turbine mounting    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> turbine mounting
Page: [1]
Login
turbine mounting - 12/4/2012 8:52 PM
DrYankum
Score: 100
Last Login: 5/22/2013
Status: offline
I'm mounting a K-80 in a used Avonds F16, and I dont have the installation manual, so my question is: what should be the gap between the exhaust cone of the turbine and the mouth of the steel exhaust tube be. On average, how big is the gap?
Jerry
Hide Signatures
       Post #: 1
RE: turbine mounting - 12/4/2012 10:03 PM
RCISFUN
Score: 105
Last Login: 5/26/2013
Status: offline
Google is your friend....
http://www.kingtechturbines.com/store/index.php?main_page=page&id=5
Click to see the file in new window.Attachment.pdf
_____________________________
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to DrYankum)
       Post #: 2
RE: turbine mounting - 12/4/2012 11:05 PM
DrYankum
Score: 100
Status: offline
Thanks for the reply and the download. I do have the manual for the K-80, but nowhere in it does it make reference to the required space between the end of the exhaust on the turbine and the mouth of the stainless tailpipe.
Anyone??
Hide Signatures
(in reply to RCISFUN)
       Post #: 3
RE: turbine mounting - 12/4/2012 11:15 PM
grbaker
Score: 115
Status: offline
Page 38 of the manual attached by RCISFUN
Gary Baker
Hide Signatures
       Post #: 4
RE: turbine mounting - 12/4/2012 11:50 PM
DrYankum
Score: 100
Status: offline
Aha....never thought to look at the specs page.
Hide Signatures
(in reply to grbaker)
       Post #: 5
RE: turbine mounting - 12/5/2012 1:04 AM
mtnflyer14
Score: 100
Status: offline
My K-80 manual on page 36 shows 20-30 mm.
Regards,
Gus
AW Extra 260/ZDZ Super 80; Elan/K-80; C-ARF Ultra Flash/P-120; YA F-15C/K-140
Hide Signatures
       Post #: 6
RE: turbine mounting - 12/5/2012 3:33 PM
RCISFUN
Score: 105
Status: offline
These are typical values for all manufactures
Jet Central Rabbit recommends 20 to 25 mm for example.
I was told that to find the ultimate position the manufactures adjust the pipe as described below.
(Disclaimer - WARNING this procedure could be dangerous and should not be attempted!)
Basically the pipe needs to centered and mounted so it can not loose its center position in relation to the tail cone, but can be slid fore and aft in relation to the tail cone (i.e. requires a fixture), you run the Turbine up and slide the pipe either away or towards the tail cone to find the neutral spot, it will either try to push the pipe away or pull the pipe closer, the neutral point is the ultimate position. I believe this is how manufactures come up with their recommendations so you don't need to perform this test yourself.
I am not personally recommending you try this, this is just for information only...
Rich
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.265RCU1
