RE: back to c/l diesel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> RE: back to c/l diesel
Page: <<   < prev  1 [2]
Login
RE: back to c/l diesel - 12/7/2012 4:02 PM
AMB
Last Login: 5/18/2013
Status: offline
GREGGLES the pix are great this will really help when I get working on mine as a stock build it leaves a little to be desired . great mods and really needed martin
Hide Signatures
(in reply to greggles47)
       Post #: 26
RE: back to c/l diesel - 12/7/2012 6:56 PM
PWF63
Last Login: 5/15/2013
Status: offline
What flying weight did it come in at Ray?
For the record Ray and Greg
My Swee Pea turned out to be a heap of excrement. Not only was it too heavy at 600gms flying weight.
I ended up flying it with my Blue Head MVVS making the model nose heavy after ballancing just right with the CS Olly.
The day was too windy and model slammed into the deck after 6 laps.
I suspect the V tail wasn't lined up correctly either.
Back to the drawing board. No, I'm not normal, still going to do things different.
Looking at building one of the current IF1 Wilson wing Cassutts.
Fredo
Hide Signatures
(in reply to qazimoto)
       Post #: 27
RE: back to c/l diesel - 12/7/2012 10:31 PM
qazimoto
Status: offline
quote:
ORIGINAL: PWF63
Fredo
I never weigh 'em Fred, it usually depresses me when I do.
I built a Sweet-pea as well also with disappointing results. It was very unstable in the Kuringai wind, perhaps a consequence of the Vee type tail as well..
The Shoestring and the Ohm Special are two reliable model designs. There's a few Ohms with the MVVS in the Mannering Point club that fly well. I can supply scans if you want.
Ray
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to PWF63)
       Post #: 28
RE: back to c/l diesel - 12/7/2012 11:01 PM
AMB
Status: offline
Gazimoto first V tail I am aware of, the elevator only using half of it to me seems odd, in up mode seems looks it would have an aileron effect and cause the the plane to slacken the lines, just my theory, maybe no adverse effect martin
airflow direction not the same (equal) on both sides
Hide Signatures
       Post #: 29
RE: back to c/l diesel - 12/8/2012 12:34 AM
qazimoto
Status: offline
quote:
ORIGINAL: AMB
Martin,
the half elevator idea is quite common with control line racers, but they're usually on the "outside" of the model.
This Vee-tail has a dihedral angle of just 20 degrees, much less than with an r/c model so it should be ok. Takeoffs had good line tension it just couldn't cope with the gusty wind at our favorite flying site.
It's located on a ridge overlooking the Pacific Ocean and surrounded by tall trees, so it's more exposed than normal.
Ray
Hide Signatures
(in reply to AMB)
       Post #: 30
RE: back to c/l diesel - 12/8/2012 9:51 AM
PWF63
Status: offline
Here's Swee Pea with CS Oliver still on the bench. No need to see after photos....lol
We'll just remember this one.
Click for fullsize
Hide Signatures
       Post #: 31
RE: back to c/l diesel - 12/8/2012 11:20 AM
greggles47
Status: offline
quote:
ORIGINAL: PWF63
Fredo
Fred,
My first GY model was a Cassutt (Plum Crazy). Nother nice flier.
Can you please explain IF1? I haven't heard that.
Greg
Hide Signatures
(in reply to PWF63)
       Post #: 32
RE: back to c/l diesel - 12/8/2012 6:48 PM
PWF63
Status: offline
quote:
ORIGINAL: greggles47
quote:
ORIGINAL: PWF63
Fredo
Fred,
Greg
International Formula One
Sorry mate, I've had my head stuck in the  IF1 and Cassutt owners forums as well as the Reno web sites for too long.
Trying to research the modern modified Cassutts that have raced at Reno the last 10 years.
Some of the jargon has stuck.
Fred
Hide Signatures
       Post #: 33
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> RE: back to c/l diesel
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
