RE: WHATS YOUR TAKE ON WEIGHT?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> RE: WHATS YOUR TAKE ON WEIGHT?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 7:17 PM
sensei
Score: 176
Last Login: 5/19/2013
Status: offline
That is a sweet looking bird you got there.
Bob
_____________________________
Fly It Like You Stole It!!!
Hide Signatures
(in reply to joebahl)
       Post #: 26
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 7:29 PM
speedracerntrixie
Score: 189
Last Login: 5/18/2013
Status: online
Lighter is always better. The old argument that a heavier airplane is better in high winds is hogwash. It just means the airplane is poorly set up and reacts poorly to airspeed variations. Wind = airspeed variations.
Hide Signatures
(in reply to sensei)
       Post #: 27
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 8:24 PM
acerc
Score: 221
Status: offline
I like my planes, like I like my women. Lean and fast.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 28
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 8:46 PM
JohnBuckner
Score: 342
Status: offline
Lite Flys Better
Lite Crashs Better
Lite Sell Better
Those are indisputable facts of life. The previous referance to full scale general aviation jets is irrelavant. Now I have never been typed in any jets but the discussion specifically to the cessna jet and a requirement for nose weight in some loading configurations has nothing to do with performance it is entirely a CG consideration and keeping that airplane within limits with certain loading situations.
I have however flown many old piston popping, cylinder blowing full scale helicopters that indeed required forward ballast when being flown with no load other than a lightweight pilot, this to avoid exceeding cyclic limits in flight. That of course has eveything to do agine with center of gavity and not because being heavy flys better.
I have also flown full scale High performance sailplanes which did have CG ballast tanks for water and the purpose of those tanks was to increase speed between the boomers on a cross country and this only in certain conditions. Of course the water was dumped when the boomers disapated and you needed to eek every last bit of performance from the ship.
None of that is material to this discussion and the way we fly our RC models:
Lite flys better, Lite crashes better and lite sells better
John
"Keep your controllines tight"
Hide Signatures
(in reply to acerc)
       Post #: 29
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 8:59 PM
scale only 4 me
Score: 314
Status: offline
quote:
ORIGINAL: speedracerntrixie
Unless it's a slope glider,, very common to add ballast for better penetration
Hide Signatures
       Post #: 30
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 9:09 PM
sensei
Score: 176
Status: offline
Agreed, a heavier airplane has more penetration energy in windy or gusty conditions however a lighter airframe dampens out the effect of those conditions faster then its porky counterpart and two aircraft alike, one light and one heavy flying side by side in strong gusting wind will show no difference flying across the field. We have actually played this out more than once with my 28 lb. Carden 260 and a 43 lb. Carden 260 in 35 mph wind gusting to 40+. The only real thing that we notices was the lighter of the two was more fun to play with in a freestyle sense under those conditions.
Bob
Hide Signatures
       Post #: 31
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 9:23 PM
Speedy-Gonzales
Score: 141
Last Login: 4/13/2013
Status: offline
I'm going to throw some physics at you all here and try not to cause pandamonium. If you don't agree with it then so be it.
OK....here goes it!
800 sq/in. is the breaking point to being able to fly with higher wing loadings but wing geometry also starts to come into play. You must start considering things like washout in the outer wing panels and flaps since angle of attack changes during takeoff,landing, and SLF. Also application of power changes during these stages of flight.
There is also a very interesting study ,as many of you know, concerning "Reynolds numbers" when calculating how much you can load a wing and still maintain good flying characteristics. One of the points I found very interesting is that the actual wing area is not the only factor when calculating the loading or lifting capabilities of a wing. The wing's "VOLUME" is to be considered. Meaning.....how much volume does the wing displace in the air. This would be like filling up your bathtub and submerging a sealed or solid object ( i.e. your wing ) into the water to measure the volume it displaces in the water.
This is why a Boeing 747 can weigh and lift the incredible loads that it does comparred to the marginal lifting capability of even a giant RC model. If you don't agree with my use of the word "marginal" then put a brick in your model next time you fly it and see what a difference it makes.
Here it is in much simpler terms:
For a 1/4 scale model to be able to lift 1/4 of the actual weight of the full scale aircraft the molecules of the air would have to be 4 times as dense ( see examples below ). As wing area and volume increase there is a "snowball" effect thus my comment on the 800 sq/in. as being a breaking point for increased wing loadings. The density of air molecules is constant unless we are talking flight at higher altitudes.
1/3 scale= 3x air density
1/4 scale= 4x air density
1/6 scale= 6x air density
1/8 scale= 8x air density
Care to dig deeper? Go here:
http://www.grc.nasa.gov/WWW/K-12/airplane/reynolds.html
To put all this in understandable terms....YES!....Lighter is better for model aircraft.
I'm not that smart but I did stay at a "Holiday Inn Express" last night!
< Message edited by Speedy-Gonzales -- 12/10/2012 12:12 AM >
Hide Signatures
(in reply to JohnBuckner)
       Post #: 32
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 9:34 PM
red head
Score: 135
Status: offline
Taste better to . ENJOY !!! RED
Hide Signatures
(in reply to Speedy-Gonzales)
       Post #: 33
RE: WHATS YOUR TAKE ON WEIGHT? - 12/9/2012 9:35 PM
red head
Score: 135
Status: offline
Maybe I'll figure out the quote later . lol ENJOY !!! RED
Hide Signatures
(in reply to red head)
       Post #: 34
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 12:25 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: Speedy-Gonzales
OK....here goes it!
There is also a very interesting study ,as many of you know, concerning ''Reynolds numbers'' when calculating how much you can load a wing and still maintain good flying characteristics. One of the points I found very interesting is that the actual wing area is not the only factor when calculating the loading or lifting capabilities of a wing. The wing's ''VOLUME'' is to be considered. Meaning.....how much volume does the wing displace in the air. This would be like filling up your bathtub and submerging a sealed or solid object ( i.e. your wing ) into the water to measure the volume it displaces in the water.
This is why a Boeing 747 can weigh and lift the incredible loads that it does comparred to the marginal lifting capability of even a giant RC model. If you don't agree with my use of the word ''marginal'' then put a brick in your model next time you fly it and see what a difference it makes.
For a 1/4 scale model to be able to lift 1/4 of the actual weight of the full scale aircraft the molecules of the air would have to be 4 times as dense ( see examples below ). As wing area and volume increase there is a ''snowball'' effect thus my comment on the 800 sq/in. as being a breaking point for increased wing loadings. The density of air molecules is constant unless we are talking flight at higher altitudes.
I'm not that smart but I did stay at a ''Holiday Inn Express'' last night!
All very good points and cubed loading and a few other things like aspect ratios, airfoil and the list go on and on but in the simplest form just remember that the smaller an airplane is the less efficient the load carrying capacity will be so added weight is critical and vice versa for the larger stuff. So if you apply just some of this logic during a build it has potential to pay of huge dividends on maiden day.
Bob
Hide Signatures
       Post #: 35
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 12:45 AM
Rob2160
Score: 183
Last Login: 5/16/2013
Status: offline
Not sure if I totally agree with this.. the foamies definately fly nicer in strong winds and turbulence when slightley heavier....  Subjectively...
The planes are set up the same and the battery location does not affect CG.. it is simply extra weight with a bigger battery, makes it more stable in severe turbulence..
Real gliders also use water ballast.. an interesting argument FOR extra weight..
http://www.ddsc.org.au/documents/manuals/Flying%20with%20Water%20Ballast.pdf
Steady constant winds won't change airspeed.. only the groundspeed will change.. turbulent constantly changing wind will give airspeed variations for sure.
What do you mean by "Reacting poorly to airspeed variation"
Just didn't quite understand what you mean't ... what is a "poor reaction"
..... frakkin cylons...
Hide Signatures
       Post #: 36
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 12:55 AM
Mr-Punk
Score: 105
Status: offline
OK....here goes it!
Speedy,
You hit the nail on the head!  Yep lighter does fly better!  That is also why it's hard to do "real scale" stuff with our models.  Lighter is always better in models.  I remember when I built a 20 ounce Gentle Lady rtf.  It flew awesome.. actually lost it, in a thermal.  I sanded everthing outside the CG area to increase its response to thermals.   It flew two hecks of a bit better than my 34 ounce Gentle Lady arf now.
There is reason why bird's bones are hollow.  :-)
Peace guys I love this discussion.
J
Hide Signatures
       Post #: 37
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 1:21 AM
speedracerntrixie
Score: 189
Status: online
quote:
ORIGINAL: Rob2160
Rob, let see if I can do a better job of explaining this. First lets tackle the silplane an ballast thing. Think as wing loading as potential energy. The sailplane wil convert this potential energy into kinetic energy by diving. The higher the potential energy ( to a degree ) the less degree of a dive is required to maintain the optimum airspeed for the particular airfoil. This is refered to as L/D. You have no doubt seen this while flying your foamies.
Ok now power airplanes and more specific aerobatic and race planes that I have most experience with. A properly trimmed airplane will recat to the wind less because all the peices of the puzzle are working together. The result is what I call ' Wind Damping "  A simple example of this is an airplane that is set up nose heavy and carrying some up trim. As the airplane is flying into the wind and the wind speed increases, the up trim becomes more effective and the airplane ballons. The opposite happens when the gust dissipates.
Hide Signatures
(in reply to Rob2160)
       Post #: 38
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 2:33 AM
ARUP
Score: 134
Status: online
quote:
ORIGINAL: JohnBuckner
Its a safe bet that lite flys better and crashs better. The later is always a factor unless your one that bins an airplane for minor damage.
As far as manufacturers go, most if not all have learned to fib a bit since they have learned Lite not only flys better and crashs better but Lite sells better as well, thats a fact
John
Exactly! This 54" span one cartwheeled (uh... a gust of wind did it... ???, lol) on the tarmac once and nothing got broken! The wing loading was 11oz/sq.ft. Lighter flies better and crashes better. Good one John and accurate assessment!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 39
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 4:24 AM
MTK
Score: 203
Status: online
Some of you may have heard about the Extreme Flight 78" Extra. It is very light, intended for either electric or small gassie, around 30cc. The model usually "assembles" (it's an ARF so not really built by me) to around 12 pounds. It's a big plane for 12 pounds. The Chinese factory where it is being built does a good job with both weight and accuracy
Anyway, a couple years ago I decided to put a piped DLE55 in it. With some careful planning and a redo of the engine box and landing gear, I added a soft mount and the piped DLE and picked up only about 4 ozs extra. The point is that at 12 pounds 4 ozs and a DLE55 up front, some might think this is not a good thing and the engine might fly clean off the model. NOT SO!! It flew great with its 35 pounds of thrust give or take.
The major take away is that most models are way overbuilt and are unnecessarily porky as a result. This was proof enough and on a Chinese built ARF no less.
After flying lightness for the better part of 2 decades, I can tell immediately when one is porky. They just don't perform as well in the air and landings can be loads of fun when they stall and fall. My Take!!
Regards,
MattK
Hide Signatures
       Post #: 40
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 9:32 AM
da Rock
Score: 265
Status: offline
quote:
ORIGINAL: Rob2160
It's not really an argument for extra weight, but an argument for adjusting wing loading for flight conditions. Gliders add ballast when specific conditions happen, and they're conditions that push the envelope for that glider's design. That glider was designed to work best in average wind etc, and there isn't average wind etc when that glider is going to be flown.
Ballast in full scale gliders is a good argument for adjusting for conditions, little more. Fly that glider with ballast in the conditions it's design was optimized for and you'll see the reason for building light.
Good flying wit ya today
Hide Signatures
       Post #: 41
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 12:23 PM
sensei
Score: 176
Status: offline
Also sailplanes in general have very high aspect ratio wings along with high L/D ratios, I mean most really good sailplanes have about as low a drag component as possible. Most sport models, aerobatic models, and war bird models have relatively low aspect ratio wings in comparison and have allot more drag so adding weight to both is really comparing apples to oranges.
Bob
Hide Signatures
(in reply to da Rock)
       Post #: 42
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 12:55 PM
JohnBuckner
Score: 342
Status: offline
Rob first water ballast in high performance sailplanes is not the norm and not all sailplanes use this in fact it is in the minority. It is not a good argument for extra weight in our models.
Ballast is caried for one reason and that is to increase speed between the boomers (thermals) on a cross country flight. In fact it is seldom carried if no cross country is contemplated.
The L over D or glide ratio is improved with the ballast but with payoff of greater minimum sink. So while it does alter the character of performance it is really only good for decreasing the time between the boomers and this has no practical purpose in our typical RC flight and the way we fly our models.
Back in the seventies there was a wonderful informal event every year at Bishop Ca. in November simply called the Wave Camp and was a gathering of all sorts of sailplanes that lasted about a week. Most years the elusive waves never materialized and we spend most of the time flying each others aircraft. My contribution was my Fournier RF-4d motorglider which was quite popular and my ship got lots of publicity of the time as this event was heavily covered by the popular aviation press of the time.
I did get some fantastic flight in in several high performance glass ships that has water ballast but it was seldom used, that included if my memoriy is correct an open class Cirrus and Diamant, this was a very long time ago.
My favorite however was Peter Lerts German wood Zugfolgel (spelling) which was one of the last high performance wood ships.
The usage of water ballast in some high performance full scale has no paralell because of the way we fly our airplanes and is not a reasonable argument for heavy airplanes.
The only reasonable exception is possibly some forms of RC Ridge soaring or dyanmic soaring.
John
Hide Signatures
       Post #: 43
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 2:42 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: Rob2160
So basically you are saying that an aircraft with the correct CG will be much more stable and fly better than an aircraft that is either too nose heavy or too tail heavy?   Yep.. couldn't agree more..!
Hide Signatures
       Post #: 44
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 2:43 PM
Rob2160
Score: 183
Status: offline
John
Sorry, maybe I didn't explain correctly.. I wasn't using the Glider example to argue for putting more weight in the models.. just that lighter is not always better in all circumstances and the glider with ballast was an example of that.
Hide Signatures
       Post #: 45
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 2:57 PM
JohnBuckner
Score: 342
Status: offline
No problem Rob and its all in the interest of learning for us all. I discovered long ago that when the learning stops then the interest in the hobby/sport/passion stops.
John
Hide Signatures
       Post #: 46
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 5:15 PM
GerKonig
Score: 191
Status: offline
I have a electric Telemaster 72" wingspan that flies better with the 4 cell pack than the 3 cell. The 4 cell is heavier. BUT when for fun I installed some giant balloon tires (to look like a bush plane), I compensated the CG shift, but it DID NOT LIKE IT. The additional weight did not help at all... Had to put the light tires back. So, my take is that there is a limit, but in general light is better.
A 80" warplane that weights 30 pounds is a really good "wind penetrator" almost as good a a brick...
I remember the old times when I had a buddy that liked to build scale 60 size warplanes. He used to glass them, and over paint, and add details. They were legit led sleds, with a narrow flight envelope like: Max speed 72 mph, cruise speed 70 mph stall speed 68 mph... all his models had retracts, one landing, and the landing gear was gone. Not easy to be heavy, and have to come in hot, and make a nice landing on grass using small wheels (scale).
Gerry
Hide Signatures
       Post #: 47
RE: WHATS YOUR TAKE ON WEIGHT? - 12/10/2012 6:10 PM
flycatch
Score: 118
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: GerKonig
I have a electric Telemaster 72'' wingspan that flies better with the 4 cell pack than the 3 cell. The 4 cell is heavier. BUT when for fun I installed some giant balloon tires (to look like a bush plane), I compensated the CG shift, but it DID NOT LIKE IT. The additional weight did not help at all... Had to put the light tires back. So, my take is that there is a limit, but in general light is better.
A 80'' warplane that weights 30 pounds is a really good ''wind penetrator'' almost as good a a brick...
Gerry
You summed it up nicely.
Hide Signatures
(in reply to GerKonig)
       Post #: 48
RE: WHATS YOUR TAKE ON WEIGHT? - 12/11/2012 12:13 AM
ckreef
Score: 105
Status: offline
quote:
ORIGINAL: ARUP
I agree. Lately I fly mostly balsa EP, ARF's. They are built light and then I convert them to glow using a larger then required engine.  They are still light and slightly overpowered. They fly excellent and if you have a moderate landing issue the light airframe holds up better.
If you build for crash strength you're just fooling yourself. If they come down hard they all break weather built light or strong.
Hide Signatures
(in reply to ARUP)
       Post #: 49
RE: WHATS YOUR TAKE ON WEIGHT? - 12/11/2012 12:21 AM
j.duncker
Score: 121
Status: offline
On a POWERED aircraft there is no advantage to increasing the weight. However on a GLIDER in certain conditions there is a significant benefit.
I have borrowed this from Wiki
quote:
Maximizing average speed
Soaring pioneer Paul MacCready is usually credited with developing mathematical principles for optimizing the speed at which to fly when cross-country soaring,[49]:11-10 although it was first described by Wolfgang Späte in 1938.[50] The speed to fly theory allows the optimal cruising speed between thermals to be computed, using thermal strength, glider performance and other variables. It accounts for the fact that if a pilot flies faster between thermals, the next thermal is reached sooner. However at higher speeds the glider also sinks faster, requiring the pilot to spend more time circling to regain the altitude. The MacCready speed represents the optimal trade-off between cruising and circling. Most competition pilots use MacCready theory to optimize their average speeds, and have the calculations programmed in their flight computers, or use a "McCready ring", a rotatable bezel on the glider's variometer to indicate the best speed to fly. The greatest factor in maximizing average speed, however, remains the ability of the pilot to find the strongest lift.[23]:56
On cross-country flights on days when strong lift is forecast, pilots fly with water ballast stored in tanks or bags in the wings and fin. The fin tank is used to reduce trim drag by optimizing the center of gravity, which typically would shift forward if water is stored only in the wings ahead of the spar.[49]:5-13 Ballast enables a sailplane to attain its best L/D at higher speeds but slows its climb rate in thermals, in part because a sailplane with a heavier wing loading cannot circle within a thermal as tightly as one with a lower, unballasted wing loading. But if lift is strong, typically either from thermals or wave, the disadvantage of slower climbs is outweighed by the higher cruising speeds between lift areas. Thus, the pilot can improve the average speed over a course by several percent or achieve longer distances in a given time.[23]:63 If lift is weaker than expected, or if an off-field landing is imminent, the pilot can jettison the water ballast by opening the dump valves.[23]:64
On days with particularly strong and widespread lift pilots can attain high average speeds by alternating periods of fast flight with pull-ups, merely slowing down in areas of lift without deviating from the course. This 'dolphining' technique can result in high average speeds because the height lost can be minimised until particularly strong lift is encountered when circling would be most effective.
In the modelling world ballasting a glider would be done on days when the lift was good and more speed was desired, eg when racing.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to flycatch)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.469RCU1
