Battery eliminating circuit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> Battery eliminating circuit
Page: [1]
Login
Battery eliminating circuit - 12/6/2012 3:35 AM
acerc
Score: 221
Last Login: 6/18/2013
Status: online
I figure this is a good place to ask this question. I want to go from two NiMh batteries to one LiFe. Would a 5v output bec placed between the battery and the ignition be the right way to go? Don't want to fry the ignition's.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 1
RE: Battery eliminating circuit - 12/6/2012 5:34 AM
nitro wing
Score: 125
Status: offline
what motor and ignition?
Hide Signatures
(in reply to acerc)
       Post #: 2
RE: Battery eliminating circuit - 12/6/2012 11:03 AM
Tony Hallo
Score: 141
Status: offline
I am currently using a Hobby King 5 amp BEC on my receiver battery for ignition power.  The only draw back is it must be unplugged after the end of the day, it draws about 100ma with the ignition off.  Call me crazy but it works.  Two years ago I would never considered this.  Here's my current setup;
Two Troy Built  2600 ma li-poly batteries
Smart Fly Regulator set at 5.9 volt
Hobby King 5V BEC ignition regulator plugged into one of flight pack charge plugs
D&B 5.1 twin engine - Has resistor sprark plug wires, not shielded
FrSky 2.4 receiver 8 channel
Smart Fly Ignition cutoff
Homemade power distribution board with 4.7 mf capacitor filter
7 Hitec 7555 servos
Tony Hallo
Hide Signatures
(in reply to nitro wing)
       Post #: 3
RE: Battery eliminating circuit - 12/6/2012 12:59 PM
karolh
Score: 315
Status: online
How long have you been using your FrSky 2.4 system. Is it the telemetry capable version and how do you rate it's performance.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to Tony Hallo)
       Post #: 4
RE: Battery eliminating circuit - 12/6/2012 3:17 PM
BarracudaHockey
Score: 280
Status: offline
Get a dual output A123 and run a diode drop down on the lead to the ignition.
No need for an IBEC.
wrongwayrc.com sells what you need.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to karolh)
       Post #: 5
RE: Battery eliminating circuit - 12/6/2012 3:29 PM
acerc
Score: 221
Status: online
The LiFe I bought has dual output's. Would be glad to do the diode, had one berore for something else, but don't know what size diode to go.
Robert
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 6
RE: Battery eliminating circuit - 12/6/2012 4:46 PM
Tony Hallo
Score: 141
Status: offline
quote:
ORIGINAL: karolh
Karol
Two seasons, two planes, does have telemerty, no problems to report, good range, no resets or brown outs, no failures.  How else might one rate the system?  It is cheap and works.  I have the module installed in a Futaba 9C, considering upgrading the telemetry.
Tony Hallo
Hide Signatures
       Post #: 7
RE: Battery eliminating circuit - 12/6/2012 6:06 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: acerc
Not sure on the specs of the diode though I'm sure with some searching you could find it.
I use these, last on the page.
http://www.shop.kavarootusa.com/category.sc?categoryId=10
www.JaxRC.com
Hide Signatures
(in reply to acerc)
       Post #: 8
RE: Battery eliminating circuit - 12/6/2012 8:09 PM
acerc
Score: 221
Status: online
Thank's Andy. In my search on this thing I have talked to several people as well as posted question's. Just got done talking with a local fella that deals with large scale. He recommended I go with a Tech-Aero Ultra. It not only regulates the current but also fuctions as a kill switch. Two birds with one stone. Not that I'm a big fan of Tx kill switches but, WTH, choke switch or kill switch either way I'm flipping a switch.
Well see!
Robert
Hide Signatures
       Post #: 9
RE: Battery eliminating circuit - 12/6/2012 8:47 PM
acerc
Score: 221
Status: online
In regards to the A123's the US manufacturer, A123 Systems,  is no longer selling them. According to their website.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 10
RE: Battery eliminating circuit - 12/6/2012 9:04 PM
BarracudaHockey
Score: 280
Status: offline
They are no longer selling packs to end users. They are supplying cells in bulk to places like Wrongway, Tail Dragger, and others that sell A123 packs.
www.JaxRC.com
Hide Signatures
(in reply to acerc)
       Post #: 11
RE: Battery eliminating circuit - 12/6/2012 9:23 PM
acerc
Score: 221
Status: online
Did a little more research and it's only the US that is no longer producing. They have four other plants, Germany, Korea, and 2 in China
Robert
Hide Signatures
       Post #: 12
RE: Battery eliminating circuit - 12/6/2012 9:57 PM
abelard
Score: 100
Last Login: 6/17/2013
Status: offline
According to this, the US affiliate is bankrupt and up for sale:
http://www.xconomy.com/boston/2012/12/06/a123-goes-on-the-auction-block-heres-how-it-got-this-bad/?single_page=true
Hide Signatures
(in reply to acerc)
       Post #: 13
RE: Battery eliminating circuit - 12/6/2012 9:58 PM
eddieC
Score: 249
Status: offline
Johnson Controls bought A123's US operations. They'll be around for a while.
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to acerc)
       Post #: 14
RE: Battery eliminating circuit - 12/6/2012 10:19 PM
acerc
Score: 221
Status: online
Just got an E-mail back from Wrongway. According to them, Richard,  they have plenty for now. He also said he does not know how their, A123 System,  bankrupcy will effect them
Robert
Hide Signatures
(in reply to eddieC)
       Post #: 15
RE: Battery eliminating circuit - 12/6/2012 11:14 PM
BarracudaHockey
Score: 280
Status: offline
As was said, the production of the consumer use cells (tools, us, military etc) have been and appear to continue to be unaffected.
www.JaxRC.com
Hide Signatures
(in reply to acerc)
       Post #: 16
RE: Battery eliminating circuit - 12/7/2012 1:42 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: acerc
Well see!
The Tech Aero unit is the only one I would consider. It has several important features; the most important ones are invisible dealing with signal filtering. RFI just doesn't get past the filters. As a safety remote arming switch (I use my retract switch on the TX) it serves just fine. With its built in V reg you may have 6 1/2 or 7 volts in but you set the output to 5 V to the CDI...Plus, at 40$ it's inexpensive
Regards,
MattK
Hide Signatures
(in reply to acerc)
       Post #: 17
RE: Battery eliminating circuit - 12/7/2012 2:12 AM
Truckracer
Score: 309
Status: offline
Ace, like you I never cared much for the ignition cut-off circuits. Recently though, I decided to try the Tech-Aero IBEC. So far it works great and I certainly like the idea of one less battery. I might be a convert!
Hide Signatures
(in reply to acerc)
       Post #: 18
RE: Battery eliminating circuit - 12/7/2012 2:23 AM
acerc
Score: 221
Status: online
Happy to hear Truckracer. I have never been a fan of electronic cut-offs either. But?
Andy I'm just repeating what was told to me, don't know anything anything for sure.  Either way there are A123's available. I have already purchased the LiFe battery anyway and ordered the Techaero IBEC.
Robert
Hide Signatures
(in reply to Truckracer)
       Post #: 19
RE: Battery eliminating circuit - 12/7/2012 6:19 AM
drac1
Score: 100
Status: offline
The Tech Aero IBEC is the best option. I've been using them on my YS cdi's and 100cc gassers with no problems what soever.
< Message edited by drac1 -- 12/7/2012 1:30 PM >
There is no such thing as too much power.
Hide Signatures
(in reply to acerc)
       Post #: 20
RE: Battery eliminating circuit - 12/7/2012 1:18 PM
ahicks
Score: 669
Status: offline
I use 2 leads from the single A123 battery pack as well. Those lead to 2 switches. From there, one goes to the receiver, the second to a Y in the rudder line. The second lead that goes to the Y will supply the largest servo (or the one that's likely stressed the most), and demanding the most power. That power is also capable of backing up through the receiver to help out anywhere else it's needed - and is also capable of supplying the entire system in case of a switch failure on the other line? This gives a lot of the redundancy a dual battery pack setup may give you.
There's nothing wrong with the Ultra IBEC, but the Rcexl opti switch with a diode can do the same thing for about half of what those cost. Commonly available for 20.00 or less. There are a TON of them in use. One source would be Wrongway, he's a distributor for Rcexl, and that's what he gets for them. VV has them as well....
The diode is placed in the output leg of the switch (leading to the ign. module). The diode you're after is 1N4007, available in 5 packs from Radio Shack for about 5.00. The only thing that makes that diode special is that they're easy to find, they'll drop the voltage enough for our purposes, and they can handle any load placed on them by the ign. module. Wrongway also has these available in a short extension all wrapped up pretty and ready to go at a pretty reasonably price as well.
Nothing wrong with the other sources listed, but additionally, A123 cells are available from a guy here in the Midwest to allow you to build your own packs. Good guy, easy to talk with, fair prices. -Al
http://www.voltmanbatteries.com/servlet/the-LITHIUM-dsh-ION-CELLS/Categories
Hide Signatures
(in reply to drac1)
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.094RCU1
