am curious if there is a simply way to adjust before I tear into it.
Thanks!
See attached pic.
Click to see fullsize image.
Click for fullsize
_____________________________
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
       Post #: 1
RE: Adjusting Savage X 4.6 Brakes - 12/3/2012 3:01 AM
steed2-inactive
Score: 166
Last Login: 12/18/2012
Status: offline
Lowering the arm will decrease leverage and decrease stopping power, but the will come on faster. Search the ofna linkage mod and do it, it will solve so many issues for you. If not, replace the spring with fuel tubing and adjust the brakes with the adjuster wheel on the end of the rod. Also the factory servo is quite weak.
oversteer scares passengers, understeer scares drivers!-savagex,-savagexl,-savageflux,-revo3.3,-tmaxx3.3,-losi aftershock lt
Hide Signatures
(in reply to JohnP2)
       Post #: 2
RE: Adjusting Savage X 4.6 Brakes - 12/3/2012 4:05 PM
JohnP2
Score: 268
Status: offline
quote:
ORIGINAL: steed2
Thanks for the replyI want to ensure I understand you here. By lowing the arm (right side of the picture) it will DECREASE stopping powe....but the brakes will be applied faster?
quote:
ORIGINAL: steed2
Thanks, I just checked this out and it looks very interesting indeed. Seems I'm not the only Savage owner with braking issues.
quote:
ORIGINAL: steed2
I think (in order) I will try the following:
1. Replace spring with fuel tube. How long? 2"???
2. Try the 'OFNA linkage' mod
3. Upgrade servo with more torque.
Thanks!
Hide Signatures
(in reply to steed2-inactive)
       Post #: 3
RE: Adjusting Savage X 4.6 Brakes - 12/3/2012 7:29 PM
steed2-inactive
Score: 166
Status: offline
If you do those three the truck will flip right over with ease...also you are running a rechargeable hump pack right? And by the way my savage brakes were horrible. I usually upgrade the steering servo and use the sf2 for throttle/brake
Hide Signatures
       Post #: 4
RE: Adjusting Savage X 4.6 Brakes - 12/3/2012 7:34 PM
steed2-inactive
Score: 166
Status: offline
Yes lowering it will have that effect, you lose leverage but gain movement when compared to the center of rotation.
Hide Signatures
       Post #: 5
RE: Adjusting Savage X 4.6 Brakes - 12/3/2012 8:46 PM
Ttowntoolman
Score: 159
Last Login: 5/16/2013
Status: offline
Double check to make sure the bolts that hold the breaks to the transmision have not come loose. When they come loose your adjustments will change and breaks fade.
Hide Signatures
       Post #: 6
RE: Adjusting Savage X 4.6 Brakes - 12/4/2012 2:53 AM
JohnP2
Score: 268
Status: offline
quote:
ORIGINAL: Ttowntoolman
Thanks, guys. One note: the three things I mentioned above I will do, is ONLY IF the first does not work. ;-) Thus I will first put the fuel tubing on...if that does not work, try the OFNA linkage....etc.
Quick question regarding switching the spring with tubing:
What is easiest method to remove the spring? Does adjustment screw come off......or should I remove the brake linkage from the servo horn?
I am curious how the truck has slowly lost it's ability to brake. As noted, it has pretty much NO braking ability at all. So much I can't run it. I am adept with working on buggies (I change/clean my break pads often), and have learned you don't "compensate" else you affect other parts....so it is important to understand the root cause. My biggest fear is putting pressure on the engine due to drag.
With that, Ttowntoolman (or anyone)....would you be kind enough to give me the part number of the bolts you are referencing? Do I need to remove the transmission, or can I access the bolts from under the truck?
Thanks!
Hide Signatures
(in reply to Ttowntoolman)
       Post #: 7
RE: Adjusting Savage X 4.6 Brakes - 12/4/2012 5:31 AM
Car-Tune
Score: 110
Last Login: 5/20/2013
Status: offline
They are not bolts, are screws
That's the problem here. The screws are getting loose on the pads. Lock tite will not fix the problem. Use a dab of tire glue to prevent this from happening over and over again.
Hide Signatures
       Post #: 8
RE: Adjusting Savage X 4.6 Brakes - 12/4/2012 6:19 PM
Ttowntoolman
Score: 159
Status: offline
Yea man just turn it over and look at the brake pad assembly on the outside of the transmission on the bottom. The two SCREWS that go through the assembly and hold it to the transmission are most likely loose. Should be Phillips heads...........
Hide Signatures
(in reply to Car-Tune)
       Post #: 9
RE: Adjusting Savage X 4.6 Brakes - 12/4/2012 6:23 PM
Ttowntoolman
Score: 159
Status: offline
OOPS fat fingers.....
Hide Signatures
       Post #: 10
RE: Adjusting Savage X 4.6 Brakes - 12/4/2012 7:37 PM
JohnP2
Score: 268
Status: offline
I believe you are referring to the step screw (part Z280).
See attached for clarificartion. However, these are adjustable and needed to take off for changing pads, so obviously don't want to locktite nor tire glue them.
If this is not it, I'll wait until I get hom to take a look at it.
Click for fullsize
Hide Signatures
       Post #: 11
RE: Adjusting Savage X 4.6 Brakes - 12/5/2012 12:56 PM
Ttowntoolman
Score: 159
Status: offline
Yep those are the ones. I check them when I feel a change in the braking.....
Hide Signatures
       Post #: 12
RE: Adjusting Savage X 4.6 Brakes - 12/5/2012 4:51 PM
JohnP2
Score: 268
Status: offline
Awesome. Thanks so much! I'll let you know the results. We are moving over the next few weeks (so don't have a lot of time to work on it), but do plan to do one final run of it for my neighbors prior to our last night here. ;-)
Hide Signatures
       Post #: 13
RE: Adjusting Savage X 4.6 Brakes - 12/6/2012 1:42 AM
JohnP2
Score: 268
Status: offline
I checked the screws on the calipers (by hand) and they were not loose. Instead of adjusting them (as I'm sure they are quite sensitive) I simply replaced the linkage spring with tubing and adjusted the thumb screw a little bit. I do like the fact I can guage the caliper play without removing the transmission, which makes it much easier to fine-tune.
Thanks for everyone's help.
Hide Signatures
       Post #: 14
RE: Adjusting Savage X 4.6 Brakes - 12/9/2012 10:19 PM
prnstr40
Score: 100
Last Login: 3/17/2013
Status: offline
On top of making the adjustmets noted above, I have also found that deglazing the rotors with a Dremel sanding drum works well.
Hide Signatures
       Post #: 15
RE: Adjusting Savage X 4.6 Brakes - 1/3/2013 3:30 AM
AIRSAVAGE
Score: 100
Last Login: 5/12/2013
Status: offline
I've been trying to get my brakes working better too. (I noticed the same thing that they have gotten worse recently). I've got a hitec 645mg for the break/throttle servo as well as a hump pack for the power. I just saw on the hpi web site that they have a Stainless steel break set for the savage. Has anyone tried this? Did it help?
E-Firestorm Flux, HPI WHeely King w/4WS, Blade mSR2, Savage X 4.6, Futaba 4PL
Hide Signatures
(in reply to prnstr40)
       Post #: 16
RE: Adjusting Savage X 4.6 Brakes - 1/3/2013 3:45 AM
Car-Tune
Score: 110
Status: offline
I didn't like them because the break pads tore and fell apart. I went back to using the stock again.
Hide Signatures
(in reply to AIRSAVAGE)
       Post #: 17
RE: Adjusting Savage X 4.6 Brakes - 1/3/2013 5:34 AM
rcnitrohead
Score: 157
Last Login: 3/4/2013
Status: offline
quote:
ORIGINAL: AIRSAVAGE
I've used every stock setup there is from the Savage 25 single fiber disk to the twin SS and finally the twin fiber discs. The single disk would always overheat and fade, after 5 gallons or so the disk partially melted and stripped on the hub. The SS brakes work well but as mentioned the fiber pads for the calipers tear apart, I went through about 3 sets of these over a course of about 5-6 gallons. The dual fiber disks have by far given the best performance and reliability, after about 5 gallons I'm just now starting to notice the outer disk crumbling. I can do endos on demand and when I let people drive my truck they always slam on the brakes and flip the truck.
A tip to make the fiber disks last longer is to apply CA glue around the circumference of the disks. To get the best performance and adjustability, you want the OFNA throttle mod. Its that much better than stock, I've been running mine for about 5 years and about 12 gallons and never any issues.
What can I say, I bash my truck hard! Go HPI!
HPI Savage 25
Hide Signatures
       Post #: 18
RE: Adjusting Savage X 4.6 Brakes - 1/3/2013 12:26 PM
Argess
Score: 151
Status: offline
I origninally installed a stronger steering servo and used the stock steering servo for the throttle/brakes which helped a bit. I also upgraded to the dual disc system which helped some more.
I also installed fuel tubing which helped even more, but not a lot. However, my braking always seemed to slowly fade during a bash session, and it seemed to be due to the batteries draining. I use 4 AA NiMH in the stock battery box.
This occurs because when you operate the brakes, considerable servo force (accompanied with rapid battery drain) is needed to overcome the override spring in the stock servo arm system.
I then bent the brake arm for better leverage, and it helped some more, but still not perfect:
Eventually, I did my own version of the OFNA throttle Mod using various bits I had in my junk box. I did have to lengthen the steering horn, but a longer one could easily have been bought cheap.
Hide Signatures
(in reply to rcnitrohead)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
