Vintage Citizen Ship radio help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> Vintage Citizen Ship radio help
Page: [1]
Login
Vintage Citizen Ship radio help - 12/11/2012 2:55 AM
anssec66
Score: 100
Last Login: 5/2/2013
Status: offline
Hello All,
Recently my grandfather handed down his old rc airplanes to me. These things are from the 50's! Pretty neat how they used to fly with the rubber band escapement. I am trying to get everything working again as it did 60 years ago. I am having a hard time finding information on this technology. Any ideas? I am also having a hard time sourcing batteries. Attached is a few pics of what I am working with. Any help would be great.
Brad
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Vintage Citizen Ship radio help - 12/11/2012 3:51 AM
rcacro
Score: 100
Last Login: 5/21/2013
Status: offline
I may be able to help you with some of this this. The first picture  I assume is the inside ot the model shows 3 different batteries being required which is standard for that vintage of equipment. The first batt box looks like it will hold a single AA battery (1.5 volt). This is needed to light the filament of the vacumun tube in the receiver which may be a 6007 Amprex  tube.  The second looks like it would the "B" battery or high voltage plate supply for the vacumun tube It was probably a 22 to 45 volt battery which may be hard to find and expensive at todays prices. Three or four 9 volt batteries could be wired in series to replace it. The third batt box looks like it will hold 2 "C" cells in series( 3 volts) used to operate the escapment.  Likewise,the transmitter usually required an "A" batt of 1.5 volts for the tube(s) filament and a "B" battery(s) of about 100 to 135 volts. These are also expensive today. A standard "C" battery could be used for the tube filament and twelve  9 volt batteries wired in series to replace the "B' required in the transmitter.
You may find that some of the capacitors in both the receiver and transmitter may have deteriorated and will have to be replaced.
John W.
Scottsdale, Az
Hide Signatures
(in reply to anssec66)
       Post #: 2
RE: Vintage Citizen Ship radio help - 12/11/2012 4:20 AM
anssec66
Score: 100
Status: offline
Thank you sir for the info. You are correct with the AA battery and the C battery. I am not sure where I can get a B size battery. Do you have any ideas? I took apart the transmitter and that is where I found that box that used to hold a "Burgess B Radio Battery." Inside the transmitter there are two connectors that look like 9V battery connectors. If you have any info on where I can buy these batteries it would be great. If i cant buy them, then I will do as you suggested and connect in series modern batteries to make the correct voltage.
Brad
Hide Signatures
(in reply to rcacro)
       Post #: 3
RE: Vintage Citizen Ship radio help - 12/11/2012 4:53 AM
rcacro
Score: 100
Status: offline
Hi Brad
The connectors in the transmitter that look like those on 9v batteries fitted the 67 volt "B" batteries  I hav'nt tryed to find them in 40 + years and don't know if any one makes them anymore. Try a search on the internet. Be careful and make sure any you buy have a current date code or are from a trusted distributor.
Batteries + Batteries had a few similar batteries in stock but they looked too old to be trusted!!
Hide Signatures
       Post #: 4
RE: Vintage Citizen Ship radio help - 12/12/2012 4:10 AM
anssec66
Score: 100
Status: offline
Today I hooked up all the batteries in the transmitter and the receiver. I used the 9v batteries in series to make the correct voltage. I could not get the transmitter to work. I did find the instruction book for the transmitter. I followed the directions with troubleshooting to check voltages around the tube terminals. None of the terminals showed voltage. Do you think I need to go ahead and replace all the capacitors. If so, I was looking at capacitors and frys and found many different types. My parts list shows a 390 MMFD, 470 MMFD, and a 15 MMFD ceramic capacitors. Frys has these size capacitors, but have different choices as in Electrolytic, non polarized and etc. Any ideas?
Brad
Hide Signatures
       Post #: 5
RE: Vintage Citizen Ship radio help - 12/12/2012 8:40 AM
bem
Score: 115
Last Login: 5/20/2013
Status: offline
Brad,
Maybe also this info can be helful if You want to fly with Your radio again:
http://www.singlechannel.co.uk
There has been two articles in the Brittish model magazine RCM & E, Nov and Dec 2012 issues, about the single-channel encoder one can build (or buy ready made from the inventor) that can be used in old vintage single-channel radios.
/Bo
Hide Signatures
       Post #: 6
RE: Vintage Citizen Ship radio help - 12/13/2012 2:11 AM
Dave Harmon
Score: 101
Status: offline
Brad......
Because it has not been mentioned....your receiver is a Babcock Magic Carpet. The matching tramsmitter was a Babcock Magic Wand.
The tube in the receiver certainly is an Amperex 6007 which was a replacement for the original 1AG4 tube.
The difference in the tubes is the 6007 has a much reduced filament current so the 1.5v battery in the plane would last much longer.
Back in the day....this equipment was pretty reliable by comparison to some other stuff....the big problem with this gear today is as mentioned....batteries.
If you are handy with electronics...an inverter/converter can be made to eliminate the 67.5v batteries in the transmitter.
But....I like the 9v battery method just as well. Just keep an eye on the voltage and don't turn it on and play around then expect the batteries to be good when you want to fly.
This is where the converter comes in handy. You can recharge the NiCad battery.
Today I would use a Hyperion A123/LiFe rechargeable battery. I have had great luck with the LiFe batteries from R/C Dude.
_____________________________
Forget Mixing Your Own Fuel....It''s Easy But No Longer Needed!
Hide Signatures
(in reply to bem)
       Post #: 7
RE: Vintage Citizen Ship radio help - 12/20/2012 12:16 AM
anssec66
Score: 100
Status: offline
Thanks for all the info. Everybody has been great. I have been busy cleaning the old Fox .15 engine and it looks brand new at this point. I have it sitting in the original box until I am ready to put it back on the airplane. I found the radio tube was cracked and obviously that could be my problem. So, I ordered another one. The part number on the tube itself was RCA 3a4. I Should have it later this week.
My next question is what do I use to tune the radio? Tuning slug of some sort? I cant see into the hole to see what adjusts it.
Any ideas would be great!
Thanks Again,
Brad
Hide Signatures
(in reply to Dave Harmon)
       Post #: 8
RE: Vintage Citizen Ship radio help - 12/20/2012 12:43 AM
rcacro
Score: 100
Status: offline
If you can take a picture of the transmitter chassis, we may be able to identify the component that is used for tuning. Some were tuned by a compression type of capacitor (Small rectangular device with a screw on it) or a slug inside a coil which may have a slot or hex opening in it.
John W.
Hide Signatures
       Post #: 9
RE: Vintage Citizen Ship radio help - 3/26/2013 5:00 AM
northiceman
Score: 100
Last Login: 4/21/2013
Status: offline
I started flying with Citizen-Ship radios in the 60's. I have the same transmitter (the Model FL) and the Model PR-27 receiver. Both work fine. I also have a source for tubes for both if you need it. Did you get the transmitter going? When its working AND tuned properly the filament in the transmitter tube will glow a dim orange color. But you need to tune it according to the instructions you said you have for it to glow.
Hide Signatures
       Post #: 10
RE: Vintage Citizen Ship radio help - 3/26/2013 5:01 AM
northiceman
Score: 100
Status: offline
Hide Signatures
       Post #: 11
RE: Vintage Citizen Ship radio help - 3/26/2013 5:21 AM
tweedy
Score: 100
Last Login: 5/22/2013
Status: offline
The Batteries are still to be had but very expensive and can give you one heck of a shock.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
