What refuelling pump setups do you use?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> What refuelling pump setups do you use?
Page: [1]
Login
What refuelling pump setups do you use? - 12/10/2012 11:00 AM
Springbok Flyer
Score: 100
Last Login: 5/21/2013
Status: offline
Hi guys,
I was just thinking about updating my fuelling pump setup for filling my jets. So please share your favourite pumps and fuel station setup's.
If possible I would like to find something that I can run off a fair capacity lipo and attach to my current fuel container (usual plastic gasoline/ kerosene).
Thanks for sharing your ideas.
JanR
_____________________________
''''It is always pilot error.''''
Hide Signatures
       Post #: 1
RE: What refuelling pump setups do you use? - 12/10/2012 1:03 PM
Dr Honda
Score: 100
Last Login: 5/22/2013
Status: offline
If you want to use a Lipo, and use your can... then you can use what I made. There is a cap that fits Du-Bro fittings... and a pump/battery mounting plate. I have a sig gas-passer on it... but the pump Todd has, will also fit.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to Springbok Flyer)
       Post #: 2
RE: What refuelling pump setups do you use? - 12/10/2012 3:48 PM
STKNRUD
Score: 110
Last Login: 5/20/2013
Status: offline
I use a submersible auto fuel pump. On the outside, I have a small box for 3-cell Lipo, reversing switch, fuel filter and bypass so fuel returned during defueling does not go through the filter. I plug a small low volt buzzer on the Lipo balance lead to alert when bat voltage drops.
I didn''''t say it was the plane''''s fault. I said I was blaming the plane.
Hide Signatures
       Post #: 3
RE: What refuelling pump setups do you use? - 12/10/2012 4:12 PM
husafreak
Score: 100
Status: offline
I am also interested as I get started into jets. I have read that Evo jet makes a fueling station with a variable flow rate, or you can use lower voltages, some even fill at a high rate and switch to a low rate for the satellite tanks. So I gather that you can damage your tanks or introduce unwanted air into the system if you fill at too high a rate. The Evo jet is not available in the states right now, or I haven't found it. I would ideally like to start with a variable rate pump.
Hide Signatures
(in reply to STKNRUD)
       Post #: 4
RE: What refuelling pump setups do you use? - 12/10/2012 7:19 PM
Greg Wright
Score: 102
Status: offline
Check out the Jersey modeler fuel jug. I have two and they work great. I have also seen some people take the stock batteries out and just run a 2Cell lipo to the system.
< Message edited by Greg Wright -- 12/10/2012 11:25 PM >
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
(in reply to husafreak)
       Post #: 5
RE: What refuelling pump setups do you use? - 12/10/2012 7:51 PM
smchale
Score: 115
Status: online
quote:
ORIGINAL: husafreak
I have one of the IQ-Hammer fill jugs with the variable rate fill dial. Works really nice. Added benefit is that it also houses my air pump. They even added my name and AMA number, . They weren't available in the US when I ordered it but I think Vogelsang now carries them.
Click to see fullsize image.
Click for fullsize
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
       Post #: 6
RE: What refuelling pump setups do you use? - 12/10/2012 10:41 PM
husafreak
Score: 100
Status: offline
That is just awesome! I will have to call my buddy Gotz... The only bummer is I gotta think whether to get the air compressor or not, I mean I just bought one recently for my Electra. But having that with the fuel station is just great.
Hide Signatures
(in reply to smchale)
       Post #: 7
RE: What refuelling pump setups do you use? - 12/11/2012 1:36 AM
tlj125
Score: 104
Status: offline
I have a Jersey can and have problems with it. Four main issues:
1) Pumps too fast causing the tanks to swell and sometimes causes the stopper to loosen and leak. I had one tank split along the seam and leak.
2) The box hangs from the side and gets bumped constantly. The box on mine is shattered particularly around the mounting screws.
3) I don't like the charging adapter. It works OK, I just don't like it mostly because I don't know where I left it last.
4) Not fond of the two step switch either. I have to push it on and off several times to fill my plane without swelling the tanks too much. Same thing getting the fuel out.
So I put together my own tank with the ability to adjust flow rate and not have a box hanging off the side of the tank bumping into everything or have an odd charging plug. It doesn't look as nice as a Jersey can, but for me it works just fine. It's very easy to switch batteries too. I can use a 3 cell LiPo or the 5 cell shown in the photos.
Terry
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: What refuelling pump setups do you use? - 12/11/2012 2:07 AM
tlj125
Score: 104
Status: offline
I meant 4 cell. Senior moment...
Hide Signatures
(in reply to tlj125)
       Post #: 9
RE: What refuelling pump setups do you use? - 12/11/2012 2:21 AM
k12rc
Score: 101
Status: offline
quote:
ORIGINAL: tlj125
know what that is
don''''''''''''''cry'''''''' till''''''''it hits
Hide Signatures
       Post #: 10
RE: What refuelling pump setups do you use? - 12/11/2012 5:07 AM
jetster81
Score: 106
Status: online
I have the DR Honda one and it works a treat,cheap and cheerful and I use the same lipos I put in my knock about foamies.
Hide Signatures
(in reply to k12rc)
       Post #: 11
RE: What refuelling pump setups do you use? - 12/11/2012 6:08 AM
Jeremy_D
Score: 100
Status: offline
I use the Apple iFill system, Only one in the world as far as I know!!
Powered off a Li-Fe 6.6v 4500mah pack with emergency shut off switch, 2 way flow, lasts for months.
Click for fullsize
Global Jet Club Australia
www.aussiejet.com
Hide Signatures
(in reply to jetster81)
       Post #: 12
RE: What refuelling pump setups do you use? - 12/11/2012 7:45 AM
Boomerang1
Score: 120
Status: offline
Mine looks like the 'standard' model flight box.
21 AH of batteries in the base, 10 litres of fuel,
charge sockets, pump & compressor in one unit.
BUT.. it's heavy! - John.
Click for fullsize
Click for fullsize
Click for fullsize
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to Jeremy_D)
       Post #: 13
RE: What refuelling pump setups do you use? - 12/11/2012 10:55 AM
In the Haze
Score: 100
Status: offline
Don't mess around.
http://www.jerseymodeler.com/id28.html
ITH
I guess that flirting with death sometimes leads to a date.
Hide Signatures
(in reply to Boomerang1)
       Post #: 14
RE: What refuelling pump setups do you use? - 12/11/2012 11:02 AM
tlj125
Score: 104
Status: offline
OMG, I had no idea that Apple had released the new iFill. Where is the touch screen?
Hide Signatures
       Post #: 15
RE: What refuelling pump setups do you use? - 12/11/2012 12:50 PM
Jeremy_D
Score: 100
Status: offline
That will be on next years model - 'The New iFill'
www.aussiejet.com
Hide Signatures
       Post #: 16
RE: What refuelling pump setups do you use? - 12/13/2012 11:01 PM
phjoker
Score: 100
Last Login: 4/27/2013
Status: offline
Jersey Modeler, I took out the stock NIMH battery and installed one 2300 mah A123 battery
The Battery is usually good for the entire day and if its not it only takes 10 min to charge.
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
       Post #: 17
RE: What refuelling pump setups do you use? - 12/13/2012 11:58 PM
afterburner
Score: 110
Status: offline
I have one similar to Dr. Honda's except I used an A123 two cell pack and the pump that Dreamorks sells. I really liked the Blitz USA manufactured kero and gas cans but they were put out of business by over 40 lawsuits brought on by greedy trial lawyers. Hundreds of people lost their jobs because the warnings on the fuel containers telling idiots not to pour fuel onto a burning fire were not enough. Sorry I'm off my soapbox now.
Marty
Hide Signatures
(in reply to phjoker)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
