1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX LIMIT .15 ***-    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX LIMIT .15 ***- Page: [1] 2 3 4 5   next >   >>
Login
1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX LIMI... - 12/8/2012 4:55 AM
skaliwag
Score: 100
Last Login: 5/19/2013
Status: online
Lets look and talk about 1/2A Bipes. And not ignore the connection of the upper wing to the rest of the airplane and the cabanes.
Just remember ... Real Airplanes have Round Engines and 2 WINGS
_____________________________
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
       Post #: 1
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 9:07 AM
ChicaWolverina
Score: 100
Last Login: 12/9/2012
Status: offline
You're talking structure, and how overly simplified they are at this scale? And does anyone even bother to follow the original hidden secret of the BU-133's negative upper plane incidents... I think not?
"What's locked up in their star ships, this needs to be known!"
Hovering... so passe now!
Hide Signatures
(in reply to skaliwag)
       Post #: 2
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 1:47 PM
LittleRock
Score: 105
Status: offline
Define wing and round !!
Hide Signatures
(in reply to ChicaWolverina)
       Post #: 3
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 2:53 PM
MJD
Score: 125
Last Login: 5/13/2013
Status: offline
If the cylinder is round, does that count?
I try to be pessimistic, but why bother?
Hide Signatures
(in reply to LittleRock)
       Post #: 4
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 3:39 PM
combatpigg
Score: 376
Status: offline
The greatest all around...semi scale RC plane I've ever flown was the Goldberg Ultimate. I believe the structure was purely 0-0-0 between both wings and the tail. The only deviation was a few degrees of right thrust to compensate for the 14 to 15 inch diameter props that many builders were using on it.
Full size span was 54 inches IIRC and I shrank it to about 24" [IIRC] for a 1/2A project. Built it as light as a feather, rigged it with Spiderline pull / pull linkages, HS55s all around, tiny battery & RX, cellophane covering...just did it as light as I possibly could.
IIRC it was 12 ozs RTF.
Tried it with .049-.061 glow..6x3 prop and it was pretty lively but nothing compared to the OS 1.20 powered version
Tried it .049 diesel with 7x3 prop [both TD & AME]..basically the same stuff
Tried Norvel .074 and 7x3 prop..much, much better. Still not enough for KE loops, but now it was capable of everything else in a big way. I still have both of the ones I built hanging in the rafters.
Another 1/2A bipe I built from pictures in a huge book I got at a used book store.
The 1930's DeHavilland Dragon Rapide. It has about 54 inches of span, built 0-0-0, powered with 2 fairly weak TDs fed from a single bladder that has feed lines coming out both ends. All pull / pull linkages, it turned out very light and slightly tail heavy. Not just tail heavy [still very controllable], but "bouncy" in choppy air. So I experimented by filling up the cabin / fuselage with lug nuts and this made it fly better. With both engines running it will hold altitude in KE flight and with 1 engine running it can be held nose up and tilted so that the lone engine running doesn't put it into a spin. 2 TDs running sound cool on this plane that flies like a pretty well powered glider. The engines are hung below the zero line of the plane's vertical CG and they needed considerable down thrust to compensate. I tested for the proper angle with the engines running and the model held at the wing tips loosely to feel for neutral / level AoA. I filed the backside of the Dubro engine mounts to acheive the proper angle. This plane sits in the rafters as well, waiting for another day...it's cellophane covering still looks OK.
I strongly recommend trying both projects if you are a modeler who likes little challenges without spending too much money or time.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to MJD)
       Post #: 5
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 4:11 PM
skaliwag
Score: 100
Status: online
MJD. Multiple round cylinders and a con rod that looks like a spider
LittleRock ....Wings .... a couple of boards. One over the pilots head and one under his butt.
Hide Signatures
(in reply to combatpigg)
       Post #: 6
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/8/2012 8:56 PM
gcb
Score: 100
Status: offline
Here are a couple of Little Bipes:
George
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 7
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 12:29 AM
MJD
Score: 125
Status: offline
Looks like a Scientific something-or-other..?
Hide Signatures
(in reply to gcb)
       Post #: 8
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 1:51 AM
skaliwag
Score: 100
Status: online
The original Skaliwag .... When a K was a C, or a C was a K...
Left to right. PAW .061, PAW .049, Norvel .049 with a diesel head.
Edit ... Tried to crop the picture.
Click for fullsize
< Message edited by skaliwag -- 12/9/2012 2:48 AM >
Hide Signatures
       Post #: 9
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 3:16 AM
skaliwag
Score: 100
Status: online
Reply to post #2.
Can you post some links to the BU-133 principle you mentioned. (I do it the other way, positive on top as per Joe Wagner's Dakota)
Hide Signatures
       Post #: 10
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 4:10 AM
combatpigg
Score: 376
Status: offline
That's a great looking fleet GCB & Skaliwag...! They look pretty tiny, too..... ...[but not too tiny, you can never get too tiny.]
Hide Signatures
       Post #: 11
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 4:12 AM
skaliwag
Score: 100
Status: online
Bipes Rock, Roll and Rule.
Hide Signatures
       Post #: 12
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 3:40 PM
BobHH
Score: 100
Status: offline
Oh, I have a bipe!! Here is my Christy bipe with Tee Dee .010.
Bob Harris
Click for fullsize
Hide Signatures
       Post #: 13
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 3:45 PM
skaliwag
Score: 100
Status: online
Pure Aero P**n.
Hide Signatures
(in reply to BobHH)
       Post #: 14
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/9/2012 6:55 PM
ffkiwi
Score: 105
Status: offline
quote:
ORIGINAL: BobHH
Bob Harris
Where do you get hold of a plan for this little cutie?
ChrisM
'ffkiwi'
Hide Signatures
(in reply to BobHH)
       Post #: 15
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 3:12 AM
skaliwag
Score: 100
Status: online
Another Bipe. This one from the now no longer in production Early R/C.. The Schoolgirl ..... Do you have a better picture Bob?
Click for fullsize
Hide Signatures
(in reply to ffkiwi)
       Post #: 16
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 3:38 AM
vauxhall
Score: 100
Last Login: 3/19/2013
Status: offline
This C/L Tiny Tot was a bit of fun a couple of years ago, Norvel .061.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 4:43 AM
exocet-RCU
Score: 100
Status: offline
Both the Christy and the School Girl are REALLY cute! I think I see a couple projects for S.M.A.L.L. 2013.
Tim
Hide Signatures
(in reply to vauxhall)
       Post #: 18
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 5:13 AM
skaliwag
Score: 100
Status: online
Perfect... Got the tiny airplane juices pumping ... Woooh Hooooo.
Hide Signatures
(in reply to exocet-RCU)
       Post #: 19
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 1:14 PM
BobHH
Score: 100
Status: offline
Steve, here is a pic of mine at the VRCS flying. This one flew with a Cox Medallion and throttle sleeve. A great little bipe.
Bob Harris
Click for fullsize
Hide Signatures
       Post #: 20
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 9:06 PM
gcb
Score: 100
Status: offline
quote:
ORIGINAL: MJD
Would you believe...Scientific "Little Bipe"?
George
Hide Signatures
(in reply to MJD)
       Post #: 21
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 11:25 PM
BobHH
Score: 100
Status: offline
And lets not forget the Flipper!!! Here's mine!!
Bob Harris
Click for fullsize
Hide Signatures
(in reply to gcb)
       Post #: 22
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/10/2012 11:28 PM
MJD
Score: 125
Status: offline
quote:
ORIGINAL: gcb
Would you believe...Scientific ''Little Bipe''?
George
LOL! Now there's an appropriate name. I probably could have found it in the AHC ad in an old mag.
Hide Signatures
(in reply to gcb)
       Post #: 23
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/11/2012 12:35 AM
skaliwag
Score: 100
Status: online
Don't forget this one. A beat up Dakota with a wore out Wen Mac
Click for fullsize
Hide Signatures
(in reply to MJD)
       Post #: 24
RE: 1/2A Biplanes.*** LIMIT***. .010 to .049? *** MAXX ... - 12/11/2012 1:34 AM
vauxhall
Score: 100
Status: offline
Did someone say "Dakota". Heres my Testors/McCoy build. Flew it just the other day, bags of low tech fun. Flick and toss.
Click for fullsize
< Message edited by vauxhall -- 12/11/2012 12:17 PM >
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
