Fuel feed issue    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> Fuel feed issue
Page: [1]
Login
Fuel feed issue - 12/6/2012 2:42 AM
AMB
Score: 110
Last Login: 5/19/2013
Status: online
As you know getting my old minnie telemaster ready to go, put on outside table, had the TT10 Davis head, ran like a dream, next day decided to do a re check before flying engine starts on prime and dies.checked tank and lines (3) engine feed, fill line, that gets a plug and muffler pressure line that has a one way pressure fitting, swapped engines put in the OS 10 same issue. fuel feed fine put in cap on fill line, same issue, I pulled the muffler pressure line and tried to blow thru it no go almost no air got through it. turns out off course blocked with no air or exhaust pressure to tank impossible to draw fuel, pulled the one way pressure fitting off then connected line to tank and all is well martin
I was ready to pull tank and replace but no need now martin
no air in no fuel out (unless bladder of course)
Hide Signatures
       Post #: 1
RE: Fuel feed issue - 12/6/2012 10:33 AM
DerFly
Score: 100
Status: offline
Hi there,
Just wondering why one would use a one way valve in the pressure line anyway.
Just about guarantees an overly rich mixture when throttling back from full loud to idle.
YS uses pressurised tank but also fuel pressure regulator!
DF
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: Fuel feed issue - 12/6/2012 1:45 PM
Hobbsy
Score: 650
Status: online
Exactly, a check valve in the exhaust requires a regulator, a check valve in the fuel line serves no purpose other than causing a problem.
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to DerFly)
       Post #: 3
RE: Fuel feed issue - 12/6/2012 2:26 PM
AMB
Score: 110
Status: online
THX guys it was of course ,now history, ( removed) a classic case of overkill that went awary martin
Hide Signatures
(in reply to Hobbsy)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> Fuel feed issue
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
