RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Andy Sheber Pitts s1s - 12/17/2012 12:50 AM
straitnickel
Score: 105
Last Login: 5/19/2013
Status: offline
Sounds good
_____________________________
I don''''t always crash, but when I do!
Hide Signatures
(in reply to acerc)
       Post #: 101
RE: Andy Sheber Pitts s1s - 12/17/2012 1:49 AM
acerc
Score: 221
Status: offline
Well, I change my mind. After pouring over photo's I have realized doing it that way would leave an opening between the wing and gear. That would not look right. And believe it or not my wife gave me a great idea. I am going to make the belly pan to cover from the rear of the wing to the front of the fuse. Then I can just make the gear removeable. I think this will work best and keep the look's as is.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to straitnickel)
       Post #: 102
RE: Andy Sheber Pitts s1s - 12/17/2012 3:12 AM
acerc
Score: 221
Status: offline
I took some preformed gear I have for another plane and put it in place on the Pitts. Looks like the removeable pan will work out great. Now that I have that figured out I can get back to work on it.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 103
RE: Andy Sheber Pitts s1s - 12/17/2012 9:37 AM
john josey
Score: 110
Last Login: 5/18/2013
Status: offline
Robert, is there any pictures of my TC pitts that i can post to maybe give you some ideas that you can adapt to suit your own needs. At the moment i have the cowl and the bottom of the fusalage (between the top of the undercarrage) off the model as i'm re-routing the lines for the smoke system ?
Hide Signatures
(in reply to acerc)
       Post #: 104
RE: Andy Sheber Pitts s1s - 12/17/2012 12:00 PM
RickBoyer
Score: 100
Status: offline
Hi Ken,
I have a set of Andy Sheber 1/4 scale Pitts S-2A plans (wingspan of 60"). The model was designed around a .90 two stroke/ 1.20 four stroke.
Rick Boyer
Top Gun 2004-2012
Pitts Special S-1S (#1)
Ryan STA
Pitts Special S-1S (#2)
Hide Signatures
(in reply to flyingagin)
       Post #: 105
RE: Andy Sheber Pitts s1s - 12/17/2012 1:23 PM
DGUY
Score: 115
Last Login: 4/5/2013
Status: offline
I love the Pitts...wish there was a smaller version that would take a 60-90 two stroke.
subscribed.
Derrick
Spitfire Brotherhood #28
AMA # 919758
Hide Signatures
(in reply to RickBoyer)
       Post #: 106
RE: Andy Sheber Pitts s1s - 12/17/2012 1:49 PM
acerc
Score: 221
Status: offline
Actually JJ their is. One from the front, of the bottom. Showing the contour of the belly area between the gear.
Robert
Hide Signatures
(in reply to DGUY)
       Post #: 107
RE: Andy Sheber Pitts s1s - 12/17/2012 2:54 PM
acerc
Score: 221
Status: offline
After all that fuss on the wing/gear issue I feel I need to explain a little. First off these plans are excellently drawn. There is nothing wrong with the design of the plans what so ever. I just know me, and I know with the pivoting gear it would not be long before I did something stooped and broke something. That is the only reason I am making them removable.
DGUY these plans could be reduced to a 60-90 size very easily. I bet you could even get them that way.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 108
RE: Andy Sheber Pitts s1s - 12/17/2012 3:09 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
No problem Robert. Taking them from the front didnt really show that well but i think these will tell you what your looking for (hopefully)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 109
RE: Andy Sheber Pitts s1s - 12/17/2012 3:41 PM
acerc
Score: 221
Status: offline
Thank's JJ. That is what I'm going with only it will be a one piece. I feel better now.
Robert
Hide Signatures
(in reply to john josey)
       Post #: 110
RE: Andy Sheber Pitts s1s - 12/17/2012 3:50 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Happy to help. If theres any other pictures you think might help along the way just let me know.
Hide Signatures
(in reply to acerc)
       Post #: 111
RE: Andy Sheber Pitts s1s - 12/17/2012 4:50 PM
drac1
Score: 100
Last Login: 5/6/2013
Status: offline
Hi Robert. Where did you get the plans from?
Cheers
There is no such thing as too much power.
Hide Signatures
(in reply to acerc)
       Post #: 112
RE: Andy Sheber Pitts s1s - 12/17/2012 5:29 PM
acerc
Score: 221
Status: offline
The firewall and top half formers are in and drying.
The plans call for 0degs thrust angles on the engine, the wing's call for 0degs incedence, and the stab has zero in print but measures out at 2degs.
Any comment's on these numbers?
Click for fullsize
Robert
Hide Signatures
(in reply to drac1)
       Post #: 113
RE: Andy Sheber Pitts s1s - 12/17/2012 5:35 PM
RickBoyer
Score: 100
Status: offline
Hey Robert,
You definitely want to build the Sheber Pitts S-1S with 0 degrees of incidence on both wings and 1 1/2 to 2 degrees of positive incidence on the stabilizer along with at least 1 degree of right thrust on the engine due to tork.
Both of mine flew with near perfect trim with this setup.
Rick Boyer
Top Gun 2004 to 2012
Ryan STA
Hide Signatures
(in reply to acerc)
       Post #: 114
RE: Andy Sheber Pitts s1s - 12/17/2012 5:40 PM
rs917
Score: 105
Last Login: 5/15/2013
Status: offline
Nice work Robert. Either you're a fast builder, or I've overestimated the amount of time it takes to build a kit like this. Either way, nice looking plane so far.
-Mike
Hide Signatures
       Post #: 115
RE: Andy Sheber Pitts s1s - 12/17/2012 6:15 PM
acerc
Score: 221
Status: offline
Thank's Rick! That is what I'll do.
Robert
Hide Signatures
(in reply to rs917)
       Post #: 116
RE: Andy Sheber Pitts s1s - 12/17/2012 6:34 PM
straitnickel
Score: 105
Status: offline
On the incidence question, I had a bme challenger witch called for a positive incidence in the top wing I went with zero and it flew just fine. If you have a real flight simulator, there is an blue ultimate plane in the sim. that the incidence in the wing and tail that can be changed to what ever value posative or negative you would like. I did this and zero was my choice top, bottom and back.
Hide Signatures
(in reply to acerc)
       Post #: 117
RE: Andy Sheber Pitts s1s - 12/17/2012 7:53 PM
john josey
Score: 110
Status: offline
My TCpitts has 0 for both wings, +2 for the stab and 2deg right thrust on the engine which seems to stack up with the others
Hide Signatures
       Post #: 118
RE: Andy Sheber Pitts s1s - 12/17/2012 8:00 PM
john josey
Score: 110
Status: offline
Robert, while i remember, my own pitts has 5mm or 3/16" of right rudder. Something to do with the propwash was the explanation.
Hide Signatures
       Post #: 119
RE: Andy Sheber Pitts s1s - 12/17/2012 10:15 PM
acerc
Score: 221
Status: offline
Thank's to everyone for their input on all the angles.
Something interesting thought I'd share. I called the manufacturer and their specs on the angles are, Engine thrust 0-0, stab incedence +2degs, fin 0, and the wing's T&B  +1.5degs. I do understand why the full scale would have + on the wing's.
Anyhow, I have built the engine mount box, the top stringers are on, and I put in the ele & rud servo mount ply. In the morning when I can install the engine mount I will post pics. I have also cut up all the laminating ply for the ele, rud, and wing tips. Can't go no further untill some epoxy dries.
Robert
Hide Signatures
       Post #: 120
RE: Andy Sheber Pitts s1s - 12/17/2012 10:34 PM
john josey
Score: 110
Status: offline
Your cracking on well Robert. I was nine months with mine and that was a kit ! I can see you having this thing done for the start of spring !
You've got me thinking....I've never owned a twin and i've been kind of looking at this - http://www.glensmodels.com/2005.htm
Sorry, the link is just taking you to the home page, the engine is the Zenoah 80 twin
Hide Signatures
(in reply to acerc)
       Post #: 121
RE: Andy Sheber Pitts s1s - 12/17/2012 10:37 PM
acerc
Score: 221
Status: offline
A friend at my field has this same engine in a Yk. It is unreal!
Robert
Hide Signatures
       Post #: 122
RE: Andy Sheber Pitts s1s - 12/17/2012 10:43 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Just so much smoother
Hide Signatures
(in reply to acerc)
       Post #: 123
RE: Andy Sheber Pitts s1s - 12/17/2012 10:46 PM
acerc
Score: 221
Status: offline
That they are.
Robert
Hide Signatures
       Post #: 124
RE: Andy Sheber Pitts s1s - 12/18/2012 12:05 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: RickBoyer
Hey Robert,
Rick Boyer
Ryan STA
Rick, do you have any detailed pictures of the cockpit and more importantly, the size from the seat to the turtle deck at the pilots head ? from what i can see, the size of a 1/3 scale pilot is 300mm/12" from the seated position to his head and if that is the case i could be in trouble !
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
