Glue question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Glue question
Page: [1]
Login
Glue question - 12/11/2012 9:45 PM
aashu
Score: 100
Last Login: 4/28/2013
Status: offline
Which one to be used for gluing accessories ? I have been using e6000 but that stays a little think and rubbery
Hide Signatures
       Post #: 1
RE: Glue question - 12/12/2012 3:42 PM
karel47
Score: 149
Last Login: 5/22/2013
Status: offline
i use bison industrial supergleu
for all my rc tanks and boats too
Click to see fullsize image.
Click for fullsize
_____________________________
PanzVI-J,ShermanM4A4,PershingM26,KTPorsche2x,KTHenshel Late3x-Early1x,TigerI 3x,JP,Panther,Jagdtiger;PantherIIta;PanthHL;Stu
Hide Signatures
(in reply to aashu)
       Post #: 2
RE: Glue question - 12/12/2012 4:27 PM
sevoblast
Score: 121
Status: online
For Tamiya, regular plastic modeling glue works fine. Testor Model Masters is what I use, black jug with a needle applicator. However, most others including Hooben use ABS plastic, not styrene, so a different glue is needed, readily available in your AO, though. Just head for any hobby shop that sells Plastruct shapes and they should have the plastruct glues also. Plastruct is generally ABS plastic.
Robert Herne
Owner - ETO Armor
Hide Signatures
(in reply to aashu)
       Post #: 3
RE: Glue question - 12/12/2012 6:20 PM
FreakyDude
Score: 107
Status: offline
Like Sevoblast I use basicly the same product (different brand ) and I change my glue based on the plastic type and strength needed to hold the part. Heck I even change cryanolates based on the sheer strength and dry times I need. Some things you just want on their forever lol
quote:
ORIGINAL: sevoblast
www.immortalhobbies.com
Hide Signatures
(in reply to sevoblast)
       Post #: 4
RE: Glue question - 12/12/2012 8:28 PM
ausf
Score: 105
Status: online
As stated, depends on the materials. Tamiya and other modeling companies generally use styrene, but the HL and other toy grade stuff is ABS plastic. Both have to be melted together with a solvent, which is what the glues are. Testors and others for styrene are usually either orange solvent or acetone. ABS needs MEK (don't waste your time trying the Home Depot MEK substitute or plumbing ABS glue, neither work). MEK works well on both plastics, but is overkill on styrene. Plastruct makes Plastiweld, which is MEK with a conditioner to prolong evaporation (rebottled at a huge markup). As it is, the stuff evaporates so fast, you have to work in small areas otherwise it's gone before it bonds.
The difference between styrene and ABS for our purposes is styrene is better in molding and holding more detail, ABS is cheaper, but stronger. Styrene can produce beautiful detail in 1/72 tanks, ABS can plumb the waste pipes in your house. I assume HL uses it for cost cutting, choosing strength over detail.
What, me worry?
Hide Signatures
(in reply to FreakyDude)
       Post #: 5
RE: Glue question - 12/12/2012 8:57 PM
Panther F
Score: 135
Last Login: 5/21/2013
Status: offline
I work with Ambroid Pro Weld which is for all materials (except metal) so there's no need to switch up all the time.
~ Jeff
Hide Signatures
(in reply to ausf)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
