Neutral position elevator SM F-4 Phantom!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Skygate CARF, Viperjet - RTF
Seller:  snobird
Details:   $9,600.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Neutral position elevator SM F-4 Phantom!
Page: [1]
Login
Neutral position elevator SM F-4 Phantom! - 12/5/2012 3:02 PM
pilot43
Score: 105
Last Login: 6/20/2013
Status: offline
Hello, friends!
Report please - where is found neutral position of the elevator beside F-4 Phantom from Skymasterjet?
In instructions on assembly of the models about this is not written.
_____________________________
Лётчик жив - полёт удался!
Hide Signatures
       Post #: 1
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 12:52 PM
757Driver
Score: 100
Last Login: 6/18/2013
Status: offline
Where is your CG? I can probably get you a picture Sunday. Hopfully someone will reply before then. There are alot of them flying. I have pics for the JL and as I remember they are very similar in position. That said they are vastly different airplanes. Lets get you a pic of the SM.
Thanks, Jason
I love it when my airplane is on fire...as long as the fire stays inside the engine!
Hide Signatures
(in reply to pilot43)
       Post #: 2
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 1:24 PM
DelGatoGrande
Score: 105
Status: offline
im sure you will find it somewhere here http://www.rcuniverse.com/forum/m_3160808/mpage_18/key_/tm.htm
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to 757Driver)
       Post #: 3
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 1:57 PM
f106jax
Score: 110
Status: offline
Pilot43,
Mine is 43mm below the horizontal panel line measured to the tip of the horizontal stab. My CG is 305mm behind the junction of the leading edge of the wing and the fuselage.
Mike
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 4
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 1:58 PM
yeahbaby
Score: 135
Status: offline
not the best pix but you should have an idea, there are 3 tick marks that are visible in the 2nd pix. the top was at cruise, the middle was at take off, the bottom was at landing.
I had my CG at 300mm and this is the large SM F4
it's a great flying jet and I look forward to getting another one..
good luck
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
"Audentes fortuna iuvat"
Hide Signatures
       Post #: 5
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 2:30 PM
AKB
Score: 100
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: yeahbaby
good luck
Buck you didn't lose yours did you?
Alan
High River RC Jet Club
MAAC Jet Committee member
Hide Signatures
(in reply to yeahbaby)
       Post #: 6
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 2:49 PM
yeahbaby
Score: 135
Status: offline
Hey Alan how ya doin? Merry XMAS
yup, I was a Delta Alpha and didn't do a good pre-flight after having sat the jet for an extended period of time. somehow I reversed ailerons while setting up another jet on the same radio...and while doing the control check....well.....I saw what I wanted to see instead of actually seeing the appropriate control deflection.
essentially dumb thumbed it into the ground on the best take off I ever had with that bird. a fleeting moment of....."I can fly this out" turned into just dumping it into the ground. no fire thankfully having shut down the motor prior to impact.
there is another one in my future. all the internals were fine, tanks, gear, tail pipe etc.
How's your F4 doing? enjoying it I see from 400'?? whew that's tight and ballzy!
cheers
Hide Signatures
(in reply to AKB)
       Post #: 7
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 4:28 PM
pilot43
Score: 105
Status: offline
 Many thanks all!
I have found here is this subjects http://www.rcuniverse.com/forum/m_3160808/mpage_31/key_/tm.htm  There all answers to my questions.
I build the Phantom. This is a first Phantom in Russia and I need the advices and help.
Hide Signatures
(in reply to f106jax)
       Post #: 8
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 4:37 PM
757Driver
Score: 100
Status: offline
Best of luck! She will pitch down a little with full flap. Easily handled with some trim. Stay on power until touchdown as she's a dirty bird and will slow/drop as soon as power is reduced.
Your gonna love it!
Thanks, Jason
Hide Signatures
       Post #: 9
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 4:44 PM
yeahbaby
Score: 135
Status: offline
+1
great airplane and you found an informative thread with tons of helpful hints / tips etc.
it's a no brainer airplane to fly.....just remember if you find yourself gear down / flaps full etc on downwind and you're not in the vicinity of 1/3 throttle you gotta ask yourself...why? LOL
the beautiful thing with this bird if she gets slow is that it just develops a high sink rate....like a turd dropping on a flat rock from a tall moose.
enjoy
quote:
ORIGINAL: 757Driver
Your gonna love it!
Hide Signatures
       Post #: 10
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 4:57 PM
pilot43
Score: 105
Status: offline
Thank you, gentlemans.
He will fly as present fighter :-) We respect Phantom, this best plane :-)
Hide Signatures
       Post #: 11
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 4:59 PM
AKB
Score: 100
Status: offline
quote:
ORIGINAL: yeahbaby
essentially dumb thumbed it into the ground on the best take off I ever had with that bird. a fleeting moment of.....''I can fly this out'' turned into just dumping it into the ground. no fire thankfully having shut down the motor prior to impact.
cheers
Hi Buck
Yes Merry Christmas to you too. Being a Canadian I got involved with a Snowbirds Tutor the last while, so I have been having adventures with it.
The F-4 took a back seat for a little while. But I decided this year it will be finished and flying for 2013. I did get some motivation from Dave Phillips flying his at Whidbey Island when he was there in 2010. Also when I was at the Jet Masters in Dayton, I also talked and watched Andy Andrews flying his flying very well too. So I think 2013 will be it's year.
So sorry to hear about your accident. As your testament says, it happens to the best. I hope you get replaced soon and that the skies will be in fear of the big Rhino again. Maybe talk to you again when I get close. Still have kept all the PM's and emails you wrote me with your good guidance.
Talk to you soon Buck and have a good 2013.
Alan
Hide Signatures
       Post #: 12
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 5:09 PM
AKB
Score: 100
Status: offline
quote:
ORIGINAL: yeahbaby
cheers
Hide Signatures
       Post #: 13
RE: Neutral position elevator SM F-4 Phantom! - 12/7/2012 5:42 PM
yeahbaby
Score: 135
Status: offline
cheers mate
here's some motivation for both of ya!!!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AKB)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
