What carb can I use for a Magnum .28?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> What carb can I use for a Magnum .28?
Page: [1]
Login
What carb can I use for a Magnum .28? - 12/5/2012 10:41 PM
xray328
Score: 100
Last Login: 1/12/2013
Status: offline
Hey guys, I have a Magnum .28 that's running terrible. I tried rebuilding the carb, but it's still not there. Besides the factory replacement are there any other (cheaper) carbs I can use to replace it?
Thanks!
Hide Signatures
       Post #: 1
RE: What carb can I use for a Magnum .28? - 12/5/2012 11:28 PM
big max 1935
Score: 100
Last Login: 5/25/2013
Status: offline
I have good luck with a Perry carb. Just be sure to use a filter in the line from the tank to the carb, they don't like dirt & junk. Max H.
Hide Signatures
(in reply to xray328)
       Post #: 2
RE: What carb can I use for a Magnum .28? - 12/6/2012 12:37 AM
speedracerntrixie
Score: 189
Status: online
Just what is the engine doing or not doing? As long as the original carb is clean, changing to a different brand will usually not fix anything?
Hide Signatures
       Post #: 3
RE: What carb can I use for a Magnum .28? - 12/6/2012 2:58 AM
xray328
Score: 100
Status: offline
I boiled the carb in soapy water to get it to free up...maybe a big mistake? Anyway when I was putting it back together the barrel would only slide halfway in. I had to sand it to get it to fit. Which it does, but then the needles didn't line up, maybe they got bent during the barrel issue. Anyway, it starts and idles but one I get to half throttle that's all I get. Opening it up more doesn't do anything and if I go wide open it dies. I went from one and a half turns on the high speed screw to as far as 4 turns open, to the point oil was dripping from the muffler with no improvement. A way, at this point I think a new carb is in order.
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 4
RE: What carb can I use for a Magnum .28? - 12/6/2012 3:12 AM
speedracerntrixie
Score: 189
Status: online
Well It sounds like it's working. You say you get an idle and it's obviously transitioning because you do get to full throttle and are able to richen it up enough to get excess fuel out the muffler. I think you are having other issues. Answer these questions correctly and we may discover something.
What fuel?    Nitro content, oil content, what type of oil.
What plug?   Brand and model number
How old is the fuel?    Has it been kept in an air tight container?
Do the bearings feel smooth? is there a " Turbo " sort of sound while running the engine? Does it leak fuel around the prop drive washer?
Hide Signatures
       Post #: 5
RE: What carb can I use for a Magnum .28? - 12/6/2012 4:10 AM
xray328
Score: 100
Status: offline
Well, I get to full throttle, but theres no power increase from half throttle on up and if I keep it there it dies like its lean, regardless of high speed needle setting. It just goes from half to wide open with no power increase, then suddenly dies after 5-8 seconds.
Cool Power 15%
A3 Plug
Brand New Jug of Fuel
Bearings do in fact feel smooth.
Engine ran fine the last time I had it running.
Hide Signatures
       Post #: 6
RE: What carb can I use for a Magnum .28? - 12/6/2012 3:20 PM
Gray Beard
Score: 314
Last Login: 5/26/2013
Status: offline
Probably the cheapest carb you are going to find for it is an original Magnum, replacing carbs can run into more trouble and usually cost more.
Food for thought, a part is in something working just fine, makes no difference what. A person removes that part for some reason, when they try to replace the part it no longer fits?It now requires sanding, grinding, cutting to make it fit? Did the part expand or grow longer or could there be another reason? Perhaps reassembly is incorrect or perhaps a piece of something isn't allowing it to go in correctly.
The parts in a something are machined to have very close fits so things like extra air don't get past them, sanding a part to fit after rebuilding or repairing may have caused a problem.
Check with Magnum to see how much a new carb will cost, if you get one don't take it apart.
_____________________________
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
