RE: Tadpoles    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> RE: Tadpoles Page: <<   < prev  1 [2]
Login
RE: Tadpoles - 12/11/2012 4:28 PM
toolmaker7341
Score: 105
Last Login: 6/18/2013
Status: offline
What is that great looking aircraft? Is it a kit,plans or arf
_____________________________
Mike Burg
Hide Signatures
(in reply to fiery)
       Post #: 26
RE: Tadpoles - 12/11/2012 9:06 PM
fiery
Score: 100
Last Login: 6/19/2013
Status: offline
A lowly VMAR "Arrow Tiger" ARF pattern trainer.
55" span. Symmetrical airfoil.
Shape reminds me of 'half-half' P-51D Mustang and Bf 109-G Messerschmitt.
Still available.
http://www.levelflight.com.au
This business also sells ENYA 2 and 4 stroke diesels. A big plus from me for that.
I have just bought a VMAR Scottish Aviation "Bulldog" for an Easter 2013 Build, to be powered by a diesel 10 cc. Build and wood quality is much improved.
It's no 'World Models' ARF, but excellent value for the price.
Apologies ... I am a long way off Micro-diesels.
< Message edited by fiery -- 12/13/2012 4:31 AM >
Hide Signatures
(in reply to toolmaker7341)
       Post #: 27
RE: Tadpoles - 12/11/2012 10:08 PM
AMB
Score: 110
Status: online
Fiery have several VMARs the Apache ll and lll among them the apache ll has been around a long time sturdy build had an Irvine 40 diesel then a upgrade to Irvine 53 Davis head
on the 53 it will knife edge also the hot rod high wing the apache lll has a side mounted 52 4strk ASP and cowled in to get a way from the trainer look also a low wing arrow 40 size
think it is a VMAR and an other high wing Hot Rod I have no beefs with VMAR qualitythey had some issues years ago but no more, at least in the last 10 years martin
Post Note I do have an ASP/MAG 4 strk converted to Diesel by Greg Glamryz that I can swap in
Click to see fullsize image.
Click for fullsize
< Message edited by AMB -- 12/11/2012 10:45 PM >
Hide Signatures
(in reply to fiery)
       Post #: 28
ffkiwi
Score: 105
Status: offline
But I'm OT!..............10,050rpm on a Cox 5x3 yellow this morning-unfortunately the camera batteries went flat when I tried to get the tacho shot........more to come. The Cox 5x3 still represents a significant load compared to other 5" props such as the Topflite or DC 5-1/4x3-1/2, so the performance continues to impress. Engine sounded very happy running this prop-but definitely harder to start.
ChrisM
'ffkiwi'
Hide Signatures
(in reply to fiery)
       Post #: 29
RE: Tadpoles - 12/11/2012 10:11 PM
fiery
Score: 100
Status: offline
Over 10,000 RPM on a Cox 5 x 3?
Now I really want one! I have a box of those Topflite 5 1/4 x 3 wood props too ...
As you said Chris, lesson learned.
Hide Signatures
(in reply to ffkiwi)
       Post #: 30
RE: Tadpoles - 12/11/2012 10:16 PM
ffkiwi
Score: 105
Status: offline
It took a bit of tweaking to get it there, but we made it in the end. Camera batteries currently on charge, so I'll try and get a repeat run later-but its getting warm here today and it may not be so happy-we'll see.
Eventually I will run it on the raft of small props I've carefully balanced and we'll have some reasonable figures for reference. I won't do the APC ones though-as they'll need a bushing machined up, and I'm too busy with my Nats preparations. Perhaps early in the New Year, after I've returned from down south.
ChrisM
'ffkiwi'
Hide Signatures
(in reply to fiery)
       Post #: 31
RE: Tadpoles - 12/11/2012 10:22 PM
AMB
Score: 110
Status: online
sounds like the tadpole turned into a bulldog martin
Hide Signatures
(in reply to fiery)
       Post #: 32
RE: Tadpoles - 12/11/2012 10:42 PM
ffkiwi
Score: 105
Status: offline
Well how much you'll eventually see once I run a series of comparative tests of the same props on the mini ED Baby of the same size..........but I need to make a compression screw lock for that one
CJM
Hide Signatures
(in reply to AMB)
       Post #: 33
RE: Tadpoles - 12/11/2012 11:34 PM
ffkiwi
Score: 105
Status: offline
'ere we are then-10080rpm, proof positive............
CJM
.....a quick check on the calculator suggests that this equates to ~0.013 BHP.......there may be a bit more to be got from the engine yet
Click for fullsize
Hide Signatures
       Post #: 34
RE: Tadpoles - 12/12/2012 1:16 AM
fiery
Score: 100
Status: offline
Chris
Is it able to drain it's tank yet on a given needle setting? Or leaning out and quitting?
Now the Schlosser .25 cc's are also historical artifacts. it looks like I will have to keep my eyes open to see if one comes up on *bay.
Hide Signatures
       Post #: 35
RE: Tadpoles - 12/12/2012 1:26 AM
ffkiwi
Score: 105
Status: offline
It still gets hot and labours to a stop unless you back off comp and richen the needle after about 1-1/2 minutes running-I've probably managed to run the tank dry twice in about a dozen separate runs. The shaft is a beautifully free fit in the main bearing so I'm assuming its cylinder friction is the issue here. I also noted today that the contra seems to freeze after more than a couple of minutes running [for the run where I took the photo, I topped the tank back up from nearly empty whilst it was still running-so that was a longer run than usual-and found that I couldn't back off the comp once the engine started to labour.
One thing I'll say for the wee beastie-you can tell whens it's happy.........and you can definitely clearly hear when it's unhappy........
ChrisM
'ffkiwi'
Hide Signatures
(in reply to fiery)
       Post #: 36
RE: Tadpoles - 12/12/2012 1:46 AM
fiery
Score: 100
Status: offline
It has a nice tight P/L fit - check.
It has a contra that 'locks up" when really hot - check.
These are plus points. I dislike engines that are a "loose" piston fit out of the box, and diesels with leaky contras are annoying.
The issues will only improve with running time, which is a bonus with a diesel this small.
Hide Signatures
       Post #: 37
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
