RE: Steel wheel panther help needed    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Steel wheel panther help needed
Page: <<   < prev  1 [2]
Login
RE: Steel wheel panther help needed - 12/10/2012 1:18 PM
tomhugill
Score: 118
Last Login: 5/21/2013
Status: offline
 Are they the mato steel tiger wheels? What adaptation did they need?
_____________________________
Tamiya:leopard 2a6, king tiger, Porsche king tiger, panther g, jagdpanther. Hooben: elefant, t-55. HL panther f, Jagdpanthe
Hide Signatures
(in reply to TheBennyB)
       Post #: 26
RE: Steel wheel panther help needed - 12/10/2012 1:43 PM
TheBennyB
Score: 105
Status: offline
Yes, they are the Mato steel wheels.  If memory serves me right, they needed to be drilled out for the axel and bushings, then spaced to fit the panther track width.
AAF # 111284-25
A.C.E. member
Hide Signatures
(in reply to tomhugill)
       Post #: 27
RE: Steel wheel panther help needed - 12/10/2012 7:29 PM
1sgt
Score: 118
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: TheBennyB
BennyB,
That is a great looking Panther. My question is do the steel wheels have a rubber tire around them. In your pic looks like you painted the rim flat black, or is that just wear?
Jim
Hide Signatures
       Post #: 28
RE: Steel wheel panther help needed - 12/11/2012 4:39 AM
mustclime
Score: 106
Status: online
I did a little sufing looking on the web for steel wheel panther info....found this..
hope they help.
That which does not destroy me just makes me more irritable
Hide Signatures
       Post #: 29
RE: Steel wheel panther help needed - 12/11/2012 11:27 AM
TheBennyB
Score: 105
Status: offline
quote:
ORIGINAL: 1sgt
quote:
ORIGINAL: TheBennyB
BennyB,
Jim
Jim,
  The steel wheel did not have a rubber outer tire,  what you see is just wear like you thought.
AAF # 111284-25
A.C.E. member
Hide Signatures
(in reply to 1sgt)
       Post #: 30
RE: Steel wheel panther help needed - 12/11/2012 12:41 PM
tomhugill
Score: 118
Status: offline
Scott those pics are exactly what I was after cheers matey!
Hide Signatures
       Post #: 31
RE: Steel wheel panther help needed - 1/8/2013 3:12 AM
Rctank2012
Score: 100
Last Login: 5/20/2013
Status: offline
 I don't mean to jump in on this thread but can someone help me with my Panther project? I did search but could not find an answer. I want to add the plastic steel looking road wheels to the last station only. What parts do I need and how to I mod them to fit? Thanks
Hide Signatures
       Post #: 32
RE: Steel wheel panther help needed - 1/8/2013 3:55 AM
MAUS45
Score: 100
Status: offline
Rctank2012, Try this thread....
http://www.rctankregiment.com/rctankforum/viewtopic.php?f=71&t=4218
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
(in reply to Rctank2012)
       Post #: 33
RE: Steel wheel panther help needed - 1/8/2013 4:09 AM
Rctank2012
Score: 100
Status: offline
 Thanks for the reply. I am converting a heng long panther g. Are the tamiya king tiger wheels the same diameter or do I need to find the hl king tiger wheels?
Hide Signatures
(in reply to MAUS45)
       Post #: 34
RE: Steel wheel panther help needed - 1/8/2013 5:26 AM
MAUS45
Score: 100
Status: offline
I would think the HL King tiger wheels would work. Just not sure. The Tamiya Tiger II wheels should be close, but here again I do not have a HL Panther G to compair them to. There has to be someone on this site that may have a couple for you to try. You may want to try Mustclimb. He just trashed a HL Tiger II to create a E-100. He may have two Tiger II wheels left over or can point you in the right direction to get some spares, because I am not sure if he needed more then the Tiger II had or not. The AAF, Girl Tankett can get you spare Tamiya Tiger II Wheels as well. Here is their web site.....
http://shop.aaftankmuseum.com/
< Message edited by MAUS45 -- 1/8/2013 5:47 AM >
Hide Signatures
       Post #: 35
RE: Steel wheel panther help needed - 1/9/2013 3:44 PM
karel47
Score: 149
Status: offline
 the turret was an F turret used from asiatam widen up so the turret covers the whole turretplate , the asiatam F is to small
we used the 88mm from the king tiger onto it just like it was designed, its total weigt would be around the 50 tons
Click to see fullsize image.
Click for fullsize
< Message edited by karel47 -- 1/9/2013 4:05 PM >
PanzVI-J,ShermanM4A4,PershingM26,KTPorsche2x,KTHenshel Late3x-Early1x,TigerI 3x,JP,Panther,Jagdtiger;PantherIIta;PanthHL;Stu
Hide Signatures
       Post #: 36
RE: Steel wheel panther help needed - 1/9/2013 3:55 PM
karel47
Score: 149
Status: offline
 here are a few pics of mine, i bought it ,
... changed it so no comments any more or you justcan find it out on your own ... i think you understand my point jeff ...
we used the tamiya panther chassis and its  kt wheels on this monster panther, 2 were made ... one was destroyed by the americans who didn't realise it was a brandnew study and test object
the glasis plate was changed of angle , the axle of the wheels were changed according the pantsertract of the panther II ... bas builded my chassis we did a lot of searchwork ... and its 90 % correct  ... even rivetcounter was wondered, it was the closed Panther II model in 1/16 one could scratch ... nothing is proving ... different opinions and the original plane was destroyed too ... not much to going onto
but the result is beautiful , enjoy it
the kt track is wrong, its to wide ... kt transporttracks will be fitting better !!!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: Steel wheel panther help needed - 1/11/2013 4:13 AM
bowlman
Score: 104
Status: offline
here is one with KT Transport Tracks .
Jimmy
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to karel47)
       Post #: 38
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
