Dried Epoxy on Ultracote?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> Dried Epoxy on Ultracote?
Page: [1] 2   next >   >>
Login
Dried Epoxy on Ultracote? - 12/7/2012 11:13 PM
BillinIndiana
Score: 100
Last Login: 6/8/2013
Status: offline
 What can I use to remove dried two-part epoxy from Ultracote without scratching it up or ruining it?
Hide Signatures
       Post #: 1
RE: Dried Epoxy on Ultracote? - 12/7/2012 11:31 PM
GaryHarris
Score: 168
Last Login: 6/2/2013
Status: offline
Nothing.
_____________________________
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to BillinIndiana)
       Post #: 2
RE: Dried Epoxy on Ultracote? - 12/8/2012 12:22 AM
Gray Beard
Score: 314
Last Login: 6/19/2013
Status: offline
New covering.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to GaryHarris)
       Post #: 3
RE: Dried Epoxy on Ultracote? - 12/8/2012 12:58 AM
bikerbc
Score: 121
Last Login: 6/18/2013
Status: online
If you can loosen the covering and twist it around a bit the epoxy just mite crack loose and let go but I think you will be left with some marks..Mite not be too bad depending on the colour......Other than that you are stuck... Good luck
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
(in reply to Gray Beard)
       Post #: 4
RE: Dried Epoxy on Ultracote? - 12/8/2012 1:14 AM
acerc
Score: 221
Status: offline
That's funny right there.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to bikerbc)
       Post #: 5
RE: Dried Epoxy on Ultracote? - 12/8/2012 1:24 AM
speedracerntrixie
Score: 194
Status: offline
Carefully warm up the epoxy with a heat gun and it will soften. Obviously don't use enough heat to damage the covering.
Hide Signatures
       Post #: 6
RE: Dried Epoxy on Ultracote? - 12/8/2012 4:22 AM
BillinIndiana
Score: 100
Status: offline
 Thanks... I'll just leave it alone. It's only a small area on the bottom, plus it's just a trainer.. I was just curious if there was something that would make it dissolve enough to wipe off. It's not worth recovering the bottom for..
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 7
RE: Dried Epoxy on Ultracote? - 12/8/2012 5:09 AM
52larry52
Score: 120
Status: offline
Bill, I've had some success by putting a couple of drops of CA de-bonder on the Epoxy wetting the outside edge of the "glob" and then carefully picking at the Epoxy with a hobby knife. Alcohol used the same way also sometimes works to get it loose from the covering but as the other guys have correctly said, nothing will actually dissolve it. "Pick" with care and if you get the major part of the "glob" off then wipe the residue with a paper towel wet with the de-bonder or alcohol. Good luck!!!
Hide Signatures
       Post #: 8
RE: Dried Epoxy on Ultracote? - 12/8/2012 6:03 AM
jester_s1
Score: 233
Status: offline
You may get it off by very carefully scraping it with a razor blade or hobby knife. If you can thinly slice it off you should get by with only minor wood denting and no covering damage.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to 52larry52)
       Post #: 9
RE: Dried Epoxy on Ultracote? - 12/8/2012 6:19 AM
mooseflier
Score: 100
Last Login: 12/13/2012
Status: offline
I admit I haven't covered a wind in about 3 years, but I thought alcohol or laquer thinner takes that out without messing with the monokote. Or is ultracote different?
Hide Signatures
(in reply to jester_s1)
       Post #: 10
RE: Dried Epoxy on Ultracote? - 12/8/2012 7:02 AM
nitro wing
Score: 125
Status: offline
epoxy wont soften or disolve again, usually its brittle enough over time that it will pick off the covering in a clean manner, with a blade or pick, usually ends up in your eyes, so be aware.
Hide Signatures
(in reply to mooseflier)
       Post #: 11
RE: Dried Epoxy on Ultracote? - 12/8/2012 8:16 AM
GaryHarris
Score: 168
Status: offline
I wouldn't mess with it. Trying to get rid of it might just make it look worse.
Hide Signatures
(in reply to nitro wing)
       Post #: 12
RE: Dried Epoxy on Ultracote? - 12/8/2012 9:31 AM
jaka
Score: 158
Status: offline
Hi!
It's easy!
Use a warm airgun!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 13
RE: Dried Epoxy on Ultracote? - 12/8/2012 11:51 AM
pmerritt
Score: 172
Status: offline
quote:
ORIGINAL: speedracerntrixie
If you think you can heat up epoxy at a lesser temperature than it would take to destroy the covering, you might need to step away from the CA.
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
       Post #: 14
RE: Dried Epoxy on Ultracote? - 12/8/2012 1:01 PM
Steve Steinbring
Score: 116
Status: offline
Epoxy starts to breakdown around 325 degrees F. and is chemical resistant so acetone, alcohol, and other common solvents are not very effective once epoxy has cured. Methalene Chloride (used in strong paint strippers) will break it down, but the cure is probably worst than the problem.
Hide Signatures
(in reply to pmerritt)
       Post #: 15
RE: Dried Epoxy on Ultracote? - 12/8/2012 1:14 PM
da Rock
Score: 265
Status: offline
Honest, replacing covering is dead simple and quick. And it's almost impossible to tell that it's been done unless you get up close enough to see the overlap. And you've got to know to look for it.
I often cut the covering out of open areas when assembling ARFs in order to brace pushrods in the fuselage and such. When done, ironing matching covering over the hole takes a couple of minutes tops. It's like having a semi-permanent hatch there. And I've had to point them out to people who seem baffled when I tell them about doing it.
Funny thing is the response is almost guaranteed. Almost everyone says something like, "that seems like an awful lot of work". It isn't even close to being work, and no effort at all. In fact, it makes some jobs possible and all of them a lot easier.
Heat the epoxy and see if it comes loose. If it doesn't, then trim the covering around it and it ought to be easy to lift since it'll be warm. Warmed covering is easier to remove.
Good flying wit ya today
Hide Signatures
(in reply to Steve Steinbring)
       Post #: 16
RE: Dried Epoxy on Ultracote? - 12/8/2012 1:22 PM
jaka
Score: 158
Status: offline
Hi!
All epoxy glues will become loose and brittle with heat and then you pry the epoxy away with a sharp nr 11 X-axto knife.
Hide Signatures
(in reply to da Rock)
       Post #: 17
RE: Dried Epoxy on Ultracote? - 12/8/2012 5:18 PM
Brian Smith
Score: 120
Last Login: 4/14/2013
Status: offline
I took some very ugly dried CA off my model with acetone. IT was old and dry. Had to work at it slowly andf let the acetone work in. I was amazed...Never tried epoxy. Just sayin/ Brian
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
Hide Signatures
(in reply to jaka)
       Post #: 18
RE: Dried Epoxy on Ultracote? - 12/8/2012 5:36 PM
toolmaker7341
Score: 105
Status: offline
use a heat gun or a sealing iron (easyest to control) to soften the epoxy then wipe off with a tissue. This requires several tries and when you get most of it off heat again and wipe the rest off with a tissue soaked with laquar thinner.
PS I don't use CA,sniff glue or drink. Hobby epoxy starts to soften at about 200 deg F Just ask my wife about when she went into a sauna with glasses I had epoxed together. They fell off her face after about 5 minutes.
Mike Burg
Hide Signatures
       Post #: 19
RE: Dried Epoxy on Ultracote? - 12/8/2012 6:04 PM
straitnickel
Score: 105
Status: offline
Alcohol, if you get to it before it sets up. After it sets, I've removed some really thin smudge marks and that's about it
I don''''t always crash, but when I do!
Hide Signatures
(in reply to toolmaker7341)
       Post #: 20
RE: Dried Epoxy on Ultracote? - 12/8/2012 6:58 PM
Gray Beard
Score: 314
Status: offline
It just hit me, I just used a mixing cup that I was using to mix up epoxy in and I used it to hold a bit of lacquer thinner and the epoxy did soften up and peel out. Just a thought, I have never tried to use it to remove epoxy from covering before but it may be worth a try? I do use my heat gun to remove wood parts from places but the parts really require a lot of heat to melt/soften the epoxy. Heat is your friend but on covering? Not so much. I have tried Acetone without much luck but the lacquer does remove it, I just don't know how much soaking it would take. If it isn't bad I would just leave it alone. I hate having a new plane with a patch job, done it before but didn't like it.
Hide Signatures
(in reply to straitnickel)
       Post #: 21
RE: Dried Epoxy on Ultracote? - 12/8/2012 8:15 PM
rv9-a
Score: 105
Status: offline
Try M.E.K now known as M.E.K Substitute.
Hide Signatures
       Post #: 22
RE: Dried Epoxy on Ultracote? - 12/9/2012 12:07 AM
speedracerntrixie
Score: 194
Status: offline
quote:
ORIGINAL: pmerritt
Just about all ambient cured hobby epoxies will soften at or a little above 150 degrees. At work where I make composite components for military aircraft we use heat all the time to clean up unwanted epoxy. Maybe some reserch was in order before sending the red reply   lol
Hide Signatures
       Post #: 23
RE: Dried Epoxy on Ultracote? - 12/19/2012 1:13 AM
JPMacG
Score: 123
Status: offline
I recently spent several hours trying to remove epoxy from Monokote - and was unsuccessful.
I tried a heat gun, and yes it softens the epoxy - which makes it even harder to pick off. I actually wonder if I should try freezing the area with cold spray. Maybe that would make the epoxy brittle and easier to pick off the covering. Maybe heating and cooling several times would help break the bond.
Hide Signatures
       Post #: 24
RE: Dried Epoxy on Ultracote? - 12/19/2012 1:17 AM
speedracerntrixie
Score: 194
Status: offline
If it gets soft you may want to try some acetone while it is soft. May take a few attempts but I think it will work.
Hide Signatures
(in reply to JPMacG)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
