RE: New Evolution 10cc gas engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Page: <<   < prev  35 36 [37] 38 39 40 41 42 43 44   next >   >>
Login
RE: New Evolution 10cc gas engine - 2/20/2013 1:25 AM
josephcraig
Score: 100
Last Login: 5/23/2013
Status: offline
Pete,
I'm going with the factory muffler.i'm not satisfied with the pitts..i'm sure it would be fine but,the muffler yall designed seems so much better..all ive got to do is notch a small spot on fusalage corner where the very end of the muffler won't hit on bottom side of firewall..cowl will cover it up anyway..just put a liitle angle notch and glue it back..about half way done with getting it together.hopefully maiden flight when weather permits probably week or so...
                                       Craig....
Hide Signatures
(in reply to Pete Bergstrom)
       Post #: 901
RE: New Evolution 10cc gas engine - 2/20/2013 1:29 AM
Pete Bergstrom
Score: 130
Status: offline
Sounds great.  We have used that same solution a lot when testing on different airframes.  Send pictures when you're done!
Pete
_____________________________
Pete Bergstrom
Saito, Evolution & Zenoah Manager
Hide Signatures
(in reply to josephcraig)
       Post #: 902
RE: New Evolution 10cc gas engine - 2/20/2013 1:40 AM
josephcraig
Score: 100
Status: offline
yall hit the settings on the carb..once the engine gets temp up she is really great...
Hide Signatures
       Post #: 903
RE: New Evolution 10cc gas engine - 2/20/2013 4:21 PM
josephcraig
Score: 100
Status: offline
Pete,
the filter in tank, will i have any problem on inverted flight,cause right now the line is still a little stiff...
Hide Signatures
       Post #: 904
RE: New Evolution 10cc gas engine - 2/20/2013 5:40 PM
Pete Bergstrom
Score: 130
Status: offline
quote:
ORIGINAL: josephcraig
Pete,
Joseph,
We have had no issues with the tubing being too stiff when we were testing.  We used mostly 8 oz tanks and would suck the tank dry in all attitudes.  Our test with a six ounce tank worked fine as well.
Pete
Pete Bergstrom
Hide Signatures
       Post #: 905
RE: New Evolution 10cc gas engine - 2/20/2013 11:17 PM
Kentli22
Score: 100
Last Login: 4/28/2013
Status: offline
I have more than 10 flights so far, with an apc12*8, everything is great except it is still making a lot of black goo,  what is the problem? i believe that I have the neeedles adjusted pretty correct  for this prop.
Hide Signatures
       Post #: 906
RE: New Evolution 10cc gas engine - 2/21/2013 12:19 AM
FlatSpin
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: Kentli22
The infamous "black goo" will eventually subside to a managable level. I am on my 2d gallon of gas and now using Klotz synthetic oil and the "goo level" is MUCH better.
Dave
Hide Signatures
(in reply to Kentli22)
       Post #: 907
RE: New Evolution 10cc gas engine - 2/21/2013 6:50 PM
Beavis
Score: 110
Status: offline
Is there any black muffler from Macs that fits on this engine (and works well, of course)?
Thanks in advance,
Hide Signatures
(in reply to FlatSpin)
       Post #: 908
RE: New Evolution 10cc gas engine - 2/21/2013 8:42 PM
FlatSpin
Score: 100
Status: offline
quote:
ORIGINAL: Beavis
Thanks in advance,
I am using the black MACs muffler that is designed for the OS 55AX. It is an exact fit and it works fairly well, with a 200-300 RPM increase over the stock muffler (in my case anyway). It softens the noise some, but mainly it is one piece and there is nothing to vibrate loose or fall off.
Dave
Hide Signatures
(in reply to Beavis)
       Post #: 909
RE: New Evolution 10cc gas engine - 2/21/2013 9:30 PM
airborne2.4
Score: 105
Status: offline
I use that same muffler with my OS 55
If you think you can or think you can''''t, you''''re right.
Hide Signatures
       Post #: 910
RE: New Evolution 10cc gas engine - 2/21/2013 9:48 PM
josephcraig
Score: 100
Status: offline
Dave,
what kind of rpms you getting with 12 x 6..is that your preferred blade...i ordered the evo blades i like the looks of them and think they should be just as good as apc...
Hide Signatures
       Post #: 911
RE: New Evolution 10cc gas engine - 2/21/2013 10:33 PM
kork
Score: 100
Status: offline
I just spoke with AL @ JTEC mufflers. He is making 2 wrap around pitts for me, for my b-25. The engines will be inverted, so if anyone has any questions you could call him. He has my 10cc mounted on a set of rails for measurements. It will be there all of next week.
jason
Hide Signatures
       Post #: 912
RE: New Evolution 10cc gas engine - 2/21/2013 11:59 PM
FlatSpin
Score: 100
Status: offline
Dave,
If I remember correctly, I am getting 11400+/- on the ground and 12800-13200 in the air.
Dave
Hide Signatures
       Post #: 913
RE: New Evolution 10cc gas engine - 2/22/2013 4:14 AM
flyingninja
Score: 100
Last Login: 5/12/2013
Status: offline
hi flat spin on your black macs muffler is your muffler for the os 55ax a bolt through or a bolt on.the muffler on my engine keeps turning no matter what i do and its making the goo much worser on the plane.i would like to try the single one piese from macs if its not going to affect the tunning of the engine and contain the goo some to some extent.thanks for your info
Hide Signatures
       Post #: 914
RE: New Evolution 10cc gas engine - 2/25/2013 2:16 AM
josephcraig
Score: 100
Status: offline
well i did get the bottom notched out for the muffler..the pitts would probably perform just as good ,but i like the factory muffler for sound and response.weather here has been crappy and i was sick a couple of days this past week..hope to close everything up this next week and see what it'll do.. i never get in a hurry to put one together cause i want to make sure everything is right..hope everybody is doing well with engine..i did order the evo blades and gonna try them ..i wish they made a 12 x 5, cause i like the 5 pitch..soon as i'm finished i'll take pictures,hopefully they won't be the last pictures...jimmy and pete, see if you can have some input on 12 x 5 evo blades....thanks
Hide Signatures
(in reply to triumphman49)
       Post #: 915
RE: New Evolution 10cc gas engine - 2/25/2013 4:29 AM
FlatSpin
Score: 100
Status: offline
quote:
ORIGINAL: flyingninja
The MACs is a bolt thru muffler. I used red RTV on the original muffler body parts to seal it and a small o-ring on the bolt that goes through the muffler. That kept it from leaking from the middle of the body. I got the o-ring at the local auto parts store.
Dave
Hide Signatures
(in reply to flyingninja)
       Post #: 916
RE: New Evolution 10cc gas engine - 2/25/2013 10:16 PM
chandley43231
Score: 100
Status: offline
just got back from the field took the evo 10  up on my matt chapmen eagle 580  used the 10x6 prop for first flight wow took a bit to get off the ground  everyone was impressed  Jearad who flys hellis  for horrizon took up the 580 an thought i was empressive with out a sag  the black goow was just all over the left side of the plane  im going to try some dish washing soap to get it off they couldn't believe  that you have to run it at high rpm for break in all was such a perfect day at dennein field the wind was even running strait down the run way so as to have no cross winds  put 32 ozs through engine now im going to step up a prop  ill have post of the bird on u tube at chandley43231 great motor horizon good job man
Hide Signatures
       Post #: 917
RE: New Evolution 10cc gas engine - 2/27/2013 1:05 AM
hoss22193
Score: 100
Last Login: 5/10/2013
Status: offline
so for the black goo that is talked about has anyone found the best way to keep it from producing it. or is it just a trade mark of this engine.
Hide Signatures
(in reply to chandley43231)
       Post #: 918
RE: New Evolution 10cc gas engine - 2/27/2013 2:15 AM
FlatSpin
Score: 100
Status: offline
quote:
ORIGINAL: hoss22193
Engine run time is the solution. Except for the fisrt several minutes setting up the needles and minor pit time associated with each flight, all of my engine run time is in the air. After the first 1/2-2/3 gallon, I noticed the amount of goo produced getting smaller and smaller. I have several flights from of my second gallon of gas and it is quite manageable now. That and I switched from Pennzoil air cooled 2C oil at 20:1 to Klotz synthetic oil at 25:1. It cleans up easily with a 409/ammonia solution or Clorox wet wipes.
Dave
Hide Signatures
(in reply to hoss22193)
       Post #: 919
RE: New Evolution 10cc gas engine - 2/27/2013 4:24 AM
Mikola
Score: 106
Last Login: 5/8/2013
Status: offline
this thread is half dead, why don't you post more videos ? didn't it get success ?
Hide Signatures
       Post #: 920
RE: New Evolution 10cc gas engine - 2/27/2013 10:48 AM
chandley43231
Score: 100
Status: offline
I used Krud cutter from lowes and Home Depots  it works with a little elbo  this motor will be great on my b-25
Hide Signatures
(in reply to Mikola)
       Post #: 921
RE: New Evolution 10cc gas engine - 2/27/2013 12:32 PM
AA5BY
Score: 153
Status: offline
quote:
ORIGINAL: Mikola
Sorry... having too much fun flying it to mess with videos.
I've got twenty some odd flights on mine and still have abt 1/3 gal of gas left in the can. Fuel cost are going to be around 15 cents per flight. No dead sticks yet. Easy hand starting. No glow starter or field box support needed. Cleans up with a single Clorox wipe so no roll of towels and spray bottle needed.
It will hover a 5.7lb plane at half throttle. It can be propped for fast or not as fast and thus will serve a wide variety of air frames. Video isn't needed to show success... take users at their word... it is a good engine.
Hide Signatures
       Post #: 922
RE: New Evolution 10cc gas engine - 2/27/2013 2:37 PM
mattnew
Score: 110
Status: online
just bought one of these based off of the "rave" reviews that its been getting . Its going to start out life going into a phaeton II, and then when my GP RV-4 .40 sized is done it will go into that. Can't wait!
Carl Goldberg Ultimate Brotherhood #103
Ultra Sport Brotherhood #148
Hide Signatures
(in reply to AA5BY)
       Post #: 923
RE: New Evolution 10cc gas engine - 2/27/2013 2:38 PM
josephcraig
Score: 100
Status: offline
my plane is gonna be a pound heavier than that..it should fly it pretty well then..don't you think?
Hide Signatures
(in reply to AA5BY)
       Post #: 924
RE: New Evolution 10cc gas engine - 2/27/2013 5:07 PM
chandley43231
Score: 100
Status: offline
heck yea my gp  Chapman 580 eagle is just over 7 pounds its fly's great even with 10x6 starting on it  just moved the prop up to a 12x6 first nice weather ill be at the field again running the heck put of it
Hide Signatures
       Post #: 925
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New Evolution 10cc gas engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
