RE: New Evolution 10cc gas engine    Gallery
Logged in as Guest
Users viewing this topic: Mick F
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: New Evolution 10cc gas engine - 1/3/2013 2:26 AM
captinjohn
Score: 247
Last Login: 5/25/2013
Status: offline
Just a note here, when you read any post "rmh" makes you can take the advice to the bank. He knows this RC stuff real well. I enjoy his comments very much...his ideas work. Happy New Years Guys....Capt,n
_____________________________
I never met a engine I did not like !
Hide Signatures
(in reply to captinjohn)
       Post #: 401
RE: New Evolution 10cc gas engine - 1/3/2013 3:39 AM
RiverLarry
Score: 100
Last Login: 5/22/2013
Status: offline
A OK Capt.    let me know when you get home need to show you the P 40 !!!!!   R/L
Hide Signatures
       Post #: 402
RE: New Evolution 10cc gas engine - 1/3/2013 3:43 AM
FlatSpin
Score: 100
Last Login: 5/26/2013
Status: offline
I wish I could take credit for the videos, but that honor belongs to Flyinwalenda. I'm technically challenged in posting here, but I'm learning.
Dave
Hide Signatures
(in reply to AA5BY)
       Post #: 403
RE: New Evolution 10cc gas engine - 1/3/2013 3:51 AM
AA5BY
Score: 153
Status: offline
Ooops... got my wires crossed... yep, thanks to Flyinwalenda.
Hide Signatures
(in reply to FlatSpin)
       Post #: 404
RE: New Evolution 10cc gas engine - 1/3/2013 4:13 AM
David DeWitt
Score: 100
Status: offline
Does the muffler have a baffle in it like the glow engines.
Hide Signatures
(in reply to AA5BY)
       Post #: 405
RE: New Evolution 10cc gas engine - 1/3/2013 4:37 AM
Ernie Misner
Score: 130
Status: offline
That's sure weird about loosing so many rpm's with the mac's pipe. Must have something to do with being a gasser.
Hello in Florida Capt'n!
Hide Signatures
       Post #: 406
RE: New Evolution 10cc gas engine - 1/3/2013 7:26 AM
2walla
Score: 100
Last Login: 5/23/2013
Status: offline
10k on a 13x6apc is about what a saito 72 will turn? Or is my memory bad.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 407
RE: New Evolution 10cc gas engine - 1/3/2013 9:44 AM
AJsToyz
Score: 304
Status: offline
I'm pretty sure my Saito .72 was in the high 9000's pretty close to 10k.
www.Deathbychina.com
Hide Signatures
(in reply to 2walla)
       Post #: 408
RE: New Evolution 10cc gas engine - 1/3/2013 11:07 AM
FlatSpin
Score: 100
Status: offline
quote:
ORIGINAL: David DeWitt
No, the muffler is just an air chamber.
Dave
Hide Signatures
(in reply to David DeWitt)
       Post #: 409
RE: New Evolution 10cc gas engine - 1/3/2013 12:06 PM
AA5BY
Score: 153
Status: offline
According to HH spec sheet on the Saito .72 the benchmark prop is an APC 13x8 @ 9800. Flyinlawenda's video with an APC 13x6 yielded 10700, less pitch but 900 rpms greater. Not bad and not a lot of disparity.
Further from HH, "In the 7 1/2-pound Super Stick, the .72 gives unlimited vertical performance." It is seeming possible that the Evo 10cc could reach the 7.25 lb thrust level and therefore the top of the 6.25-7.25 thrust range I guessed at a few days ago.
Hide Signatures
       Post #: 410
RE: New Evolution 10cc gas engine - 1/3/2013 12:27 PM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: Ernie Misner
I suspect that the OEM muffler on the Evo 10cc engine is more of a "tuned" muffler design. So the muffler has less of a performance loss when used with the engine, sometimes even a gain. The OEM muffler looks more like the old Performance Specialties Ultrathrust mufflers (aka Nelson Mufflers) or the Jett mufflers.  Thus if you use  different mufflers it could affect performance.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 411
RE: New Evolution 10cc gas engine - 1/3/2013 1:19 PM
RiverLarry
Score: 100
Status: offline
Some one needs to get a header from Mac    and some flex pipe  and a tuned pipe  and  start cutting !!!
and find the happy spot !!!     R/L
Hide Signatures
(in reply to earlwb)
       Post #: 412
RE: New Evolution 10cc gas engine - 1/3/2013 2:07 PM
airborne2.4
Score: 105
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: RiverLarry
+1
If you think you can or think you can''''t, you''''re right.
Hide Signatures
(in reply to RiverLarry)
       Post #: 413
RE: New Evolution 10cc gas engine - 1/3/2013 3:34 PM
rmh
Score: 252
Status: offline
You can make a very good tuned system from a small paint can and some 1/2" inside dia tubing.
I did some of these a few years back- - nothing magic about em.
basically you need about 12" of header which goes into the expansion can- and stops about 1/4" from inside end of the can -
an outlet of tubing about 1/4" id placed at front of the can will work-
this setup is about right for running at 10.000rpm .
It will take some careful testing and a prop which runs at about 10,000 without the ehaust system (open stack) for openers .
then it's cut n try till you get a smooth transitioning setup .
Then - you have to find a model which will accept the setup -
been there.
You can calculate it all day long but till you actually do it you won't find a good workable setup - heat - noise cooling - all affect it.
The books on tuned pipes are really of little or no value on doing a smooth ,broad band tuned system.
They are typically for doing a max power gain -which for most flyers is just a PITA The can in the picture was for a larger engine but theory is the same - it was on a ZDZ60.
Click to see fullsize image.
Click for fullsize
Libby is still watching you
Hide Signatures
(in reply to airborne2.4)
       Post #: 414
RE: New Evolution 10cc gas engine - 1/3/2013 10:01 PM
Shiftyeddie
Score: 100
Last Login: 5/21/2013
Status: offline
Ok, my engine is in! Can't wait to get it airborne.
Hopefully some of you guys get some air footage video on here
using this new engine!
Hide Signatures
       Post #: 415
RE: New Evolution 10cc gas engine - 1/3/2013 11:28 PM
Kmot
Score: 168
Status: offline
Well, I got some oil anyway.
BTW, the muffler bolt is long enough to add another 4mm nut on the end as a 'jam nut'.
Click for fullsize
Click for fullsize
~Tom~
Hide Signatures
(in reply to Shiftyeddie)
       Post #: 416
RE: New Evolution 10cc gas engine - 1/4/2013 12:36 AM
FlatSpin
Score: 100
Status: offline
quote:
ORIGINAL: FlatSpin
Thanks to everyone for your expert insight. I’m not trying to drain every last RPM out of this engine but it did strike me as odd that I got so much extra RPMs w/o the pressure line. I bet the LS is still a little off, so I will take the time to do more experimenting with the LS and HS settings this weekend. I'll even try a larger diameter fuel pressure line to see it that helps.
Dave
I did some needle tweaking today. With the APC 12x6, the engine maxed out at 10,100 RPMs but I finally got the engine to peak at 10,900 RPMs on the ground. The LS needle definitely interacts with the HS for rich/lean and max RPMs and 1/16” makes about a 500 RPM difference. At the peak needle settings, removing the muffler pressure line caused the engine to die. I flew it at these needle settings and got 13,850 RPMs unloaded in a dive. I left the LS needle alone and opened the HS for a 200 RPM decrease. The transition to WOT is solid and my idle is around 2100.
I now have 2/3 gallon thru this little beast which equates to about 5-5 ½ hrs of flight time and decided to see what the piston and crank pin looked like. There is just a light golden brown hue on the piston, near the exhaust port and the crank pin still looks brand new. The spark plug tip is a light tan. All OK so far! Now to mount this in my new Meridian and maybe get in a maiden flight it this weekend.
Dave
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 417
RE: New Evolution 10cc gas engine - 1/4/2013 12:50 AM
AJsToyz
Score: 304
Status: offline
quote:
ORIGINAL: AA5BY
Further from HH, ''In the 7 1/2-pound Super Stick, the .72 gives unlimited vertical performance.'' It is seeming possible that the Evo 10cc could reach the 7.25 lb thrust level and therefore the top of the 6.25-7.25 thrust range I guessed at a few days ago.
I'm pretty sure Horizon gets there prop numbers running 30% nitro fuel.
Hide Signatures
(in reply to AA5BY)
       Post #: 418
RE: New Evolution 10cc gas engine - 1/4/2013 2:02 AM
chandley43231
Score: 100
Status: offline
ok can some tell me if this will fit on a hanger 9 b-25 of course there would be 2  or is it too big
Hide Signatures
       Post #: 419
RE: New Evolution 10cc gas engine - 1/4/2013 3:04 AM
earlwb
Score: 584
Status: offline
Yes the engines would fit no problem in the H9 B-25. They suggest Evo .40NX glow engines.  The Evo 10cc engine is really the same size as a .46 to .56 size glow engine. The .40NX is in that same size range too.  It is a drop in replacement for some of those size engines too. The Evo .60 NX is the same engine as a glow version. You might want to use a Pitts muffler or something that fits inside the cowls more though, but you don't have to, if you don't mind the mufflers sticking out more. Your biggest hassle is the ignition CDI unit and where you are going to put them. You might have to get a bit creative and imaginative for them.  Other than that the engines would work fine.
AMA # 928076
Hide Signatures
(in reply to chandley43231)
       Post #: 420
RE: New Evolution 10cc gas engine - 1/4/2013 5:09 AM
Firepower R/C
Score: 110
Last Login: 5/16/2013
Status: offline
It is sure looking like they have a good design on their hands... this looks like the best attempt yet on a small gas engine.
Firepower R/C
Saving un-loved R/C airplanes around the world
Hide Signatures
       Post #: 421
RE: New Evolution 10cc gas engine - 1/4/2013 1:02 PM
RJStrickJR
Score: 110
Status: offline
I will tell you next week if my B-25 will ever get here.... My 2 engines finally came in and the 2 Bisson Pitts mufflers. I guess when I get it set up and running it will answer some of the other questions about after market mufflers and their effects on the little stinkers!
quote:
ORIGINAL: chandley43231
Hide Signatures
       Post #: 422
RE: New Evolution 10cc gas engine - 1/4/2013 1:26 PM
chandley43231
Score: 100
Status: offline
Thanks for reply for the hanger 9 b25 do take some pics and post let me know how they work  I have the bird it's all so right now with a great sound system in it but I want to go to has would I need separate kill switch per motor or can I y harness of course after CDi ignition and whAt size 3 blade can I put on the 10cc motors  man if horrizon could do a video build like there hanger9 p-47 that would be awsome!!!
Hide Signatures
(in reply to RJStrickJR)
       Post #: 423
RE: New Evolution 10cc gas engine - 1/4/2013 3:17 PM
airborneSGT
Score: 105
Last Login: 1/18/2013
Status: offline
quote:
ORIGINAL: RJStrickJR
I will be following up to see the numbers Horizon said it was not a big impact on performance!
PAU Sponsored Pilot
Hide Signatures
       Post #: 424
RE: New Evolution 10cc gas engine - 1/4/2013 4:38 PM
gade600sdi
Score: 115
Status: offline
I have been doing some calculation on weight vs. the Evolution 60NX engine.
Evolution 10cc Gas is 23 ounces all in. (book says 22 but I used the guy that weighed it on a scale in this forum)
Evolution 60NX glow is 17 ounces all in. (it may really be 18 but I am using the published specs)
But, I use a 16 ounce tank normally for a 10-12 minute glow flight, and I am thinking 8 ounces of gas tank would be more than needed to provide 15 minute flights, possibly a 6 ounce tank would be enough. So you can save 8 ounces of fuel, maybe 9-10 ounces figuring the smaller tank will weigh less. So that gives you a net savings of 3-5 ounces, which will go towards the ignition pack.
Overall, its very close weight to the 60NX glow based on my logic above.
Now for the power, prop rpm readings I am seeing here are comparable to what I get on a 60 glow motor, so the power seems similar too.
So, this should be a perfect motor for a plane like the Hangar 9 Katana and should be good for 3D with the power to weight ratio. Did I conclude this right or did I miss something?
My conclusion
Hide Signatures
(in reply to airborneSGT)
       Post #: 425
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
