MVVS update stock    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> MVVS update stock Page: [1]
Login
MVVS update stock - 12/11/2012 5:06 PM
AMB
Score: 110
Last Login: 6/18/2013
Status: online
Just checked Pe Reivers site he had a few MVVS 15s GONE no more, think Davis may still have a a head for the 40 and 61 you will have to check martin
Hide Signatures
       Post #: 1
RE: MVVS update stock - 12/11/2012 6:19 PM
DeviousDave
Score: 110
Status: offline
Does that mean they aren't assembling any more from parts?
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: MVVS update stock - 12/11/2012 8:39 PM
pe reivers
Score: 646
Status: offline
They did, but all things come to an end eventually.
I do still have small stuff though to keep your .15 engines in top shape.
_____________________________
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to DeviousDave)
       Post #: 3
RE: MVVS update stock - 12/11/2012 8:59 PM
fiery
Score: 100
Status: offline
Pe
Will an MVVS .15 ABC P/L assembly retro-fit into a standard MVVS .15 DFS?
If yes, do you have any stock?
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: MVVS update stock - 12/12/2012 7:09 AM
DeviousDave
Score: 110
Status: offline
I wonder what Parra will do for R/C carbs and needles?
Hide Signatures
(in reply to fiery)
       Post #: 5
RE: MVVS update stock - 12/12/2012 11:46 AM
pe reivers
Score: 646
Status: offline
yes, and yes.
The ABC P/L assy however is not the same as the diesel version, so needs a modified head/cp. It's doable, have done it.
Hide Signatures
(in reply to fiery)
       Post #: 6
RE: MVVS update stock - 12/12/2012 10:32 PM
fiery
Score: 100
Status: offline
The PARRA Wasp 1.5 cc in R/C guise is delivered with an ENYA air bleed R/C carburettor.
ENYA now offer a twin needle R/C carburettor having the same spigot diameter, as an upgrade.
In addition, the twin needle R/C carburettor for the ASP/SC/Magnum .12 fits the PARRA Wasp perfectly.
There are plenty of carburettor options once the supply of MVVS carbs dries up.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by fiery -- 12/13/2012 12:45 AM >
Hide Signatures
       Post #: 7
RE: MVVS update stock - 12/12/2012 10:42 PM
qazimoto
Score: 100
Last Login: 6/19/2013
Status: online
quote:
ORIGINAL: pe reivers
yes, and yes.
A standard ABC Rossi 15 p/l will fit the MVVS case/shaft as will a Parra 15D diesel push/pull head button. A slight about of machining is necessary.
New Rossi p/l are still available.
Ray
Hide Signatures
       Post #: 8
RE: MVVS update stock - 12/12/2012 11:22 PM
Mr Cox
Score: 102
Status: offline
The MVVS carb has a diameter of 11mm (if I remember correctly) while the ASP one is 8 or 10mm? Depending on if it is the one for their .12 or .15 engine.
The MVVS carb is also a direct drop in on a Norvel .15 and gives it a nice power bost of about 1500rpm.
Hide Signatures
(in reply to qazimoto)
       Post #: 9
RE: MVVS update stock - 12/13/2012 12:47 AM
fiery
Score: 100
Status: offline
Hi Ray
Is the Rossi .15 ABC P/L set you mention "plug and play" in the MVVS .15 DFS, or is some fettling required?
Hide Signatures
(in reply to Mr Cox)
       Post #: 10
RE: MVVS update stock - 12/13/2012 1:04 AM
ffkiwi
Score: 105
Status: offline
quote:
ORIGINAL: qazimoto
Ray
From where Ray? ......I have a couple of Conquests that could be turned into Cossi's if I could get Rossi p/l........
ChrisM
'ffkiwi'
Hide Signatures
       Post #: 11
RE: MVVS update stock - 12/13/2012 5:59 AM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: fiery
Hi Ray
Is the Rossi .15 ABC P/L set you mention ''plug and play'' in the MVVS .15 DFS, or is some fettling required?
Depends on individual cylinder liner fins, and the depth that the Parra head button extends into the liner. Only a matter of a few thou" either way.
More later.
Ray
Hide Signatures
(in reply to fiery)
       Post #: 12
RE: MVVS update stock - 12/13/2012 6:00 AM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: ffkiwi
quote:
ORIGINAL: qazimoto
Ray
ChrisM
'ffkiwi'
Chris,
I'll check on availability and email you.
Ray
Hide Signatures
(in reply to ffkiwi)
       Post #: 13
RE: MVVS update stock - 12/13/2012 6:11 AM
ffkiwi
Score: 105
Status: offline
Thanks Ray.
CJM
Hide Signatures
       Post #: 14
RE: MVVS update stock - 12/13/2012 11:18 AM
pe reivers
Score: 646
Status: offline
quote:
ORIGINAL: qazimoto
yes, and yes.
Ray
If that is the case, and bore is the same, the Parra head would probably also fit the MVVS ABC and the diesel liner with some lathe work.
Hide Signatures
       Post #: 15
RE: MVVS update stock - 12/13/2012 12:19 PM
qazimoto
Score: 100
Status: online
[/quote]
[/quote]
I believe that the Parra diesel button will fit the MVVS ABC liner but there is a problem with the Iron/steel diesel liner because it's taller.
IIRC the liner top does need to be skimmed a little to get the right deck height for the Parra button.
The Rossi Steel or ABC does work better than the MVVS and people have been doing this conversion for decades.
Ray
Hide Signatures
       Post #: 16
RE: MVVS update stock - 12/14/2012 4:56 AM
DeviousDave
Score: 110
Status: offline
quote:
ORIGINAL: fiery
Mmmm..... still waiting for my Wasp. The first run of right hand exhaust motors went out before my place in line came up. I guess he hasn't had a second run come in?
Hide Signatures
(in reply to fiery)
       Post #: 17
RE: MVVS update stock - 12/14/2012 4:57 AM
DeviousDave
Score: 110
Status: offline
quote:
ORIGINAL: Mr Cox
That's very useful! Thanks!
Hide Signatures
       Post #: 18
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> MVVS update stock
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
