Byron/Iron Bay F4U Corsair build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Byron/Iron Bay F4U Corsair build
Page: [1] 2 3 4 5 6 7   next >   >>
Login
Byron/Iron Bay F4U Corsair build - 12/9/2012 1:29 AM
warbird_1
Score: 159
Last Login: 5/19/2013
Status: offline
I started working on this in September but had to back burner it to get a home project done. After i got started on it i found many parts missing and crappy workmanship on some things that i was able to fix myself. I'm really disappointed in the quality of this kit as far as missing parts etc. i drove all the way down to WV pick this plane up personally just to prevent damage from shipping only to find the fuse workmanship was totally unacceptable. i did look at it before i left ,but was tired and wanted to head home so i didn't look at like i should have. lucky for me the following 3 weeks later i had to go to NC for my nephew's wedding so i exchanged it on the way down. ok.... Here's the kit as i put it on the bench for the first time. i'm using robart wheels and gear , if you have any cool ideas you'd like to share ,do so by all means WB_1
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Scratch Builders make their own destiny
Hide Signatures
       Post #: 1
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:38 AM
warbird_1
Score: 159
Status: offline
here we have the spar and gear rails being fitted. i opted to replace the factory rails with wider ones because of the clearance grooves needed to make the gear much easier to remove . i was concerned about them being to weak after i grooved them to where they needed to be. byron wanted the gear built into the plane and not serviceable . i have many hours playing with the rails to get them just right . Partly because i'm hoping to add gear doors . the wing is thin and i'm not sure if i'm going to be able to make them work.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to warbird_1)
       Post #: 2
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:40 AM
Ram-bro
Score: 156
Status: offline
so was the issue with the construction or with the manufacturer? How much detail are you planning on doing ?
Hide Signatures
       Post #: 3
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:44 AM
warbird_1
Score: 159
Status: offline
the first pic is when i cut the gear door from the fuse. i didn't follow the panel lines because i'm making the gear removable and i'll be cutting the tabs from the door and adding mounting tabs to the pieces. the next pic is of the access hatch after being fitted. and the last two are of formers f-1 and f-2 being prepped for glassing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:47 AM
warbird_1
Score: 159
Status: offline
here's the cowl mounting brackets being fitted along with the cowl
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:49 AM
warbird_1
Score: 159
Status: offline
power plant... new g-62 with a byron straight mount
Click for fullsize
Hide Signatures
       Post #: 6
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:52 AM
warbird_1
Score: 159
Status: offline
here she is sitting pretty on her feet. i was going to use the dummy engine you see but i had clearance issues that i just get away from so i had to scrap the dummy engine idea. that sucked !
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:57 AM
warbird_1
Score: 159
Status: offline
next i had to work on fitting the exhaust from the great guys at jtech. the stock muffler hung to low and i couldn't get it in the cowl. i hate hacking up a cowl to get a muffler to fit. so i worked out where it need to be and i sent it back and Jtech made the mods for free!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:01 AM
warbird_1
Score: 159
Status: offline
here you can see the fitting process . The exhaust was one of the bigger challenges thus far .
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:06 AM
warbird_1
Score: 159
Status: offline
after getting the exhaust the way i wanted i decided to rebuild the area where i had relieved in order to the the pipes to fit. i had to as the lover cowl mounting bracket need to be supported better.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:09 AM
warbird_1
Score: 159
Status: offline
here's a couple of shots after the carb and plug reliefs where done
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:12 AM
warbird_1
Score: 159
Status: offline
here's the radiator inlets. i'm still looking for some screen to make the actual radiators so they aren't quite done .
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 12
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:15 AM
warbird_1
Score: 159
Status: offline
here i'm installing the servo mounts . i added the extra material so the servo screws had something to bite into . the pads are 1/8 5-ply
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 13
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:21 AM
warbird_1
Score: 159
Status: offline
mostly from the manufacturer. just isn't as good as byron was. i ordered a replacement canopy for my at-6 and it was so thin i sent it back and told them i wasn't going to use it and to either send me a better one or refund my money. when i bought the corsair kit they gave me the wrong canopy for that so i sent them both back at the same time on my dime or about 15.00 . i was supposed to get a sliding canopy i got the static one . gezzz
Hide Signatures
(in reply to Ram-bro)
       Post #: 14
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:25 AM
warbird_1
Score: 159
Status: offline
here i'm working on the tail wheel mount . i know the rudder post/tail wheel former doesn't look straight but it's right on lol
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 15
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:36 AM
warbird_1
Score: 159
Status: offline
this is where i am as of tonight . i'm getting ready to start on building /fitting the wing panels / the pic with the piece of ply taped to it was part of what i was talking about . poor workmanship. the spar slot looked like it was cut by a third grader with a dull hacksaw . lucky for me the slot was way to narrow so i squared of the line and use the piece of ply to hold the line while i recut the slot . it turned out good. spar fits nice now.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:38 AM
warbird_1
Score: 159
Status: offline
Ill be progressing slowly so check back for updates .
Hide Signatures
       Post #: 17
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 2:53 AM
BobH
Score: 116
Last Login: 5/18/2013
Status: offline
You would be wise to reinforce the spar where its cut out for the Gear strut. Others have failed exactly at that point..
BobH.
Hide Signatures
       Post #: 18
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 3:47 AM
Check6
Score: 105
Status: offline
Hey Ron,
Looking great!! I'm ready to buy when finished.
Later,
Fred
Hide Signatures
(in reply to BobH)
       Post #: 19
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 12:43 PM
warbird_1
Score: 159
Status: offline
quote:
ORIGINAL: BobH
bob , i haven't heard of any failures there. good to know. i already put a 1/6 5-ply reinforcement ply doubler there just for good measure. i guess a lot of factors can come into play there like how deep the person cut the groove. was it rounded on the bottom , did they pull up way to hard etc. i'd be interested in hearing more about the failures if you have first hand knowledge . thanks for the tip. WB_1
Click for fullsize
Hide Signatures
(in reply to BobH)
       Post #: 20
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 12:45 PM
warbird_1
Score: 159
Status: offline
quote:
ORIGINAL: Check6
Hey Ron,
Later,
Fred
LOL fred, not a chance buddy . i'm building this one to keep . :-)
Hide Signatures
(in reply to Check6)
       Post #: 21
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 12:52 PM
samparfitt
Score: 125
Status: offline
I agree with Bob on re-enforcing the spar.
I'd epoxy ply on both sides of the spar (total 3 layers) as I had a Byron hellcat and the wing broke off due to the metal spar breaking free of that lone ply (bought the plane already built). Needless to say, I have failed every time to successfully land a plane with only half a wing (but I keep flying her until every part stops moving!), resulting in total destruction of plane and engine (except for that one wing that came floating down by itself!).
As for kit quality, Byron was way ahead at the time, but you're now talking about 30+ year old technology!
I found some pictures:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
G. Samuel Parfitt
Hide Signatures
       Post #: 22
Alain RONK
Score: 100
Last Login: 1/8/2013
Status: offline
 Hello !
Your construction Wonderful !
Best regards !
Alain
My website : www.modelisme-racer.fr
Best regards
Alain
Hide Signatures
       Post #: 23
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:03 PM
warbird_1
Score: 159
Status: offline
quote:
ORIGINAL: samparfitt
sam i was thinking about that last night. i had one of these before and i put it though it's paces. when you say you bought it built , had it ever flown. where i'm going with this is ... like i said before , i've never heard of any byron planes having problems with wing.spar failures. i was wondering if had it flown. a possible wing strike during a hard land could have cracked something. that's kinda why i don't buy used ,pre built planes. lol i don't trust anyone. so your saying the wing spar in the plane broke completely apart at the gear strut notch and ripped the spar clamp right out ?
Hide Signatures
(in reply to samparfitt)
       Post #: 24
RE: Byron/Iron Bay F4U Corsair build - 12/9/2012 1:11 PM
samparfitt
Score: 125
Status: offline
If I remember correctly, I don't think it was ever flown and I don't remember having any bad landings as hellcats are pretty easy flyers. I also didn't like the gear not being removable. Like you, I no longer buy already built planes (that way, I can only blame 'dump thumbs'!).
I just added pictures to my previous post so you can see where the spar came out.
G. Samuel Parfitt
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.328RCU1
