Ideas for a building surface    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Ideas for a building surface
Page: [1]
Login
Ideas for a building surface - 12/9/2012 11:04 PM
stevegauth30@comcast.net
Score: 100
Last Login: 5/24/2013
Status: offline
For years i have always built on a sheet of 5/8 sheetrock. I tape down the plans, then I put clear packing tape over all of the areas to be built over so that after building a certain part, i just take a thin piece of metal, such as a hack saw blade and slide it side to side under the part and it very easily pops off of the plans with no damage to either the part or the plans. The only drawback is at the end, every where that i put a t-pin is now glued down to the dry wall. After all that time of protecting the plans, i end up doing more damage just trying to roll them up. Aside from a magnetic building board, ( which i would love to have)but dont have, what do you guys do to prevent this from happening?Im tired of shredding up plans. I would love to hear what you guys do. Thanks, Steve.
_____________________________
CUB BROTHERHOOD # 151, CORSAIR BROTHERHOOD # 80, CLUB SAITO # 804
Hide Signatures
       Post #: 1
RE: Ideas for a building surface - 12/9/2012 11:46 PM
goirish
Score: 305
Status: online
I have a solid core door for the base. I put a piece of cellotex on top of that and then I lay my plans on top of the tex. I cover the plans with parchment paper and then build on that. The parchment paper will not let any thing stick to the paper or the plans.
DX-7,RDS8000. big Bingo,1/4 Scale Cub, SeaMaster 120, Forget the health food, I need all the preservatives I can get
Hide Signatures
(in reply to stevegauth30@comcast.net)
       Post #: 2
RE: Ideas for a building surface - 12/10/2012 1:32 AM
N1EDM
Score: 125
Status: online
I made a bench from scratch called a torsion box. A lot of work but was dead flat and won't warp. It's tedious but you only have to build it once. Just look this up on YouTube -
But more importantly, when I build from plans, I make a copy first and build off of the copy. The cost was $5-$10 or so, a small price to pay considering how much money you're going to put into this airplane anyway.
Just my $.02
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to goirish)
       Post #: 3
RE: Ideas for a building surface - 12/10/2012 2:12 AM
goirish
Score: 305
Status: online
quote:
ORIGINAL: N1EDM
Just my $.02
Bob
I also make a copy so I can keep the original. I do a lot of scratch building. I guess I enjoy building as much as flying.
Hide Signatures
(in reply to N1EDM)
       Post #: 4
RE: Ideas for a building surface - 12/10/2012 5:18 AM
Gray Beard
Score: 314
Status: offline
My board is just 3/4 inch pine I have laminated then run through a sander to get it level then put cross braces on the bottom to keep it level. I used to always have a second copy of my plans made but it depends on the plane and if I need to worry about destroying the originals. Unless I cut up the plans I don't seem to hurt them just building over them. The pine board allows me to use Tee Pins during my builds. I have never tried a magnetic board but I have been told it's really a great way to go.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 5
RE: Ideas for a building surface - 12/10/2012 11:18 AM
gene6029
Score: 120
Status: offline
I used to teach building classes at the LHS & heres what we did for each student. Picture #1 is a piece of shelf board that is laminated on all sides, bought at Lowes under $10. Pic #2, we attached a piece of 1/2" drywall material & taped down 3 sides. Pic#3, next we ran a straight edge from corner to corner to check for flatness & shimmed it up if needed with paper under the drywall. Pic#4, tape down the plans & cover with waxpaper. Pic #5, start building. This way we could put all the building tables away until the next building session, or they could take them home & work on stuff themselves. This is just one way thats easy & inexpensive & builds a Flat & straight model.......Gene
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: Ideas for a building surface - 12/10/2012 11:24 AM
Rotten40851
Score: 110
Status: offline
Magnets
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Futaba 18 MZ... Nothing even comes Close!!!
Hide Signatures
(in reply to gene6029)
       Post #: 7
RE: Ideas for a building surface - 12/10/2012 12:06 PM
thailazer
Score: 110
Last Login: 5/23/2013
Status: online
Ceiling tile (24 inch by 48 inch if I remember right) placed upside down on your workbench and covered with plans and wax paper works good. Never had a problem with the T pins sticking to the plans.
Tiger Flyer #49
Hide Signatures
(in reply to Rotten40851)
       Post #: 8
RE: Ideas for a building surface - 12/10/2012 1:31 PM
bogbeagle
Score: 148
Status: online
I have a torsion-box, which I fitted with blind nuts, so that I can clamp components.
But, my friend uses a pine desk. Instead of modelling pins, he secures components using 2" nails (obviously he doesn't nail through itty bits of balsa). This works really well ... much better than pins. It's worth considering.
Hide Signatures
(in reply to thailazer)
       Post #: 9
RE: Ideas for a building surface - 12/10/2012 3:28 PM
Score: 100
Status: offline
First of all, thanks to all who have taken the time to share ideas with me. They all sound good. The real problem is the back side of the plans sticking to the drywall where the t pins penatrate. The CA follows the pin down into the drywall. I think for now, I will just have coppies mades so that its n ot a big deal if it happens. In the near future i would really like to try the magnetic system. Can any one tell me where to get the materfials?The metal i dont see as a problem to find, but how about the magnets?Are they expensive? And how do you go about holding down say a wing panel, or the fuse? Do you have to cut notches in them to fit over the spars?I am realizing that with as many planes that i have building, and with as many as i would like to build, the cost is nothing in the long run. Just wondering. Thanks again for all of the knowledge. Steve.
Hide Signatures
(in reply to bogbeagle)
       Post #: 10
RE: Ideas for a building surface - 12/10/2012 3:35 PM
TCampbell
Score: 100
Status: offline
quote:
ORIGINAL: N1EDM
...But more importantly, when I build from plans, I make a copy first and build off of the copy. The cost was $5-$10 or so...
Where do you get the copy made ? Just Kinko's or Staples? Or do you need to look for somewhere with a special capability for these large sheets? Thanks for the info.
Tim
Hide Signatures
(in reply to N1EDM)
       Post #: 11
RE: Ideas for a building surface - 12/10/2012 4:23 PM
Score: 100
Status: offline
Kinkos i know for sure does them, Hopefully staples does too because theres a staples about 1/2 mile from me where as Kinkos is like 15 miles away from me. Im going to take a ride to staples in a bit and let you know.
Hide Signatures
(in reply to TCampbell)
       Post #: 12
RE: Ideas for a building surface - 12/10/2012 5:22 PM
Gray Beard
Score: 314
Status: offline
Kinko's, but it's worth a phone call to other copy centers. I used to have to wait until I was going to make a trip from the mountains down to Fresno {almost 2 hours} to get my plans copied. I also located an old print shop that still had a blue line machine in operation that I liked even better. There are print shops that have the machine like Kinko's that copy blue prints for architects too.
I almost never have my plans get stuck to the board? I don't glue over the pins or pin holes. If a little glue does get through I just use a flat metal ruler and gently scrape the plan off the board from under them. You can press down some clear tape over the top of the stuck area so the plans stick to the tape more then the board when you lift them.
Kit plans I never get copied these days and Building plans I only get a copy if I'm going to cut them up as templates.
Just be careful with the glue, use wax paper or parchment paper over them. Parchment works great but you can see through wax paper better, I use them both.
Hide Signatures
       Post #: 13
RE: Ideas for a building surface - 12/10/2012 5:37 PM
Score: 100
Status: offline
Thanks grey beard for the replys. I did just call staples and for a 3 foot by 4 1/2 foot plan it's only 5 dollars so economically I think it's the way to go. I was just thinking too that if I put packing tape on the bottom of the plan or even on the drywall it self would probably solve the problem. I'll give it a try. Thanks again.   Steve.
Hide Signatures
       Post #: 14
RE: Ideas for a building surface - 12/10/2012 6:05 PM
TCampbell
Score: 100
Status: offline
Thanks for reporting on the Staples call, Steve, and for confirmation on Kinko's, Gray Beard. I have new plans that will be on the board soon and I'd like to cut a set up for templates, so this is great information.
I wish I had a suggestion for your original question. I build on a ceiling tile, laying the plans directly on top and then covering them with wax paper. Like Gray Beard, I don't normally glue in or through the pin holes so no glue gets under the wax paper. Your idea of covering the drywall first, then laying the plan on top sounds like a reasonable approach. Good luck.
Tim
Hide Signatures
       Post #: 15
RE: Ideas for a building surface - 12/10/2012 10:06 PM
R/C-PILOT-DREAMER
Score: 100
Last Login: 12/11/2012
Status: offline
There is a recent build thread under "Kit Building" that RCU member "acer" shows his building table that uses magnets.
And he shares were to get the magnets.
Hide Signatures
       Post #: 16
RE: Ideas for a building surface - 12/11/2012 1:47 AM
2walla
Score: 100
Status: offline
Ej Lind used to make a magnetic building board set. Tower hobbies/great planes bougt it up from his widow after he died. It used to run about 120. Haven't seen it in a while but i think it is still inproduction. The magnets have holes in them and you can bolt accessories to ithem. The board itself was about four feet by one and a half feet so about a good glow 120 wing panel was maxed out. It needed a solid flat surface to be layed out. I built a lot of planes on mine, but really liked the magnets when I scored a nice steel exterior door to build on.
Hide Signatures
       Post #: 17
RE: Ideas for a building surface - 12/11/2012 2:23 AM
crossman
Score: 100
Status: offline
I use a door with a piece of drywall on top it. I cover the plans with the clear backing from a used roll of monokote. But since I mainly use Ultracote now, I'll have to find something else in the future. I also have my plans copied at Staples before I start a build.
Chuck R AMA 588070 Club Saito#681
I spend most of my money at the Hobby Shop, and I waste the rest.
Hide Signatures
(in reply to 2walla)
       Post #: 18
RE: Ideas for a building surface - 12/11/2012 3:15 AM
raptureboy
Score: 178
Status: offline
O.K I'm surprised no one said this yet so I will. Go to your local glass shop and see if they have any used panels from a patio door or tempered glass table tops. Check on craigs list also. you lay your plans on the bench and then cover over with the glass. To hold spars or other items in place you just use a spot of CA and when your ready take a razor blade and pop it all loose from the glass. Dave Platt and many others use this method.  No holes in your plans or spilled glue.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to crossman)
       Post #: 19
RE: Ideas for a building surface - 12/11/2012 3:26 AM
frequent flyer
Score: 125
Status: offline
I made,a table from a solid core Masonite door, border with 1x3 wood (I used some Oak I had laying around) a 1/2" higher than the top surface, then I cut a sheet of 1/2" homosote board the size of the door and laid it in. It made a nice building table that is flat and I can stick pins into it to hold things.
Epoxy Glass Fuselages, Short Kits & Fiberglass parts. Proudly made in the U.S.A. rcaiir.com
email: rcaiir@gmail.com
Hide Signatures
(in reply to raptureboy)
       Post #: 20
RE: Ideas for a building surface - 12/11/2012 4:50 AM
KaP2011
Score: 115
Status: offline
quote:
ORIGINAL: stevegauth30@comcast.net
This is probably the best system I've ran across. The magnets are just cabinet door magnets.
http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/tools/magnetic_building_board/order_magnetic_fixtures.htm
KaP2011
AMA #408493
Hide Signatures
       Post #: 21
RE: Ideas for a building surface - 12/11/2012 8:11 AM
mooseflier
Score: 100
Last Login: 12/13/2012
Status: offline
I've used sheetrock forever.Once I started making nicer/bigger models, I used sheetrock above glass, taping down the edges, Or two pieces of plywood laid across each other and leveled with a level.
Regardless, use a very true/stiff rod to check your front and leading edges. If you have minor bends, you can try to take them out with the coating.
Hide Signatures
(in reply to KaP2011)
       Post #: 22
RE: Ideas for a building surface - 12/14/2012 1:27 PM
KitBuilder
Score: 131
Last Login: 5/22/2013
Status: offline
Upside down 2x4 cieling tiles on my "known flat workbench? Easily yet strongly accept pins.. I tape down both 2' ends chordwise with wide masking.. easy, inexpensive and flat... come 4 to a box at Lowes. One tile can last a coulple builds. Have everything from small electeics to 60 size planes.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
(in reply to mooseflier)
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
