RE: New Evolution 10cc gas engine    Gallery
Logged in as Guest
Users viewing this topic:
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: New Evolution 10cc gas engine - 12/29/2012 2:15 AM
earlwb
Score: 584
Last Login: 5/25/2013
Status: online
Some people a while back stated that the Evolution 10cc engine and the NGH 9cc engine used the same carb. Actually the carbs are completely different from each other. There are quite a few differences in how the different designers tackled the problem of a RC carb for a small gasoline engine.
The Evolution carb uses a spray bar that encloses the low speed needle. The NGH carb uses an open needle spray bar design.
The Evo carb does not have a spray bar depth adjustment screw on it like the NGH carb has.
The Evo carb has a fuel inlet fitting that appears to feed fuel directly to the high speed needle, whereas the NGH carb fuel inlet fitting is on the front side of the carb and indirectly feeds fuel to the high speed needle.
Of course the Evo carb isn't using a fuel pump but has a small fuel regulator on it. The NGH carb uses a external regulator/fuel pump unit.
There are other differences, such as the four screw front cover on the Evo carb versus the six screw front cover on the NGH carb. I am sure there are other more subtle differences as well.
< Message edited by earlwb -- 12/29/2012 1:16 PM >
_____________________________
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Mikola)
       Post #: 276
RE: New Evolution 10cc gas engine - 12/29/2012 6:37 AM
Ernie Misner
Score: 130
Status: offline
Nice pics! It's hard to tell, am I seeing a butterfly or rotating barrel in those for throttle control?
Hide Signatures
(in reply to earlwb)
       Post #: 277
RE: New Evolution 10cc gas engine - 12/29/2012 8:39 AM
robc57
Score: 100
Status: offline
Look like barrels to me.
Do know if the UK shipments have left yet, specifically to Kings Lynn Models?
Hide Signatures
(in reply to Ernie Misner)
       Post #: 278
RE: New Evolution 10cc gas engine - 12/29/2012 9:15 AM
flyinwalenda
Score: 157
Last Login: 5/26/2013
Status: online
They are both barrel type carbs. The NGH requires an external pump placed/located correctly for it to operate . Appears the EVO 10 has solved the carb issues using just tank pressure.
Brian Ray
Hide Signatures
(in reply to robc57)
       Post #: 279
RE: New Evolution 10cc gas engine - 12/29/2012 9:38 AM
AA5BY
Score: 153
Status: offline
Time will tell how installation variances affect fuel issues. My installation is inverted and will place the barrel somewhat below tank center line. We'll see.... eh.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 280
RE: New Evolution 10cc gas engine - 12/29/2012 1:12 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: Ernie Misner
They are both barrel throttle carburetors.  Walbro actually makes barrel throttle carbs too. Walbro had been making them for small gas engines for quite a few years now. The Walbro barrel carbs are seen on the small four stroke trimmer and leaf blower engines. Saito has been using barrel throttle carbs for quite a while as well, on their smaller four stroke gasser engines.
AMA # 928076
Hide Signatures
       Post #: 281
RE: New Evolution 10cc gas engine - 12/29/2012 1:19 PM
AJsToyz
Score: 304
Last Login: 5/22/2013
Status: offline
Looks more like NGH tride to copy and improve on the Magnum carb and didn't do so well.
www.Deathbychina.com
Hide Signatures
       Post #: 282
RE: New Evolution 10cc gas engine - 12/29/2012 1:21 PM
earlwb
Score: 584
Status: online
Some more comparisons of the Evolution 10cc and NGH 9cc engines.
Weight of Evolution 10cc engine by itself:
Weight of the NGH 9cc engine by itself
All up weight of the Evo 10cc engine with muffler and ignition unit
All up weight of the NGH 9cc engine with pump/regulator, ignition and OEM muffler
To make it more equal, using the Evolution muffler with the NGH 9cc engine all up weight
Pictures of the two engines side by side
AMA # 928076
Hide Signatures
       Post #: 283
RE: New Evolution 10cc gas engine - 12/29/2012 1:27 PM
earlwb
Score: 584
Status: online
Comparing the two different CDI modules used with the Evolution 10cc and NGH 9cc engines.
Both are made by RCexl too.  But the Evolution  version can handle higher voltages such as from two cell LiPo or LiFe battery packs whereas the NGH version is limited to 6.0v maximum.  The Evolution CDI is slightly longer but it is more narrow though.
AMA # 928076
Hide Signatures
       Post #: 284
RE: New Evolution 10cc gas engine - 12/29/2012 1:31 PM
earlwb
Score: 584
Status: online
quote:
ORIGINAL: AJsToyz
The Magnum engines are made by the same company that makes the Evolution engines as well as others like ASP, etc.
NGH on the other hand is a different company that came up with a different way of doing the same thing.
AMA # 928076
Hide Signatures
(in reply to AJsToyz)
       Post #: 285
RE: New Evolution 10cc gas engine - 12/29/2012 1:48 PM
AJsToyz
Score: 304
Status: offline
Just stating a simple fact, the Magnum was at the shows two years ago and the NGH looks very similar. I don't live in China so I really don't know who has access to see what.
Hide Signatures
       Post #: 286
RE: New Evolution 10cc gas engine - 12/29/2012 2:18 PM
earlwb
Score: 584
Status: online
Actually the Magnum prototype engine's carb was the design used in the Evolution engine. NGH did not copy it.
I think the Evolution people took over the development to sell and market the engines instead under their brand label and not the Magnum label.
Magnum Prototype .52 gasser in a test plane picture from a couple of years ago.
AMA # 928076
Hide Signatures
       Post #: 287
RE: New Evolution 10cc gas engine - 12/29/2012 3:09 PM
AJsToyz
Score: 304
Status: offline
OooK.
Hide Signatures
       Post #: 288
RE: New Evolution 10cc gas engine - 12/29/2012 5:44 PM
Kmot
Score: 168
Status: online
Is that from when they were testing it at the Apollo field?
~Tom~
Hide Signatures
       Post #: 289
RE: New Evolution 10cc gas engine - 12/29/2012 6:41 PM
Mikola
Score: 106
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: earlwb
Hide Signatures
       Post #: 290
RE: New Evolution 10cc gas engine - 12/29/2012 7:36 PM
kochj
Score: 143
Status: online
quote:
ORIGINAL: rhd-RCU
Mine has been ready to go, but I am fearful of breaking it in the 25 degree weather. It is an ABC engine.
It is a valid concern. In nitro cars, if you ran the engine out when it was winter, the cyl never comes up to proper temps.
This causes 2 things: The engine will loose compression. You will only be able to run the engine in cold weather, as this is the only way it wl develope compression,.
Metal expands and contracts....
It brings up the question, how do the other ringless motors handle freezing weather?
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to rhd-RCU)
       Post #: 291
RE: New Evolution 10cc gas engine - 12/30/2012 12:53 AM
RiverLarry
Score: 100
Status: offline
Kochj I have read yor Post  and     ( what are you trying to say ) ????     R/L
Hide Signatures
(in reply to kochj)
       Post #: 292
RE: New Evolution 10cc gas engine - 12/30/2012 3:46 AM
earlwb
Score: 584
Status: online
Mikola, yes NGH had gone down a similar development path that Evolution did. But NGH decided to use a external pump/regulator unit. Evolution seems to have solved the problem with their carb though. The two carb designs are somewhat similar but the actual carbs are quite different from each other. Different carb bodies and everything.
AMA # 928076
Hide Signatures
(in reply to RiverLarry)
       Post #: 293
RE: New Evolution 10cc gas engine - 12/30/2012 5:50 AM
Warbirdguy
Score: 145
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: av8tor1977
Ya know, I wonder why everyone uses a pumped, regulated carb on these small, (under 20cc) gassers? They are obviously much heavier than a glow type carb. Power to weight is an obvious concern with these small gassers, so I think they could save weight by using a simpler carburetor. When these size engines are used as glow engines, everyone works within the constraint of fuel draw weakness with the glow fuel system, and places their fuel tank accordingly. All they would need to do to use a simple glow type carb would be to provide it with very fine thread needles, or longer lower taper needles so the carb wouldn't be so finicky to adjust on gasoline. Someone is likely to say that it wouldn't be safe to use muffler pressure, which might be true. However, crankcase pressure could easily and safely be used.
Seems like except for the ignition coil itself, the ignition system could be made a lot smaller and lighter too....
Funny though, how everything has come full circle, from the old ignition engines, to glow, and now back to ignition. You would think the glow fuel manufacturers would ''see the light'' and get glow fuel prices under control before they loose their market completely!
AV8TOR
Being in the marine engine business for 30 plus years, I can answer that one. The old (pre 1958 outboard engine) used a crank case pressurized fuel system. The steel tank was sealed and pressure from the crank case pressurized the fuel tank. It took away the need for a fuel pump. But, what was overlooked was there were two lines going to the tank. A pressure line and a fuel line. Now, if the fuel line ever got damaged or came loose from the tank or engine, it would spray fuel everywhere creating a worse case scenario with fuel vapors and raw fuel all over the place and looking for something to ignite it, like a running engine. Or, you’re setting in a boat with a fully pressurized 3 or 6 gallon tank of gas. Not something I would want to be near.
Now, apply this to this aircraft engine. You run a regular glow type carb with a pressure line pressurizing the tank to eliminate the fuel pump carb. Two issues. One is the above mentioned. Second is when the engine stops and you still have gas in the tank, chances are its going to bypass the needle valve and run out of the carb into your airplane. May not be alot, but, unlike glow fuel, gas is explosive even in its smallest quantities. Either one not worth the risk.
I do agree that the current pumped carb is way too heavy for a small engine like this.
So maybe another answer to this issue would be the standard glow carb and a small bolt on fuel pump like the old "Perry Pump" of years gone by
WBG
Spitfire Brotherhood member #23
Hide Signatures
(in reply to av8tor1977)
       Post #: 294
RE: New Evolution 10cc gas engine - 12/30/2012 6:49 AM
airborneSGT
Score: 105
Last Login: 1/18/2013
Status: offline
Has anyone just flown the engine a lot to see how it will perform. I promise when I get one to fly it like I stole it. Same way I fly big planes :-) I dont take it easy on any plane.
PAU Sponsored Pilot
Hide Signatures
(in reply to Warbirdguy)
       Post #: 295
RE: New Evolution 10cc gas engine - 12/30/2012 7:23 AM
Ernie Misner
Score: 130
Status: offline
I think the barrel type carbs offer a more linear throttle response as compared to the butterfly type walbros. Is there nothing in the manual about how far away you can place the tank?
Hide Signatures
(in reply to airborneSGT)
       Post #: 296
RE: New Evolution 10cc gas engine - 12/30/2012 9:17 AM
vertical grimmace
Score: 154
Status: offline
quote:
ORIGINAL: airborneSGT
The engine has not been available for any length of time yet. Maybe a week or so? Patience grasshopper! The knowledge you seek will come in time.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 297
RE: New Evolution 10cc gas engine - 12/30/2012 11:54 AM
AA5BY
Score: 153
Status: offline
Tank Location
Because muffler pressure is used to provide the pressurization to the fuel regulating and metering carburetor, the tank still needs to be mounted in line with the carburetor, and as close to the rear of the engine as possible. Care taken in mounting the tank as described will provide trouble free operations in all flight attitudes.
Hide Signatures
       Post #: 298
RE: New Evolution 10cc gas engine - 12/30/2012 4:09 PM
rhd-RCU
Score: 100
Status: online
quote:
ORIGINAL: kochj
quote:
ORIGINAL: rhd-RCU
If the ABC engine doesn't get up to the correct temp. It will wear out prematurely.
rd
Hide Signatures
(in reply to kochj)
       Post #: 299
RE: New Evolution 10cc gas engine - 12/30/2012 4:21 PM
daytonarc
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Warbirdguy
AV8TOR
WBG
 The outboard engines I believe had a sealed fuel system.  This uses exhaust pressure.  as soon as the engine stops running the pressure will blead off through the muffler.
Hide Signatures
       Post #: 300
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
