Journalists using drones.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> AMA Discussions >> Journalists using drones.
Page: [1] 2 3 4   next >   >>
Login
Journalists using drones. - 12/3/2012 6:18 PM
Sport_Pilot
Score: 233
Last Login: 5/23/2013
Status: offline
Intresting article how drones will erode our privicy by their use by journalists.  A few things about this does not see quite right, but not sure where the regulations sit right now.
http://www.washingtontimes.com/news/2012/dec/2/inside-the-beltway-drones-for-journalists/
Seems drones are limited to 400 feet, but models are not?  If flying less than 400 feet and over property they would be trespassing.  Seems those writing this don't know this.  Wonder when the first big lawsuit is in the news.
_____________________________
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 1
RE: Journalists using drones. - 12/3/2012 7:43 PM
phlpsfrnk
Score: 101
Status: offline
quote:
ORIGINAL: Sport_Pilot
Where do you get it that models are not restricted?
Regards
Frank
It is not possible to write in such a way that cannot be misinterpreted by a reader determined to do so.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 2
RE: Journalists using drones. - 12/3/2012 8:01 PM
bogbeagle
Score: 148
Status: online
Here is the problem ... if that is the correct term.
Your image does not belong to you. It belongs to the person taking it.
Hide Signatures
(in reply to phlpsfrnk)
       Post #: 3
RE: Journalists using drones. - 12/3/2012 8:21 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: bogbeagle
But the model commited trespassing to take the picture.
Hide Signatures
(in reply to bogbeagle)
       Post #: 4
RE: Journalists using drones. - 12/3/2012 8:24 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: phlpsfrnk
www.washingtontimes.com="" href=""> http://www.washingtontimes.com/news/2012/dec/2/inside-the-beltway-drones-for-journalists/
Regards
Frank
Because the last law said models are not to be regulated.   Also before the newest law takes effect there is only an AC that does not have the effect of law, as it is only advisory.
Hide Signatures
       Post #: 5
RE: Journalists using drones. - 12/3/2012 8:35 PM
bogbeagle
Score: 148
Status: online
Not sure that a machine can commit any offence. If I take a picture of you as I walk past your house, can you prosecute my camera?
If my machine flies over your house and takes your picture ... where is the harm or loss?
You don't own the sky above your property ... so you don't have any exclusive right to its use, afaics.
Dunno about the US, but in the UK, trespass is not a criminal offence. You can't be arrested or prosecuted for trespass ... only for the damage that you cause. Most often, any such damage requires a civil remedy, rather than a criminal one.
Hide Signatures
       Post #: 6
RE: Journalists using drones. - 12/3/2012 8:43 PM
hugger-4641
Score: 229
Status: offline
In the U.S., tresspassing is a criminal offense. But for a private land owner, proving tresspass and getting it prosecuted can be very difficult depending on the area of the country you live in.  There is a process for getting a No-Fly-Zone established, but I'm not aware of it being used by individuals, usually this is done by large corporations trying to protect proprietary trade secrets.
Jerry
AMA -922698 Nomal people scare me, but not as much as I scare them...
Hide Signatures
       Post #: 7
RE: Journalists using drones. - 12/3/2012 8:59 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: bogbeagle
You would not be commiting trespassing as you did not cross the property boundry.  That boundry line extends up to the minimum altitude limits of the FAA.
Yes you do own the air above your property.  Do a search on AIR RIGHTS.
Hide Signatures
       Post #: 8
RE: Journalists using drones. - 12/3/2012 10:38 PM
bogbeagle
Score: 148
Status: online
I'll take your word for it.
It's different here.
Hide Signatures
       Post #: 9
RE: Journalists using drones. - 12/4/2012 11:04 AM
phlpsfrnk
Score: 101
Status: offline
quote:
ORIGINAL: bogbeagle
? Minimum altitude limits of the FAA? Where is it written that the FAA has "minimum altitude limits” when it comes to air traffic? With the exception of class A airspace FAA control starts at the surface and extends to FL 600.
Regards
Frank
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 10
RE: Journalists using drones. - 12/4/2012 12:27 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: phlpsfrnk
quote:
ORIGINAL: bogbeagle
Regards
Frank
The FAA has minimum altitude limits below which aircraft cannot fly.  Generally when not near an airport, it is 1000 feet over populated areas, and 500 feet from people or structures in non populated areas.  The only exceptions are emergencies and helicopter routes.
Hide Signatures
       Post #: 11
RE: Journalists using drones. - 12/4/2012 12:33 PM
bogbeagle
Score: 148
Status: online
Our 500 foot rule is just that. Imagine you are in a bubble of 500 foot radius.
You can fly right down to one millimetre from the surface, provided you stay 500 feet clear of people vessels or structures. You have to be both VFR and VMC, of course. Done it many hundreds of times.
Now, in reality, it is almost impossible to be sure that there isn't someone taking a pee behind a hedgerow ... and a fence is technically a structure (maybe) ... and someone could claim that you caused his horse to miscarry its foal ... but so long as you are acting reasonably, you won't get nicked. AFAIK.
With the permission of the land-owner, there is no barrier to your making a landing, either. (I'm talking non-commercial flights, here) But, even if you do land without permission, the worst you can be acccused of is trespass, with its attendant requirement that the property owner shows the harm or loss which he has suffered.
Your rules may differ.
< Message edited by bogbeagle -- 12/4/2012 1:04 PM >
Hide Signatures
       Post #: 12
RE: Journalists using drones. - 12/4/2012 2:06 PM
phlpsfrnk
Score: 101
Status: offline
quote:
ORIGINAL: bogbeagle
Acctually it is pretty much the same here; (bold added)
quote:
FAR Part 91
Sec. 91.119 — Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters, powered parachutes, and weight-shift-control aircraft. If the operation is conducted without hazard to persons or property on the surface—
(1) A helicopter may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section, provided each person operating the helicopter complies with any routes or altitudes specifically prescribed for helicopters by the FAA; and
(2) A powered parachute or weight-shift-control aircraft may be operated at less than the minimums prescribed in paragraph (c) of this section.
Not sure what Sport_Pilot is refering to.
Regards
Frank
Hide Signatures
       Post #: 13
RE: Journalists using drones. - 12/4/2012 2:47 PM
Sport_Pilot
Score: 233
Status: offline
I am refering to section 91.119 which limits the minimum altitude.  This defines the navigable airspace and the limits of property air rights as it pertains to overflying aircraft.  When you are flying a UAV below 400 feet you are, in most places, flying in non navigable airspace and thus trespassing the property you are overflying.
Hide Signatures
       Post #: 14
RE: Journalists using drones. - 12/4/2012 3:35 PM
phlpsfrnk
Score: 101
Status: offline
I quoted 91.119 in its entirty and I did not read it saying anything about it "defining the navigable airspace and the limits of property air rights as it pertains to overflying aircraft." It only talks to minimum safe altitudes. How does one fly (navigate) in "non navigable airspace"?
Regards
Frank
Hide Signatures
       Post #: 15
RE: Journalists using drones. - 12/4/2012 4:25 PM
littlecrankshaf
Score: 259
Status: offline
Probably when one is flown over a Texan's land and is shot down...Of course that would be of little newsworthiness since the story about shooting those that tried to retrieve the drone would completely eclipse that little story...
I think I've figured this forum out now...It really isn't about AMA or much of anything else...Just people that have some need to validate their existence based on some rule or lack of rule... and that philosophy is magnified and embraced if some entity or organization can be used to bolster their dependent position.
Argue on!
Wow! Another epiphany…that is why the suckups suckup. Super sucking protection power. Yea baby.
Hide Signatures
       Post #: 16
RE: Journalists using drones. - 12/4/2012 4:41 PM
jester_s1
Score: 233
Status: offline
I figured Texas would come up in this discussion at least once. Texas has the most property protecting laws of any state in the US. A landowner or renter in Texas is allowed to use deadly force if he finds someone on his property without permission no matter what they are doing. The origin of the law comes from when Texas had so many cattle ranches and rustlers were a major problem. Ranchers were given the right to shoot people inside their fences on sight to protect their cattle. The laws have stayed on the books so there's this odd little quirk of behavior here where if you're walking through a neighborhood you always stay on the sidewalks and don't hang around looking into someone's backyard or windows as you go.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to littlecrankshaf)
       Post #: 17
RE: Journalists using drones. - 12/4/2012 5:33 PM
Top_Gunn
Score: 134
Status: online
So if you see a little kid cutting across your back yard you can shoot him dead? Somehow, I doubt it. How about a cite to this supposed law?
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
(in reply to jester_s1)
       Post #: 18
RE: Journalists using drones. - 12/4/2012 5:54 PM
rgburrill
Score: 126
Status: offline
If the law is going to ingore these invasions of privacy then the law should also ignore the discharge of firearms shooting down these drones.
Hide Signatures
(in reply to Top_Gunn)
       Post #: 19
RE: Journalists using drones. - 12/4/2012 5:56 PM
rgburrill
Score: 126
Status: offline
quote:
ORIGINAL: Top_Gunn
Yup.  And his dad when he comes to get his kid!
Hide Signatures
       Post #: 20
RE: Journalists using drones. - 12/4/2012 5:59 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: phlpsfrnk
Regards
Frank
Because rulings on air rights have defined the air rights up to the limits of the FAA minimum altitude.  Especially for full scale aircraft.  Various state trespassing laws will sometimes describe overflights below minimum altitude as violating their trespasing law.
Hide Signatures
       Post #: 21
RE: Journalists using drones. - 12/4/2012 6:07 PM
eddieC
Score: 249
Last Login: 5/21/2013
Status: offline
SP, calling you out on this. Please stop posting based on supposition and a poor understanding of the regs. First, it's totally legal to operate aircraft below 500' above ground in sparsely inhabited areas as long as you're more than 500' from a person or structure and you pose no hazard. Buzzing a lake is one example. Having been a CFI over 30 years, I'm well acquainted with what is and isn't allowed.
You shot yourself in the foot over 'air rights', as it's more of a real estate/property development concern. Property owners have no claim on any airspace above their property beyond what they can 'reasonably use'.
From wikipedia: "The first legal limits placed on air rights came about because of the airplane. Eventually, owners only had rights to airspacethat they could reasonably use. It would be impractical for the development of air travel for individual landowners to own all the air above them, because airplanes would be constantlytrespassing."
I might not be very good, but I am fun to watch!
Hide Signatures
       Post #: 22
RE: Journalists using drones. - 12/4/2012 6:37 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: eddieC
Yes what you say is legal.  What I said is correct, I did not get into all of the specifics of the reg and left out some of this.  Note I said "generally".  But by the same token it is not legal to fly closer than 500 feet from a house.  And besides we are talking UAV's not full scale aircraftt.
From Wikipedia.
"At the same time, the law, and the Supreme Court, recognized that a landowner had property rights in the lower reaches of the airspace above their property. The law, in balancing the public interest in using the airspace for air navigation against the landowner's rights, declared that a landowner owns only so much of the airspace above their property as they may reasonably use in connection with their enjoyment of the underlying land. In other words, a person's real property ownership includes a reasonable amount of the airspace above the property. A landowner can't arbitrarily try to prevent aircraft from overflying their land by erecting "spite poles," for example. But, a landowner may make any legitimate use of their property that they want, even if it interferes with aircraft overflying the land."["
Hide Signatures
(in reply to eddieC)
       Post #: 23
RE: Journalists using drones. - 12/4/2012 8:43 PM
rgburrill
Score: 126
Status: offline
Contrary to popular opinion in this forum UAVs, hobby or not, are aircraft.  Certain types of hobby aircraft are exempted from the FAA regulations by law but only if they follow other regulations.  Just because you call it a hobby RC plane does not mean that you have full control over what you can do with it.  Specifically, you cannot use the exemption for any commerical purpose.  And taking pictures to sell rag magazines is a commercial purpose.  But hey, these people have never cared about confidentiallity, privacy, or even basic dignity so why should they care about legality.
Hide Signatures
       Post #: 24
RE: Journalists using drones. - 12/4/2012 8:49 PM
rgburrill
Score: 126
Status: offline
And this is why other laws and regulations exist.  A simple minded, one-sided interpretation of this says that if I won a large farm and my enjoyment of that farm includes flying RC planes from an airstrip on that farm and that my enjoyment further means I can fly as high as possible even up to the edge of space with an RC balloon so I can take pictures of my house from near space then I can do it!  Right?  Simple minded and one-sided!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
