to use smartfly or not    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> to use smartfly or not
Page: [1]
Login
to use smartfly or not - 12/5/2012 4:50 PM
gobigorgohome
Score: 100
Last Login: 4/18/2013
Status: offline
Ok guys i have never used a smartfly regulator before and have had 6 differrent 50cc aircraft. I now have a 33% hanger 9 sukhoi. Do i have to use one or can i keep doing the same setup i have always done in the 30% just using the rx, batteries and switches.
Pro's and con's either way would be helpful. How do you have them setup.
Hide Signatures
       Post #: 1
RE: to use smartfly or not - 12/5/2012 4:54 PM
Tony Hallo
Score: 141
Last Login: 6/19/2013
Status: offline
Are you talking about a regulator or the power distribution system?  Not one in the same.
_____________________________
Tony Hallo
Hide Signatures
(in reply to gobigorgohome)
       Post #: 2
RE: to use smartfly or not - 12/5/2012 5:21 PM
gobigorgohome
Score: 100
Status: offline
The regulator. I am just wondering if this is a must need thing or can you still just use the rx. I havent used regulators or distributers. I'm just wondering what i can or should be doing with my setup. The servos i will be using are out of one of my 50cc aircrat where i had used a 6v 2200 nimh on rx and 1400 nicad on the engine.
Hide Signatures
(in reply to Tony Hallo)
       Post #: 3
RE: to use smartfly or not - 12/5/2012 5:34 PM
phantomdriver
Score: 100
Last Login: 6/15/2013
Status: offline
I've used relion batteries & smartfly system for reliebility in all my 30% and larger scale. Never had a issue with any of my planes.
There is alot of different setups as there is colors just my setups have always worked very well for me.....
Hide Signatures
       Post #: 4
RE: to use smartfly or not - 12/6/2012 3:32 PM
Zeeb
Score: 111
Last Login: 6/20/2013
Status: offline
Okay you're quite possibly asking for trouble on a 33% size model vs. what's worked for you on a 50cc size gasser. Specifically the use of NiMH batteries can be problematic depending on size and IR ratings of the cells and just off hand I don't recall seeing any 2200mah NiMH cells I'd trust to a 33% size model.
As for what else you might need depends on your radio setup and whether or not it can handle the four wing servo matching? Some rx's have an electrical buss capable of handling the model, some don't, some electrical switches when setup correctly will do fine some won't.
As mentioned, there are lots of ways to do a 33% size power system but you WILL need more capability than your 50cc stuff is using.
Zeeb
Hide Signatures
(in reply to phantomdriver)
       Post #: 5
RE: to use smartfly or not - 12/6/2012 4:47 PM
gobigorgohome
Score: 100
Status: offline
Ok - so i am listening and appreciating what is being said. So what do i need to do then. As i have said i have not used a setup like this before. Is there certain things ( which smartfly - what batteries i can use ) that will help me out. I fly with a futaba 9c 2.4 and am using a faast 617 receiver.
Thanks to those who have responded so far.
On the sukhoi it only has one servo per wing - there are two for the elevator and one for the rudder. The jr 8711's are what is being used.
Hide Signatures
(in reply to Zeeb)
       Post #: 6
RE: to use smartfly or not - 12/6/2012 5:03 PM
DadsToysBG
Score: 125
Status: offline
the best battery is A123's 6>6v no need for a regulator. the jr 78711's can draw high amps. when called for. With the Smartfly you get 6.6 to the servos bypassing the receiver. No voltage drop. the smartfly also uses a "dead mans switch" no current goes thru the switch. Use as few connectors as you can. I solder my servos to the extensions, only using one plug at the Smartfly. the smartfly delivers 5v to the receiver and 6.6v from the panel to the servos. Iuse 20ga. wire thru out the plane. Dennis
DadstoysRC. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 7
RE: to use smartfly or not - 12/6/2012 6:20 PM
gobigorgohome
Score: 100
Status: offline
So what smart fly product are you using then?
Hide Signatures
(in reply to DadsToysBG)
       Post #: 8
RE: to use smartfly or not - 12/6/2012 6:52 PM
DadsToysBG
Score: 125
Status: offline
The SmartFly Pro. Dennis
Hide Signatures
       Post #: 9
RE: to use smartfly or not - 12/6/2012 7:06 PM
gobigorgohome
Score: 100
Status: offline
Is that the power expander?
Hide Signatures
       Post #: 10
RE: to use smartfly or not - 12/6/2012 7:13 PM
DadsToysBG
Score: 125
Status: offline
He calls it a power distribution unit. Dennis
Hide Signatures
       Post #: 11
RE: to use smartfly or not - 12/6/2012 7:19 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: gobigorgohome
Given this, I wouldn't worry about a power expander. I'd run dual A123 batteries, each through an individual switch, to different ports on the reciever.
Thats essentially a 50cc setup servo wise.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 12
RE: to use smartfly or not - 12/8/2012 4:41 AM
snuts
Score: 100
Last Login: 6/18/2013
Status: offline
I to have the same airframe. As Andy has suggested Parallel A123 packs as a minimum. Also similar to my 50cc airframes. see link.
http://www.hangtimes.com/parallel_packs.html
I picture the real question as being. When are you going to start using distribution systems, then regs. If that is the case, yes you are at that point, and these will work well. By your handle, your only going to get bigger, (ha-ha).
Hope this helps, it really comes down to you. But, yes at 33% you can justify upgrading your power distribution.
-Snuts-
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 13
RE: to use smartfly or not - 12/8/2012 10:15 PM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
Is that the flying field in Camrose Alberta ??
Gotta come visit !
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to snuts)
       Post #: 14
RE: to use smartfly or not - 12/9/2012 6:30 PM
snuts
Score: 100
Status: offline
No, Elk Point Alberta. Travel Alberta lables it in there information as the "Best Model Airplane Feild in Alberta" We attend both of there 3+ day events each summer.
Now back to our regularly schedulede thread!
-Snuts-
(P.M. on it's way)
Hide Signatures
(in reply to Flyer88)
       Post #: 15
RE: to use smartfly or not - 12/10/2012 6:15 PM
gobigorgohome
Score: 100
Status: offline
So maybe this is a dumb question but why into seperate slots on the rx. Why couldn't you go y harness into one slot and if one battery fails the other on is still there.
Hide Signatures
(in reply to snuts)
       Post #: 16
RE: to use smartfly or not - 12/10/2012 6:45 PM
BarracudaHockey
Score: 280
Status: offline
You can if you need to.
But if you have an open port it eliminates a Y harness.
www.JaxRC.com
Hide Signatures
       Post #: 17
RE: to use smartfly or not - 12/10/2012 7:11 PM
600Bob
Score: 100
Status: offline
Redundancy, with a Y you have two batteries hooked to one pair of pins on the RX.  I have two RX batteries, one goes to the Batt. channel the other goes to a Y on an aileron channel.
Hide Signatures
       Post #: 18
RE: to use smartfly or not - 12/26/2012 12:52 AM
snuts
Score: 100
Status: offline
Never choke ALL your current draw through a Y harness. This is your weak link, and definatly the point to fail. Not a redundant system. A redundant system will have power if the other side ever becomes open momentarily. If you run out of ports on your receiver then back-feed through a Y harness on any channel, such as the throtle, rudder etc.
Often used as a link for clarity. Crazy good amount of information here.
-Snuts-
Hide Signatures
(in reply to 600Bob)
       Post #: 19
RE: to use smartfly or not - 12/26/2012 2:09 AM
telejojo
Score: 130
Last Login: 6/4/2013
Status: offline
I use the Smartfly power expander on all my big planes,you can use 2 bats. and you won't have to use y's you get 2 ports per channel.
Hide Signatures
(in reply to snuts)
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
