Damaged cockpit. To fix or not to fix? That is the question.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Damaged cockpit. To fix or not to fix? That is the question.
Page: [1]
Login
Damaged cockpit. To fix or not to fix? That is the ques... - 12/7/2012 2:04 PM
Canadian Man
Score: 100
Last Login: 5/23/2013
Status: offline
I posted this question in my euro fighter build but I figured I would post it here to get more eyes on it.
So a question for all following this build.
Here are pics of the damaged cock pit.
Would you fix or buy a new one for $350 ish?
I would need to build a new front seat but I have the rear one to use as a guide. Also fix all the other missing / damaged items.
Let me know your thoughts.
Also what type of glue to repair this with? I would assume I would be gluing wood to this flimsy plastic material.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/7/2012 2:44 PM
wojtek
Score: 110
Status: offline
see if you could get just the tubs from the manufacturer. Looks like most of the components made it ok, or could be pieced, and you could reassemble into new one.
~V~
_____________________________
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to Canadian Man)
       Post #: 2
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/7/2012 2:53 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
Fix it for sure!
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to wojtek)
       Post #: 3
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/7/2012 2:59 PM
RCISFUN
Score: 105
Status: offline
CA it back together and then use 1oz fiberglass cloth and resin on the back side...EASY fix
I have one that I am bout to do in the same kind of shape
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
       Post #: 4
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/7/2012 3:42 PM
DelGatoGrande
Score: 105
Status: online
quote:
ORIGINAL: RCISFUN
+1!
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to RCISFUN)
       Post #: 5
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/7/2012 4:39 PM
FalconWings
Score: 121
Status: offline
Fix it. Tape all the parts in place from the "visible side" . Once you have "one piece" cockpit again, take some small pieces of fiberglass cloth and spray some 3M Adhesive on then place them on the "non-visible side" of the cockpit. Then take some thick and slow CA and and an epoxy brush and soak the fiberglass cloth with it. Once the cloth is saturated, spray some kicker on it and voi'la.
Take the tape off and re-finish.
Been there, done that.
David
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 6
RE: Damaged cockpit. To fix or not to fix? That is the ... - 12/8/2012 1:27 AM
Canadian Man
Score: 100
Status: offline
Thanks guys!
That gives me a good starting point. I had no clue where to begin!
Hide Signatures
(in reply to FalconWings)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
