3W60 won't start    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> 3W60 won't start Page: [1]
Login
3W60 won't start - 12/6/2012 2:45 PM
Moggy
Score: 100
Last Login: 5/27/2013
Status: offline
Hi Guys, I have a 3W60 that's been lying around waiting for me to finish my YA Spit. Went to bench run it and it won't start (My arm is killing me LOL). I rebuilt the carb last year and made sure everything was in the right place. I also made sure it was pumping frm the tank to the carb and the carb was good and wet. It fired off the prime and then wouldn't start. Somewhere I read there is a safety feature in the ignition which BTW is an older 4.8 V. I also replaced the plug with a new one just to try to eliminate obvious things. Any help would be appreciated. The plane is ready so I would like to install the engine knowing it will start. Thanks in advance. Oh ya, there is a reed on 3W but I'm not sure if they go bad over time without being used.
_____________________________
Piece of Cake
Spitfire Brotherhood #121
Hide Signatures
       Post #: 1
RE: 3W60 won't start - 12/6/2012 3:11 PM
BarracudaHockey
Score: 280
Last Login: 6/18/2013
Status: offline
Fuel or fire.
If it fired off the prime you're getting a spark so you have a fuel draw problem or your needles are closed too far.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to Moggy)
       Post #: 2
RE: 3W60 won't start - 12/6/2012 3:15 PM
Moggy
Score: 100
Status: offline
Needles are set at one full turn. It's drawing fuel from the tank to the carb but not entering the engine?
Piece of Cake
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: 3W60 won't start - 12/6/2012 4:25 PM
dadragon
Score: 112
Last Login: 6/8/2013
Status: offline
Cuda +1
Hide Signatures
(in reply to Moggy)
       Post #: 4
RE: 3W60 won't start - 12/6/2012 5:18 PM
OldScaleGuy
Score: 120
Status: offline
Make sure the screen inside the carb is clean.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to dadragon)
       Post #: 5
RE: 3W60 won't start - 12/6/2012 9:35 PM
Tony Hallo
Score: 141
Status: offline
I would open both needles two turns.  Take the plug out and prime the cylinder with a few drops of gas.  Test for spark while the plug is out.
Tony Hallo
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 6
RE: 3W60 won't start - 12/6/2012 10:26 PM
Moggy
Score: 100
Status: offline
No spark so I sent it to Gerhard. What's weird is it popped on the prime yesterday so it had to have had a spark. Today, no spark go figure.
Piece of Cake
Hide Signatures
(in reply to Tony Hallo)
       Post #: 7
RE: 3W60 won't start - 12/6/2012 10:37 PM
CK1
Score: 150
Status: offline
Sounds like a 3w plug boot failure. Very common ...
"Aint this great !!" - Chris
"Nosen Cessna 310 Club" #8
Hide Signatures
(in reply to Moggy)
       Post #: 8
RE: 3W60 won't start - 12/6/2012 11:11 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: CK1
He beat me to it.
www.JaxRC.com
Hide Signatures
(in reply to CK1)
       Post #: 9
RE: 3W60 won't start - 12/7/2012 2:45 PM
Moggy
Score: 100
Status: offline
Thats what Gerhard said, should be an easy fix
Piece of Cake
Hide Signatures
       Post #: 10
RE: 3W60 won't start - 12/7/2012 4:04 PM
CK1
Score: 150
Status: offline
I would have Gerhard send you a spare cap kit when he ships it back to you. You may find that it will be handy to have when you are off at a fly-in and it wont start again .
Been there - done that!!!
Hide Signatures
(in reply to Moggy)
       Post #: 11
RE: 3W60 won't start - 12/7/2012 5:20 PM
Moggy
Score: 100
Status: offline
Good advice, thanks.
Piece of Cake
Hide Signatures
(in reply to CK1)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> 3W60 won't start
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
