Head shims    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Head shims
Page: [1]
Login
Head shims - 12/9/2012 8:11 PM
K5 bogger
Score: 100
Last Login: 2/4/2013
Status: offline
Okay I'm new to this so got a few questions what head shims do I need for 20% nitro.
on a picco p3-28 and a picco .26 don't know what stock is or what should I put on it?
Hide Signatures
       Post #: 1
RE: Head shims - 12/10/2012 12:51 AM
K5 bogger
Score: 100
Status: offline
anyone? is it just 1 0.2mm or 2
Hide Signatures
(in reply to K5 bogger)
       Post #: 2
RE: Head shims - 12/10/2012 11:59 AM
controlliner
Score: 100
Last Login: 5/22/2013
Status: offline
What you need to achieve is .019-.020 clearance between the squish band and the piston crown at Top Dead Center. To measure this, take out the plug and take a length of solder wire and bend the end like an L shape. the lower bend needs to be about 3/8 an inch long. place it in the plug hole and allow the end of the "L" to touch the edge of the liner. Turn the engine over by hand with the flywheel. Remove the solder wire and measure the squished end with a Micrometer or a vernier.
I've used this method since the 1970's and have had accurate results every time. Remember when you use higher nitro, your engine will crank out higher RPM at a richer setting, you just can't hear it. If your engine is screaming on the straights, the HSN is set way too lean and you will go through plugs needlessly.
_____________________________
"Keep it clean and not too lean" Duke Fox
Hide Signatures
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.174RCU1
