Need Sander Advice    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Need Sander Advice
Page: [1]
Login
Need Sander Advice - 12/7/2012 5:36 PM
ma_mulcahy
Score: 100
Last Login: 5/21/2013
Status: offline
I am looking at purchasing a bench top sander for various airplane sanding chores. Initially, I was looking at a combo sander with a 3-4" belt and 5-6" disc. My thought was that it would be good to have a couple of different grits for different purposes. My thinking has evolved towards purchasing just a 12" disk sander thinking that this is probably all I need. With a 150 grit disk on it, it should be a good general purchase sander.
What have all the builders used successfully?
_____________________________
Mike
Waco Brotherhood #215/Ultra Sport Brotherhood #126
Hide Signatures
       Post #: 1
RE: Need Sander Advice - 12/7/2012 6:05 PM
Mustangman40
Score: 181
Last Login: 5/22/2013
Status: online
I am going to pick up one of these tomorrow, they are on sale for 49.95 till Sunday. Best of both worlds at a great price...
I been getting buy for many years with a small sander from Dremel and it's still works fine, but for 50 bucks, it's time to upgrade..
http://www.menards.com/main/tools-hardware/power-tools/sanders/wen-4x6-belt-disc-sander/p-1868526-c-10088.htm
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to ma_mulcahy)
       Post #: 2
RE: Need Sander Advice - 12/7/2012 6:08 PM
foodstick
Score: 177
Status: offline
When I bought one of these I figured I would use the belt more than the wheel, However I use the wheel the most by far. If I was to buy a new one I would get the biggest side wheel I could...
Hide Signatures
(in reply to Mustangman40)
       Post #: 3
RE: Need Sander Advice - 12/7/2012 7:19 PM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
If you buy a disk sander is is a nice feature to have the motor reversible. It is sometimes nice to use the other side of the table/wheel.
Ken
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to foodstick)
       Post #: 4
RE: Need Sander Advice - 12/7/2012 8:06 PM
Gray Beard
Score: 314
Status: offline
Mine is belt and disc but I belong to a wood working club and they have several different types and I use them all. The sander Mustang showed is an outstanding choice and the price is sure right. I could sure use a new one in my shop.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to kenh3497)
       Post #: 5
RE: Need Sander Advice - 12/7/2012 8:34 PM
Top_Gunn
Score: 134
Status: offline
I have a belt-disc sander and almost never use the belt. If I had it to do over, I'd go the way you're thinking of going.
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: Need Sander Advice - 12/8/2012 3:14 PM
KW_Counter
Score: 141
Last Login: 5/19/2013
Status: offline
I have a Ryobi belt-disc sander and love it.
Having a multi-tascker sure saves a lot of space.
I admit the belt is used more than the disc;
often times, for RC stuff, it isn't even turned on.
It's nice to have a solid piece of sandpaper so convenient to make
a small adjustment.
I have learned through life, buy more than you need right now, eventually you'll need it.
Good Luck,
KW_Counter
Hide Signatures
(in reply to Top_Gunn)
       Post #: 7
RE: Need Sander Advice - 12/9/2012 3:10 PM
Edwin
Score: 156
Status: offline
The sander I use the most is the 1" vertical belt. I have a 6" disc / 4" belt sander and seldom use it, only for big heavy jobs with isnt very often. I dont have as much control for the finer detailing as the 1" belt.
Edwin
Hide Signatures
(in reply to KW_Counter)
       Post #: 8
RE: Need Sander Advice - 12/9/2012 10:13 PM
WhiteRook
Score: 108
Status: offline
get one with a dust collector , the dang things make a total mess
Hide Signatures
       Post #: 9
RE: Need Sander Advice - 12/10/2012 2:58 PM
mustangman177
Score: 105
Status: offline
Picked one up at Menard's Saturday. had a $40.00 Menards certificate from last year and put it to good use on a sander. Looks to be decent quality, time will tell.
Thanks for the "Heads-Up" on this offer !!!
Hide Signatures
(in reply to WhiteRook)
       Post #: 10
RE: Need Sander Advice - 12/10/2012 5:03 PM
mustangman177
Score: 105
Status: offline
Looking for a small band saw to compliment the sander I picked up at Menards. What is of decent quality out there ?
Hide Signatures
(in reply to mustangman177)
       Post #: 11
RE: Need Sander Advice - 12/13/2012 12:34 AM
eagledancer
Score: 110
Status: offline
i have a delta 10" band saw, most used tool in my shop. this one is 20 years old and still going strong!!
one thing to do before you buy find out the size blade it uses and shop around and see how available they are, mine are starting to get hard to find
I once had a drinking problem.....I divorced it, now shes someone else''s problem
waco brotherhood # 140
Hide Signatures
       Post #: 12
RE: Need Sander Advice - 12/13/2012 2:28 AM
acerc
Score: 221
Status: offline
I have one of the old Ohio forge band saw's. I can only get blades at Ace or online, when it breaks not waiting for online. So check availability before purchase. I have a cheap belt/disk sander from Harbor Freight, I use both equally, depending on task.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to eagledancer)
       Post #: 13
RE: Need Sander Advice - 12/14/2012 2:47 AM
Hydro Junkie
Score: 116
Status: offline
I've found the belt/disc sander I have to be very limiting on what I can do on it. I ended up buying a sander that combines and oscillating spindle with a horizontal belt and have found it to be my "go to" sander. Here is a link so you can take a look:
http://www.homedepot.com/Tools-Hardware-Power-Tools-Sanders/h_d1/N-5yc1vZc28s/R-100061671/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
Hide Signatures
(in reply to acerc)
       Post #: 14
RE: Need Sander Advice - 12/15/2012 3:46 PM
KW_Counter
Score: 141
Status: offline
Search online. Many band saw blade suppliers cut to your specifications.
I have a craftsman, they use odd sizes to keep you coming back in, the B@$&@()*
Good Luck,
KW_Counter
Hide Signatures
(in reply to acerc)
       Post #: 15
RE: Need Sander Advice - 12/15/2012 10:38 PM
bikerbc
Score: 116
Status: online
I have a Rockwell 14" bandsaw that use's a 93.5" blade...I order blades from Acklands and I believe they custom make them...What I use are 1/4" 24 teeth per inch , They are wiggly like a hacksaw blade and you can cut aluminum or lite ferrous metal's or pretty much what ever we run into hobby wize...I order 12 at a time and they cost around $10.00 each..That lasts me for a long time...
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
       Post #: 16
RE: Need Sander Advice - 12/16/2012 2:20 PM
OldRookie
Score: 115
Status: offline
Here is the one I got several years ago.
I've never looked back.
http://www.harborfreight.com/12-inch-direct-drive-bench-top-disc-sander-43468.html
Greg
You really only own what you can carry at a full out run.
Hide Signatures
(in reply to bikerbc)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
