I have a Mule on the firewall !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> I have a Mule on the firewall !
Page: [1]
Login
I have a Mule on the firewall ! - 12/9/2012 1:12 AM
JEanes
Score: 100
Last Login: 6/19/2013
Status: offline
33% Edge with a 3W-80 on the nose. This thing kicks like a mule when trying to crank it. I bought it second hand with only about a gallon of fuel thru it. I have severely bruised two of my fingers not once but twice, using a welders glove ! I can see that the timing has been tinkered with along the way. So being that it kicks so bad, I moved it some myself. To much and I lost the top end RPM's. I got desperate today and "kick started" it.....even kick me back ! Anyone else have this with the big single cylinders ? [>:]
_____________________________
" Ain''t Nothing Like A Good Bean " !
Hide Signatures
       Post #: 1
RE: I have a Mule on the firewall ! - 12/9/2012 3:48 AM
speedracerntrixie
Score: 194
Status: offline
From my experience three things can contribute to this. Timing being too far advanced, getting it too wet and running low octane. I havent owned any 3W singles but the 70 and 170 twins that I have owned ran really well on 91 octane with factory set timing.
Hide Signatures
(in reply to JEanes)
       Post #: 2
RE: I have a Mule on the firewall ! - 12/9/2012 4:17 AM
earlwb
Score: 599
Status: offline
Sounds like the static timing is set to far in advance. Thus it still is advanced too much for starting. What is your static timing set to at this time?
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 3
RE: I have a Mule on the firewall ! - 12/9/2012 6:37 AM
MetallicaJunkie
Score: 243
Last Login: 6/16/2013
Status: offline
quote:
ORIGINAL: JEanes
33% Edge with a 3W-80 on the nose. This thing kicks like a mule when trying to crank it. I bought it second hand with only about a gallon of fuel thru it. I have severely bruised two of my fingers not once but twice, using a welders glove ! I can see that the timing has been tinkered with along the way. So being that it kicks so bad, I moved it some myself. To much and I lost the top end RPM's. I got desperate today and ''kick started'' it.....even kick me back ! Anyone else have this with the big single cylinders ? [>:]
i had that same problem with my 3w80.... i swapped out the 3w ign for an rc xcell...i eyeballed the stock location of the hall sensor and did my best to put the rcxcell in the same spot....when it came time to start it, it gave me a good whack when it back fired.....it left my index finger tip numb for a couple of months.... luckily it was a blunt Belia prop and not a thin bladed prop.... i checked the timing and it was at about 35 deg....so i brought it down to 27 and problem solved.... another thing to take into consideration is to follow through solidly when hand starting it...
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
       Post #: 4
RE: I have a Mule on the firewall ! - 12/9/2012 4:47 PM
mikes68charger
Score: 106
Last Login: 6/18/2013
Status: offline
Or use a big boy starter, I got a monster starter used of this site for $125 and use a old 3000mah 4s 40c lipo I had laying around connected to it. Workds great!
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 5
RE: I have a Mule on the firewall ! - 12/9/2012 6:03 PM
JEanes
Score: 100
Status: offline
Here what I found this morning. The timing WAS high. I set the piston at TDC, set my pointer to 0, Reset the pickup to 28 degrees. Funny that setting is as low as can be set. This engine is fitted with an ignition that was made for CH by Recell. It is Version 2, model A: 01 L. Does this thing have auto advance ?
Hide Signatures
(in reply to mikes68charger)
       Post #: 6
RE: I have a Mule on the firewall ! - 12/9/2012 6:22 PM
speedracerntrixie
Score: 194
Status: offline
Yes that ignition has auto advance.
Hide Signatures
       Post #: 7
RE: I have a Mule on the firewall ! - 12/9/2012 6:37 PM
All Day Dan
Score: 156
Status: offline
You want to make sure that the spark plug fires at 28 degrees BTDC. Dan.
http://www.youtube.com/watch?v=GBXFpxWg7vY
Dan
Hide Signatures
       Post #: 8
RE: I have a Mule on the firewall ! - 12/9/2012 10:27 PM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: JEanes
RCexl has auto-RETARD of ~21° during starting and low rpm operation. It restores gradually back to your set timing between 2000 and 4000 rpm
BTW, high performance engines like lower advance, like 23 - 26° BTDC. Try it.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> I have a Mule on the firewall !
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
