motor wont suck fuel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> motor wont suck fuel Page: [1]
Login
motor wont suck fuel - 12/9/2012 5:14 AM
jvdd
Score: 100
Last Login: 5/20/2013
Status: offline
Hi Guy's
I've got this Zenoah 26 that wont prime up with fuel.
It is a new motor and originally had a 644 with primer bulb.
With this Carbie it will start as the bulb has primed with fuel
but once the carbie has run out it will stop. The iso block had a nipple for
a water pume but was blocked off so thinking that that was the problem I changed it for a new one,
but the problem still persisted so I swaped out the carbie for a new one (no bulb) and still no fuel.
I then replaced the gaskets with new teflon ones and still no difference.
I put this carbie on another motor and all works fine.
I'm stumped what could be the problem as it seem to be just with this motor.
jim
Hide Signatures
       Post #: 1
RE: motor wont suck fuel - 12/9/2012 6:15 AM
Ron Olson
Score: 1175
Last Login: 5/21/2013
Status: offline
I'm thinking that the isolator block is on upside-down. Been there.
_____________________________
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to jvdd)
       Post #: 2
RE: motor wont suck fuel - 12/9/2012 6:19 AM
tapkoote
Score: 122
Last Login: 5/2/2013
Status: offline
did it ever start?
Hide Signatures
(in reply to Ron Olson)
       Post #: 3
RE: motor wont suck fuel - 12/9/2012 6:56 AM
mistycreekboats
Score: 105
Status: offline
I think plugged vent or fuel filter / tank  issues - cut in fuel line - pinched or pluged - change the hose out and check the vent
JMO
Randy Danchuk
Misty Creek Boats Canada
Hide Signatures
(in reply to tapkoote)
       Post #: 4
RE: motor wont suck fuel - 12/9/2012 7:35 PM
Jackal1983
Score: 105
Last Login: 5/7/2013
Status: offline
Id take the carb block off and check you have have the pulse hole in the corect position and none of the gaskets are covering the pulse holes.
Does the motor have Compression? If the piston had a hole in it you wouldnt have fuel or compresstion and will never run in a million years!
MillPond Models
Hide Signatures
(in reply to mistycreekboats)
       Post #: 5
RE: motor wont suck fuel - 12/9/2012 7:53 PM
tapkoote
Score: 122
Status: offline
I'd guess a warped iso block to the carb.
Hide Signatures
(in reply to Jackal1983)
       Post #: 6
RE: motor wont suck fuel - 12/11/2012 2:22 AM
jvdd
Score: 100
Status: offline
Hi Guy's
Thanks for getting back to me, I will take these suggestions onboard and check the motor and get back to you when I find out more.
jim
Hide Signatures
       Post #: 7
RE: motor wont suck fuel - 12/15/2012 3:52 AM
wetsleeves
Score: 100
Status: offline
maybe the pulse hole has a blockage in it, casting or somthing similiar
Hide Signatures
(in reply to jvdd)
       Post #: 8
RE: motor wont suck fuel - 12/15/2012 4:11 AM
jvdd
Score: 100
Status: offline
I found it
I think someone got over excited with the drill and tap,
a small bolt should fix it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to wetsleeves)
       Post #: 9
RE: motor wont suck fuel - 12/15/2012 4:27 AM
Ron Olson
Score: 1175
Status: offline
Yeah, that'll really lower your compression!
Somebody got a tad overzealous also thinking that longer bolts are better than short ones, i.e., the ones going through the isolator block.
269 Racing Team
Hide Signatures
(in reply to jvdd)
       Post #: 10
RE: motor wont suck fuel - 12/15/2012 6:59 AM
The Ghost
Score: 110
Status: offline
That sucks. Some one used it for a pump port (water/fuel)
Cheers
Remember, Always look after the ORGANIC part of the model
Hide Signatures
       Post #: 11
RE: motor wont suck fuel - 12/15/2012 5:42 PM
Jackal1983
Score: 105
Status: offline
Yer... Id go with Ghost... that no accident!!! someone has done that to get a pulse line!!! very very odd place to put it tho!!!lol
MillPond Models
Hide Signatures
(in reply to The Ghost)
       Post #: 12
RE: motor wont suck fuel - 12/15/2012 10:11 PM
jvdd
Score: 100
Status: offline
Yeh as the original iso block had a nipple drilled into it also.....2 for 1 maybe
jim
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
