Thunder Tiger MT4 G3 (formerly AE SC10 RS, HPI Blitz, or something else?)
#51
Well, just ordered the Hype X7 Plus (80w) charger, plus 2x Nvision 4200 60C 3s Lipos, and an adaptor cable..
Yes, I've been reading, and have more to do. Kind of nervous about it.
Gonna go to the hardware store now and look at metal boxes...
#52
ORIGINAL: HerrSavage
However if one swells up bad or becomes a taco due to a massive crash, a steel metal box is a great way to hold it before you decide to dispose of it thoughtfully (aka blow it up in a parking lot)
<br type="_moz" />
#53
I read that the mt4 takes upto 138mm battery and the nvision are 142mm
Just a heads up.
#54
ORIGINAL: sparky 25
Will the nvision batteries fit the mt4 battery compartment?
Just a heads up.
Just a heads up.
<br type="_moz" />
#55
Hmm.. That makes me a bit nervous. Could be why I've not been able to find ANY info on them. They are the cheapest 3s hardcase batteries (with Deans) going, but nobody seems to have them... I assume I could just return them..
BTW, my first shipment arrived yesterday - the Y-cable ha ha.. Question: when you run two packs, what's with the balancer thingies on the lipos?
#56
The balance leads are only for charging and checking voltage,
When you install the batteries in an rc just tuck the balance lead in beside the battery.
#61
Will do, when the weather finally cooperates.. Still negotiating with the wife about when I can open it(%50 of it is my X-mas present)
Think I'll open it on the weekend, threadlock stuff, try to get my head around charging, setting whatever on the ESC, then hopefully run it on X-mas.. What exactly is the process for starters? What's the first thing to do with the lipos? I'm kind of scared of them ha ha.. I've been reading so much about volts, cutoff whatever, programming boards(what is that? Should I buy one?), etc.., I'm not sure where to start.
Also need to buy some lipo safety bags and maybe a big metal box this weekend..
Thanks for all your help btw.
#62
I've haven't heard of a programming board before, sounds like something that you will use to update software. Did you mean balance board? I believe that charger your getting has a balance board, which allows you to plug in those balance connectors so you can balance charge.
<br type="_moz" />
#63
<br type="_moz" />
It's going to be .... quiet
