RE: Illusion Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Illusion Build
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: Illusion Build - 12/29/2012 10:45 PM
edp
Score: 100
Last Login: 6/18/2013
Status: offline
I'm thinking of this scheme. I just can't get my butt down to the basement to work on it. I am plugging away at it, just not at my usual pace.
For a while, my benches looked like Santa's gift wrapping department
Click to see fullsize image.
Click for fullsize
_____________________________
Ed Peel AMA 2680 NECPO#58
Alliance Balsa Bees Inc #492
Hide Signatures
(in reply to edp)
       Post #: 26
RE: Illusion Build - 12/29/2012 11:06 PM
SuperViking
Score: 100
Last Login: 6/7/2013
Status: offline
I thought we might see a Veitnam camo job on this one, nothing too scale . I always thought some of thes classics looked like older jets and wanted to do one up like one just to be different, looks good though.
Hide Signatures
(in reply to edp)
       Post #: 27
RE: Illusion Build - 12/29/2012 11:14 PM
PatternPilot
Score: 125
Last Login: 6/19/2013
Status: offline
can you do a drawing with the pee green changed to red... ?
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to SuperViking)
       Post #: 28
RE: Illusion Build - 12/30/2012 10:57 PM
edp
Score: 100
Status: offline
Here you go Scott. The camo is only a what if. I even thought of the old Cicus Circus paint scheme. I have painted or covered so many red, white and blue birds.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to PatternPilot)
       Post #: 29
RE: Illusion Build - 12/31/2012 1:26 AM
R_G
Score: 135
Status: online
The camo is cool!
RG
Ralph Geese, AMA 36403, NECPO #2
Wanna hover? Fly a heli!
Hide Signatures
(in reply to edp)
       Post #: 30
RE: Illusion Build - 12/31/2012 1:31 AM
PatternPilot
Score: 125
Status: offline
The red,white,blue looks sweet.
S.
Hide Signatures
(in reply to R_G)
       Post #: 31
RE: Illusion Build - 12/31/2012 2:21 AM
SuperViking
Score: 100
Status: offline
I think the camo is cool also, maybe a few well placed markings and the bottom white and it would look the part!
Hide Signatures
       Post #: 32
RE: Illusion Build - 12/31/2012 3:43 PM
edp
Score: 100
Status: offline
There were two versions of the three tone wrap around w/ the the bottom being a ghost grey. Heck, add some drop tanks from the GP Phantom and drop them on a high speed pass. This way I can loose all respect from the pattern community
The rudder is now done minus the 1/4" dowel for the pull-pull system. The tank floor is ready to go in after adding blind nuts for the gear. There is plenty of room for the tank compaired to my H9 Phoenix 7. I may slide the tank floor up a bit to eliminate the little bend in the gear.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 33
RE: Illusion Build - 12/31/2012 3:56 PM
EscapeFlyer
Score: 120
Status: offline
That would be cool.... imo.
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to edp)
       Post #: 34
RE: Illusion Build - 12/31/2012 4:01 PM
edp
Score: 100
Status: offline
Brian,
The tree line would make it disappear
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 35
RE: Illusion Build - 12/31/2012 4:58 PM
SuperViking
Score: 100
Status: offline
hahahaha drop tanks ought to really impress the judges ! It does look cool in camo though but orientation could suffer. Anyways I am following your build and its looking good!
Hide Signatures
(in reply to edp)
       Post #: 36
RE: Illusion Build - 12/31/2012 5:48 PM
edp
Score: 100
Status: offline
Firewall is now glassed from behind and tank floor ready for install.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: Illusion Build - 12/31/2012 8:48 PM
edp
Score: 100
Status: offline
The tank floor is in and ready to be glassed in after the filling epoxy sets. I did move up the tank floor 1/4" from the print.
I also included some pics of my shop. The two benches are anchored to the wall, flat and level. They are great for wings and foam cores. These pics, and a few more,were taken for the club's basement of the month last year. The winter project was flown this year.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to edp)
       Post #: 38
RE: Illusion Build - 1/1/2013 5:56 PM
edp
Score: 100
Status: offline
The nose gear is set. I did lengthen it a 1/4" and will do the same for the mains. We have a great, well manacured grass field. 99.9% of the time
Click for fullsize
Hide Signatures
(in reply to edp)
       Post #: 39
RE: Illusion Build - 1/1/2013 8:47 PM
edp
Score: 100
Status: offline
The engine/muffler cutout are finalized. Now the fun part starts, WINGS/STAB
Click for fullsize
Hide Signatures
(in reply to edp)
       Post #: 40
RE: Illusion Build - 1/1/2013 9:48 PM
hrrcflyer
Score: 127
Status: offline
Hey EDP,
Glad to see you back at it. Keep up the great work & Happy New Year......
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to edp)
       Post #: 41
RE: Illusion Build - 1/5/2013 1:11 AM
edp
Score: 100
Status: offline
I had a minor problem as the cores were cut askew. I trued up both the root and tip. I then added 3/32" to fit it to the print. It took longer for the glue to dry than fixing it. I cut out for solid elevators. I didn't have much to glue my hinge points to. The stab is ready for joining and the anhedral sanded in at the root roughly 2 degrees per side. This gave me the 2" called for at the tip.
The wing are also sheeted. I have added some Cf horse hair to the TE hoping to help w/ the dings
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to hrrcflyer)
       Post #: 42
RE: Illusion Build - 1/5/2013 3:40 AM
doxilia
Score: 136
Status: online
Ed,
One thing I did on a recent Tipo build was to follow the build instructions and use one screw up front for the wing and two in the back. However, because of the curvature and thickness of the wing at the LE I found out that it's possible to actually over tighten the wing and have the hardwood dowel exit the top of the wing near the mount plate. This doesn't happen at the TE as the dowels are captured by the flush TE with the mounting blocks and the thin ply plate on the bottom which prevents over entry of the bolts.
In short, I no longer plan to mount my foam wings like that if I don't need to. I'll use the dual dowel approach on the wing LE with a 1/8" ply plate at the fuse junction. On the backside of the glass you can also install a couple of squares or rings of ply to anchor the dowels. Many don't like the dowels but they also make for a faster wing mount.
Just wanted to relay that experience. The last thing we want is to have a detached wing from the fuse of a just finished build...
David
Hide Signatures
(in reply to edp)
       Post #: 43
RE: Illusion Build - 1/5/2013 3:49 AM
frequent flyer
Score: 125
Status: offline
I second the dual dowels at the leading edge method. I always do it that way regardless of  what the plan says.
Epoxy Glass Fuselages, Short Kits & Fiberglass parts. Proudly made in the U.S.A. rcaiir.com
email: rcaiir@gmail.com
Hide Signatures
(in reply to doxilia)
       Post #: 44
RE: Illusion Build - 1/5/2013 3:51 AM
edp
Score: 100
Status: offline
Hi Dave,
I built three Tipos in the past w/o a problem like that one. I like to glass the dowels in so they can't move. I use a heavy then two layers of 3/4 oz. cloth overlap. I'm not a big dowel in the LE either. I did notice that the elevators are bigger on the Illusion compared to the Tiporare. My sanding jigs were too small.
Hide Signatures
       Post #: 45
RE: Illusion Build - 1/6/2013 1:22 AM
edp
Score: 100
Status: offline
The wing cores are trimed and sized. This is a good place to stop until Thursday. ( that pesky work thing is starting up again )
Click for fullsize
Hide Signatures
(in reply to edp)
       Post #: 46
RE: Illusion Build - 1/6/2013 3:47 AM
skybuster97
Score: 100
Last Login: 6/9/2013
Status: offline
I like your choice on the bright green, blue and white paint scheme . I did something similar on a Patricia ....refreshing. There are thousands of red, white and blue paint schemes. The bottom is akin to D. Brown's aircraft of old. Keep up the good work...
BL
Hide Signatures
(in reply to edp)
       Post #: 47
RE: Illusion Build - 1/6/2013 2:59 PM
edp
Score: 100
Status: offline
I talk to Dave Brown and Sally every year at the Toledo Show. I'm was going to tell him I stole his paint scheme and all his Shlitz
< Message edited by edp -- 1/6/2013 10:47 PM >
Hide Signatures
(in reply to skybuster97)
       Post #: 48
RE: Illusion Build - 1/7/2013 9:00 PM
stuntflyr
Score: 137
Status: offline
I like the camo, use the drops to light up the place when it disappears in the trees. Big impression points!
Back to reality...
Chris...
Hide Signatures
(in reply to edp)
       Post #: 49
RE: Illusion Build - 1/8/2013 2:32 PM
MMcConville
Score: 100
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: edp
Strohs not Shlitz
Mike McConville
Horizon Hobby
Hide Signatures
(in reply to edp)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.195RCU1
