tail wheel for SIG kadet sr..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> tail wheel for SIG kadet sr..
Page: [1]
Login
tail wheel for SIG kadet sr.. - 12/8/2012 10:43 PM
tazzzz
Score: 100
Last Login: 5/18/2013
Status: offline
Im turning my SIG kadet sr. into a taildragger,,,anyone know a good way to set up a good reliable workable tailwheel? I have various tailwheel assys. Just need to know a good way to link it up;
THX,,,,TAZZZZ
Hide Signatures
       Post #: 1
RE: tail wheel for SIG kadet sr.. - 12/8/2012 11:02 PM
gene6029
Score: 120
Last Login: 5/21/2013
Status: offline
Here's a few pics of my home made tailwheel. I used a carbon fiber shaft that passes thru the fuse up thru the stab. The wire for the tail wheel passes thru it & isbent 90 degrees into the rudder. The bottom is bent to conform to any tail wheel you may have....Gene
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tazzzz)
       Post #: 2
RE: tail wheel for SIG kadet sr.. - 12/8/2012 11:21 PM
tazzzz
Score: 100
Status: offline
Im not quite sure,, does the shaft mount into the base of the rudder?
Hide Signatures
(in reply to gene6029)
       Post #: 3
RE: tail wheel for SIG kadet sr.. - 12/8/2012 11:34 PM
tazzzz
Score: 100
Status: offline
I got it,,,dont mind my 90wt brain fluid. Thanks for the help.
Hide Signatures
       Post #: 4
RE: tail wheel for SIG kadet sr.. - 12/11/2012 2:00 AM
airbusdrvr
Score: 141
Status: offline
These are easy to install and don't transmit loads back to the servo. Tower Hobbies part number LXFV47. I've used them for years whenever possible.
_____________________________
UltraSport Brotherhood #17
Hide Signatures
       Post #: 5
RE: tail wheel for SIG kadet sr.. - 12/11/2012 3:36 PM
jaka
Score: 158
Status: offline
Hi!
Most of the time it works just as good a with an all swiveling tail wheel!
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 6
RE: tail wheel for SIG kadet sr.. - 12/11/2012 7:45 PM
Top_Gunn
Score: 134
Last Login: 5/22/2013
Status: offline
Another way to go is to put the tail wheel on a separate servo, connected to the rudder servo with a Y harness. Or, if your Kadet Sr. is a 3-channel plane, just put the tail wheel servo on channel four. A pull-pull setup is ideal for a tail wheel on its own servo, but you could use a pushrod as well.
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
(in reply to jaka)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
