RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
Users viewing this topic:
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,880.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Andy Sheber Pitts s1s - 12/18/2012 6:53 PM
acerc
Score: 221
Last Login: 6/20/2013
Status: offline
I have used the aluminum flasing from the Improvement store's.  It is 10"x10'x0.0092, not sure if it would be better than glass. My dilema with aluminum is I'm not quite sure how well paint will stick to it.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to wayne d)
       Post #: 151
RE: Andy Sheber Pitts s1s - 12/18/2012 7:57 PM
acerc
Score: 221
Status: offline
Aren't I a lucky dog. I was just talking with a fellow club member about the aluminum. And he has some lithoplate and is giving me two sheets. I figure I will cut the litho to the size of each panel and then laminate a 1/64 ply, except at the overlap,  to the back side. I would like for the front section to be removable so as to have access to the throttle and choke servos, the cabane fasteners, fuel and oil tank. I think this will work.
  And I'm still not sure how well paint will adhere to the aluminum.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 152
RE: Andy Sheber Pitts s1s - 12/18/2012 8:42 PM
wayne d
Score: 105
Status: online
Paint will stick but needs a self etching primer on it first.
Available at the local auto parts store.
Best Regards,
Wayne Fussell Pres. Solo Propellers & RC Products
Hide Signatures
(in reply to acerc)
       Post #: 153
RE: Andy Sheber Pitts s1s - 12/18/2012 8:45 PM
acerc
Score: 221
Status: offline
Thanks Wayne. I'll see what I can find.
Robert
Hide Signatures
       Post #: 154
RE: Andy Sheber Pitts s1s - 12/18/2012 8:52 PM
Hinckley Bill
Score: 100
Status: offline
Quick question...
In order to get those laminated curves did you soak the wood beforehand in a water/ammonia solution or ????
Looks great.
Hide Signatures
(in reply to acerc)
       Post #: 155
RE: Andy Sheber Pitts s1s - 12/18/2012 8:55 PM
cubcrasher
Score: 107
Status: offline
quote:
ORIGINAL: acerc
Dupont veri-prime self etching primer mixed with converter 50/50
R.L.
cub brother #31
Hide Signatures
(in reply to acerc)
       Post #: 156
RE: Andy Sheber Pitts s1s - 12/18/2012 9:01 PM
acerc
Score: 221
Status: offline
Bill it was just water. The key is to use lightply. It takes the water much better than regular ply.
Thank's R.L.
< Message edited by acerc -- 12/18/2012 11:24 PM >
Robert
Hide Signatures
(in reply to cubcrasher)
       Post #: 157
RE: Andy Sheber Pitts s1s - 12/18/2012 9:12 PM
john josey
Score: 110
Status: offline
Robert, i was just thinking about that panel myself the other day. On the fullsize pitts, does that panel sit flat on the airframe or is there a gap ? i know mine is finished but i'd like to add that panel and was wondering could i use some 1/64 ply to create the step and just feather it back to nothing ?
Coming on a treat BTW !
Hide Signatures
(in reply to acerc)
       Post #: 158
RE: Andy Sheber Pitts s1s - 12/18/2012 9:44 PM
acerc
Score: 221
Status: offline
John,  in the photo below you can see there is no gap between the panels or between the panel and the fabric. On the full size the panels are riveted/screwed to a former so there would be no gap between the panel and former. The rest of the panel is over open structure behind the panels.
Click to see fullsize image.
Click for fullsize
Robert
Hide Signatures
(in reply to john josey)
       Post #: 159
RE: Andy Sheber Pitts s1s - 12/18/2012 9:52 PM
wayne d
Score: 105
Status: online
Will these help.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Best Regards,
Hide Signatures
(in reply to acerc)
       Post #: 160
RE: Andy Sheber Pitts s1s - 12/18/2012 10:17 PM
john josey
Score: 110
Status: offline
Ah, ok. Thanks guys, i didnt realise they came that far back. Robert, are you covering with some sort of fabric and then painting ?
Hide Signatures
       Post #: 161
RE: Andy Sheber Pitts s1s - 12/18/2012 10:32 PM
acerc
Score: 221
Status: offline
Yes Sir! Polylite from Aircraftspruce. And stits paint.
Robert
Hide Signatures
       Post #: 162
RE: Andy Sheber Pitts s1s - 12/18/2012 10:44 PM
john josey
Score: 110
Status: offline
I wonder if it's called something else over here as i've not heard of that before.....i'll google it and have a look
Do you guys remember the 'PILOT' kits from japan ?
Hide Signatures
(in reply to acerc)
       Post #: 163
RE: Andy Sheber Pitts s1s - 12/18/2012 11:13 PM
acerc
Score: 221
Status: offline
JJ let us know what you find. Added some, whatever there called, to the fin and rudder. When dry I will finish it up.
Click for fullsize
Robert
Hide Signatures
       Post #: 164
RE: Andy Sheber Pitts s1s - 12/19/2012 12:33 AM
acerc
Score: 221
Status: offline
Question, in the photos below one of the same plane there are some kind of balance whatchamacalit on one but not the other. What is it, what is it for, and opinion on installing onto a model?
Click for fullsize
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 165
RE: Andy Sheber Pitts s1s - 12/19/2012 12:47 AM
straitnickel
Score: 105
Status: offline
There is an air shovel on the lower aileron one on each lower like power steering.
I don''''t always crash, but when I do!
Hide Signatures
(in reply to acerc)
       Post #: 166
RE: Andy Sheber Pitts s1s - 12/19/2012 12:55 AM
acerc
Score: 221
Status: offline
Thank's that's cool.
And opinion on installing onto a model?
Robert
Hide Signatures
(in reply to straitnickel)
       Post #: 167
straitnickel
Score: 105
Status: offline
In the second pic on the left jurystrut there is a tubeing that shows 45° and 90° to the pilot as they fly aerobatics.
And on the air shovel I have never seen only one, it's just not visible in this pic.
Hide Signatures
       Post #: 168
RE: Andy Sheber Pitts s1s - 12/19/2012 12:56 AM
acerc
Score: 221
Status: offline
You talkin about that antenna looking thing?
Robert
Hide Signatures
       Post #: 169
RE: Andy Sheber Pitts s1s - 12/19/2012 1:05 AM
straitnickel
Score: 105
Status: offline
Yep, there are different styles, and I don't know the proper name for them.
I callem angle indicators. I'm gonna go look that up.
Hide Signatures
(in reply to acerc)
       Post #: 170
RE: Andy Sheber Pitts s1s - 12/19/2012 1:34 AM
WacoNut
Score: 175
Status: offline
Hey Robert that fin/rudder looks like crap
You asked for it LOL.
Seriously the build is looking good.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 171
RE: Andy Sheber Pitts s1s - 12/19/2012 1:37 AM
acerc
Score: 221
Status: offline
Anything is better than nothing!
Robert
Hide Signatures
(in reply to WacoNut)
       Post #: 172
RE: Andy Sheber Pitts s1s - 12/19/2012 1:54 AM
straitnickel
Score: 105
Status: offline
Ace,
Are the wing tips and rest of the tail going to be a bow like the rudder?
Hide Signatures
(in reply to acerc)
       Post #: 173
RE: Andy Sheber Pitts s1s - 12/19/2012 1:56 AM
acerc
Score: 221
Status: offline
Yes it is.
Robert
Hide Signatures
       Post #: 174
RE: Andy Sheber Pitts s1s - 12/19/2012 2:00 AM
straitnickel
Score: 105
Status: offline
Holey Mackerel! This is one great model.
Hide Signatures
(in reply to acerc)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
