Need work done on a Webra Speed 120    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Need work done on a Webra Speed 120
Page: [1] 2   next >   >>
Login
Need work done on a Webra Speed 120 - 12/11/2012 5:35 PM
ScottMcM
Score: 125
Last Login: 6/19/2013
Status: online
One of my flying buddies has a Webra Speed 120 that the compression is gone in. He has tried to disassemble it, but gets stopped at removing the piston. He can't seem to figure out how to pull the pin. He has asked me to see if I can find anyone that works on these engines, because he doesn't want to destroy it. If any of you guys can help, we would really appreciate it.
_____________________________
It is better to keep one''s mouth closed, and be thought a fool, than to open it, and remove all doubt.
Hide Signatures
       Post #: 1
RE: Need work done on a Webra Speed 120 - 12/11/2012 5:39 PM
Hobbsy
Score: 650
Status: offline
Scott, you should be able to screw a 4mm screw into the wristpin pull it out. I'll check my .91 and see.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to ScottMcM)
       Post #: 2
RE: Need work done on a Webra Speed 120 - 12/11/2012 5:41 PM
ScottMcM
Score: 125
Status: online
Thanks. I'll call him right now and tell him.
Hide Signatures
(in reply to Hobbsy)
       Post #: 3
RE: Need work done on a Webra Speed 120 - 12/11/2012 6:40 PM
ScottMcM
Score: 125
Status: online
He has another question. Does the Speed 120 have a head gasket?
Hide Signatures
       Post #: 4
RE: Need work done on a Webra Speed 120 - 12/11/2012 6:44 PM
Sport_Pilot
Score: 233
Status: offline
I think Webra did not use a head gasket, but you might find a shim which can be reused.   Has your friend located parts?  I don't think you can buy Webra parts unless someone has some NOS somewhere.  If it is a ringed engine you might be able to buy from Mr. Bowman, I am sure someone here will send the address.  Gaskets can be made from thin gasket material.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 5
RE: Need work done on a Webra Speed 120 - 12/11/2012 6:53 PM
ScottMcM
Score: 125
Status: online
I don't think he has located any parts, and that may be what kills this project. I believe it is a ringed engine. He claims that it runs, but that the compression is low.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 6
RE: Need work done on a Webra Speed 120 - 12/11/2012 7:04 PM
1QwkSport2.5r
Score: 155
Status: offline
As long as the piston and liner are in good shape, a new ring will have the engine running like new. Frank Bowman can be reached at ringmaster46@msn.com I believe.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 7
RE: Need work done on a Webra Speed 120 - 12/11/2012 7:37 PM
ScottMcM
Score: 125
Status: online
I just spoke with him. He got the engine disassembled(thanks for the advice). He says the piston and liner look good, but the piston moves"really easily" inside the liner. He says it looks as if the ring is a dykes(sp?) ring. Is that correct? If so, how hard is it to replace it, and can Frank Bowman supply them?
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 8
RE: Need work done on a Webra Speed 120 - 12/11/2012 8:26 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: ScottMcM
I just spoke with him. He got the engine disassembled(thanks for the advice). He says the piston and liner look good, but the piston moves''really easily'' inside the liner. He says it looks as if the ring is a dykes(sp?) ring. Is that correct? If so, how hard is it to replace it, and can Frank Bowman supply them?
I believe frank does make dykes rings, but I'd email him to verify.
The piston on a ringed engine will move easily in the liner, especially if it has a dykes ring or a worn out standard ring. Dykes ringed engines never feel like they have a lot of compression when turning over slowly. That's normal.
Hide Signatures
       Post #: 9
RE: Need work done on a Webra Speed 120 - 12/11/2012 8:43 PM
tiffitech
Score: 110
Status: offline
Yes Frank is makeng Dykes rings also, sent him a P&L Set for an 6,5ccm MVVS with broken Dykes Ring sometimes before and he made one for me. This MVVS is now on the List of Engines he makes Rings for. This is an incredible good Service from Frank and this for such a good price!
Regards,
Holm
Hide Signatures
       Post #: 10
RE: Need work done on a Webra Speed 120 - 12/11/2012 8:51 PM
ScottMcM
Score: 125
Status: online
I have sent him an email. Thanks for all your help, guys.
Hide Signatures
(in reply to tiffitech)
       Post #: 11
RE: Need work done on a Webra Speed 120 - 12/11/2012 9:27 PM
Sport_Pilot
Score: 233
Status: offline
A broken in dykes ring will feel like a worn out normal ring.  They use the compression pressure to expand out to fit the cylinder.  Probably just need to put it back together.
Hide Signatures
       Post #: 12
RE: Need work done on a Webra Speed 120 - 12/11/2012 10:06 PM
Hobbsy
Score: 650
Status: offline
Scott, one thing to check and consider, if it is a Dykes ringed engine. it will have lousy compression at flipping speeds. It depends on combustion pressure to push the ring outward. The idea is to reduce friction losses. If it has bars across the exhaust port it is a ringed, the ring will be on the top edge of the piston and almost invisible if Dykes ring. If no bars on exhaust port it is an ABN engine.
Hide Signatures
       Post #: 13
RE: Need work done on a Webra Speed 120 - 12/12/2012 12:04 AM
ScottMcM
Score: 125
Status: online
I have talked him into putting it back together, and running it. It may be ok. He said that it runs, but he didn't test it further.
Hide Signatures
       Post #: 14
RE: Need work done on a Webra Speed 120 - 12/12/2012 3:34 AM
captinjohn
Score: 247
Status: offline
My friend bought 2 of the1.20 Webra engines. One would hand start but the other one needed a electric starter to get it going.  I put a Frank Bowman ring in it & it had good compression before starting. It hand started real easy from then on.  Get Frank,s ring & don,t look back.   Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 15
RE: Need work done on a Webra Speed 120 - 12/12/2012 3:47 AM
earlwb
Score: 599
Status: offline
If the cylinder and piston aren't scored too much, I would just put a Bowman ring on it, and new bearings. It should be fine once the new ring seats in good. As the engines get larger and larger in displacement, they tend to have slightly more loose pistons in them. So a piston that seems a little loose may still be perfectly fine.
But new parts are going to be hard to find. When Webra went out of business, they closed up the factory. All the parts are there too. I don't know if anyone bought up the goods in a auction yet.  Most of the retailers didn't stock much in the way of parts for Webra engines, they would order the parts when a customer requested them. So the factory had all of the parts.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to captinjohn)
       Post #: 16
RE: Need work done on a Webra Speed 120 - 12/12/2012 7:00 AM
airraptor
Score: 131
Last Login: 6/20/2013
Status: offline
That webra 120 on a Bisson pitts muffler should spin a 15X8 Apc at around 9,100-9,200
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to earlwb)
       Post #: 17
RE: Need work done on a Webra Speed 120 - 12/12/2012 9:10 AM
ScottMcM
Score: 125
Status: online
He says the liner looks good. Wants to know if he should rough the liner up a tiny bit before installing the new ring, or just install the ring "as-is". Thanks again, guys, for the help. I was successful in getting a new ring ordered from Frank........I was wondering what to get the old guy(my friend) for Christmas.....I think this will do just fine.
Hide Signatures
(in reply to airraptor)
       Post #: 18
RE: Need work done on a Webra Speed 120 - 12/12/2012 11:54 AM
1QwkSport2.5r
Score: 155
Status: offline
The new ring from frank will have instructions; you use 400-600grit sandpaper and lightly buff a cross-hatch pattern into the liner. Nothing crazy.
Hide Signatures
       Post #: 19
RE: Need work done on a Webra Speed 120 - 12/12/2012 12:11 PM
earlwb
Score: 599
Status: offline
quote:
ORIGINAL: ScottMcM
I typically  just use the ring without roughing up the cylinder with super fine grit sandpaper. It might take a little longer to seat the ring on a more smooth surface, but then I don't run the risk or adding more premature wear into the mix either.  But it also depends on if the cylinder is hardened or not. Some engines use a hardened cylinder sleeve and the hardened surface is very thin, so roughing it up would wear through the hardened surface. Normally one would use a hone to hone the surface of the cylinder, but the special small Sunnen hones are quite expensive. You cannot use a brake cylinder hone as it is still too coarse for a model engine. A machinist person might make a homemade hone and use some lapping compound to hone a cylinder too.  But in my opinion, just leave the cylinder alone and use the new ring.
AMA # 928076
Hide Signatures
       Post #: 20
RE: Need work done on a Webra Speed 120 - 12/12/2012 3:13 PM  1 votes
blw
Score: 655
Status: offline
You won't go wrong if you let the ring do the work.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 21
RE: Need work done on a Webra Speed 120 - 12/12/2012 3:32 PM
tiffitech
Score: 110
Status: offline
It's not really needed to rough up the cylinder in a 2cycle engine. On a normal 4cycle the roughness is good to hold the oil on the surface and to make a good oil seal.
Our model engines aren't needing this and F. Bownman means this also. (Wrote it to me sometimes before in a mail)
Regards,
Holm
Hide Signatures
(in reply to blw)
       Post #: 22
RE: Need work done on a Webra Speed 120 - 12/12/2012 9:39 PM
1QwkSport2.5r
Score: 155
Status: offline
Frank included in all of the piston rings I have ordered from him a set of instructions. He suggests lightly buffing the inside of the liner with 400-600grit emery paper or sandpaper to seat the ring quicker. I'll go find those instructions and post them up later.
Hide Signatures
       Post #: 23
RE: Need work done on a Webra Speed 120 - 12/12/2012 9:59 PM
earlwb
Score: 599
Status: offline
Well unless someone knows what is meant by the "lightly buffing" the cylinder wall, they are well advised to not mess with it. Many people have ruined otherwise, what would be  useable cylinders, doing it.
AMA # 928076
Hide Signatures
       Post #: 24
RE: Need work done on a Webra Speed 120 - 12/13/2012 12:47 AM
proptop
Score: 130
Last Login: 6/5/2013
Status: offline
My take on it is...(after a close up inspection w/ jewlers loupe ) if the engine doesn't have a whole lot of time on it, and there is no visable varnish present...no ridge at the top of the bore...factory cross hatch still obvious...then leave it alone.
If the cyl. wall looks like it has a glaze on it, then I will use 1000 grit wet/dry w/ light oil wrapped around my finger...just a few minutes to clean things up some....no metal removed, just varnish, crud, whateveryawannacallit...
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Need work done on a Webra Speed 120
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
