RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Andy Sheber Pitts s1s - 12/21/2012 7:13 PM
acerc
Score: 221
Last Login: 5/25/2013
Status: offline
The following is one of the reasons not much work will be done over the next few days.
Have to put other thing's together. What ya'll think, will it fly?
Click to see fullsize image.
Click for fullsize
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to acerc)
       Post #: 251
RE: Andy Sheber Pitts s1s - 12/21/2012 7:25 PM
straitnickel
Score: 105
Last Login: 5/24/2013
Status: offline
Ace,
That's gonna fly for somebody.
I don''''t always crash, but when I do!
Hide Signatures
(in reply to acerc)
       Post #: 252
RE: Andy Sheber Pitts s1s - 12/21/2012 9:01 PM
acerc
Score: 221
Status: offline
I have been going over these wing plans real good. Just want to make sure I have all the bases covered. There is one thing I will change. In the pic at the rear of the rib there is a rectangular cut out 1/4 x 7/16. This is for a piece of hardwood to run from outer rib to outer rib. I do not have the tools to replicate this 28 times as accurately as I want it. So I am going to change this to a 3/8 dowel.
Click for fullsize
Robert
Hide Signatures
(in reply to straitnickel)
       Post #: 253
RE: Andy Sheber Pitts s1s - 12/21/2012 10:39 PM
acerc
Score: 221
Status: offline
And here are the routered ribs. Next is the drill press for some lightening holes and the dowel hole.
Click for fullsize
Click for fullsize
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 254
RE: Andy Sheber Pitts s1s - 12/21/2012 10:58 PM
Melchizedek
Score: 100
Status: offline
Ace,
What is your way to make the stringer notches ?
Do you have a technique to make accurate repetetive cuts ?
Newbie builder here.
Kevin
Hide Signatures
(in reply to acerc)
       Post #: 255
RE: Andy Sheber Pitts s1s - 12/21/2012 11:22 PM
acerc
Score: 221
Status: offline
I believe I do.
Pic1-After the router while still attached to the templet I cut the recess in the band saw. -This band saw cut is not exact just loosens up the inside.
Pic2-Now I line them up square, true, and held firmly.
Pic3-Then I make a sanding stick with a mark for depth.
Pic4- Put a good straight edge on the cut and sand with the stick.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Robert
Hide Signatures
(in reply to Melchizedek)
       Post #: 256
RE: Andy Sheber Pitts s1s - 12/21/2012 11:39 PM
Melchizedek
Score: 100
Status: offline
Thanks ace.
Grasshopper very grateful
The more I see a the potential of a magnetic building board the more I want one.
Building a Sig Kadet Lt 40 on drywall now. The next plane will be built on a magnetic board.
Kevin
Hide Signatures
(in reply to acerc)
       Post #: 257
RE: Andy Sheber Pitts s1s - 12/21/2012 11:47 PM
acerc
Score: 221
Status: offline
You are welcome. Nothing like a magnedic one. Wait till you see how much of this wing is assembled before a drop of glue hit's it.
Robert
Hide Signatures
       Post #: 258
RE: Andy Sheber Pitts s1s - 12/22/2012 12:54 AM
wayne d
Score: 105
Status: offline
Hey Robert
You seem to be moving at a fast pace. Love it.
You may have noticed with a couple of pictures I posted that I used flite skin fiberglass sheets instead of aluminum.
I am not completely happy with the way it turned out and have been thinking about removing it, smoothing the balsa skin again and using conventional glass and finishing resin.
I'm trying to talk myself out of it but it's not working.
I could then simulate the panels using high full primer.
Oh, what do I do?
Best Regards,
Wayne Fussell Pres. Solo Propellers & RC Products
Hide Signatures
(in reply to acerc)
       Post #: 259
RE: Andy Sheber Pitts s1s - 12/22/2012 1:05 AM
acerc
Score: 221
Status: offline
Hey Wayne, Thank's.You know how it is as soon as I get thru the frameing it will slow way down. I have done panels with glass, aluminum, plastic, and even poster board. But leaving those big chunks of balsa out makes it a little different.  I got some litho plate from a friend, it is super thin and flexible. So I will back it with 1/64ply,  minus the overlap of course. I think, hopefully, this will be a bit lighter. But it does what I wanted to do and that is make them removeable.
  Here's the ribs all done with the dowel stuck in the back side. Fine tuning will take place during instalation, if needed.
Click for fullsize
Robert
Hide Signatures
(in reply to wayne d)
       Post #: 260
RE: Andy Sheber Pitts s1s - 12/22/2012 1:38 AM
acerc
Score: 221
Status: offline
All the nose of the Waco is 1/64 ply, the gear covers are aluminum, and the gear fairings are fiberglass.
The nose of the Cub is poster board, and the gear covering is balsa covered in flite metal.
Click for fullsize
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 261
RE: Andy Sheber Pitts s1s - 12/22/2012 2:22 AM
acerc
Score: 221
Status: offline
Fine! If ya'll insist. Here's some more building. The wings have been started. The bottom wing left half.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 262
RE: Andy Sheber Pitts s1s - 12/22/2012 2:30 AM
acerc
Score: 221
Status: offline
Here ya go! I'm no fan of thumb screws so I used regular.
Also if your gonna want any real down force there needs to be four magnets on the front instead of two.
Click for fullsize
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 263
RE: Andy Sheber Pitts s1s - 12/22/2012 3:00 AM
Melchizedek
Score: 100
Status: offline
Ace,
Was going to ask you about your fixtures for your magnets.
Do you have any other types than the ones you just showed ?
Also on a build such as the Pitts, about how many fixtures will you use ?
How many magnets, loose and attatched to fixtures will you use at one time ?
The magnets come in a box of 100.
Are 100 sufficient for a build like the Pitts ?
Kevin
Hide Signatures
(in reply to acerc)
       Post #: 264
RE: Andy Sheber Pitts s1s - 12/22/2012 3:14 AM
wayne d
Score: 105
Status: offline
How about posting a link to the magnets.
Best Regards,
Hide Signatures
       Post #: 265
RE: Andy Sheber Pitts s1s - 12/22/2012 3:20 AM
acerc
Score: 221
Status: offline
Here ya go.  http://www.magnetsource.com/Solutions_Pages/latches-catches3.html
Robert
Hide Signatures
       Post #: 266
RE: Andy Sheber Pitts s1s - 12/22/2012 3:28 AM
acerc
Score: 221
Status: offline
Kevin they will sell any number just call them. I got 100  loose magnets and 13 fixtures. For hold downs I usually use the magnets under the piece with a rubber band.  I don't really use the fixtures much other than to hold something square. I could use a few more, probably 100. If I try to form up an entire wing like I am doing on this pitts I will use most of them. So 250 should be sufficient. As a matter of fact I think I am going to go and order myself another 100. Thank's!
Robert
Hide Signatures
(in reply to acerc)
       Post #: 267
RE: Andy Sheber Pitts s1s - 12/22/2012 3:34 AM
straitnickel
Score: 105
Status: offline
Ace,
Did the pic.s of the canopy get through?
Hide Signatures
(in reply to acerc)
       Post #: 268
RE: Andy Sheber Pitts s1s - 12/22/2012 3:36 AM
acerc
Score: 221
Status: offline
I don't recall seeing it. Where did you send it to?
Robert
Hide Signatures
       Post #: 269
RE: Andy Sheber Pitts s1s - 12/22/2012 4:17 AM
acerc
Score: 221
Status: offline
Ok! A little more. Thats about all I can do until romorrow. I need to cut some spars, leading and trailing edges.
Speaking of spars he says to make them out of balsa, hmmmmmm.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 270
RE: Andy Sheber Pitts s1s - 12/22/2012 4:40 AM
john josey
Score: 110
Status: offline
hmmmmmm. Indeed Robert. That would make me nervous !
Hide Signatures
(in reply to acerc)
       Post #: 271
RE: Andy Sheber Pitts s1s - 12/22/2012 4:50 AM
straitnickel
Score: 105
Status: offline
Maybe the fly wires are functional?
Hide Signatures
(in reply to john josey)
       Post #: 272
RE: Andy Sheber Pitts s1s - 12/22/2012 5:14 AM
wayne d
Score: 105
Status: offline
My S2 had, key word HAD balsa spars. Changed to spruce for the main center spar with the rear secondary spar balsa..
And yes, I do believe the flying wires are functional.
Best Regards,
Hide Signatures
       Post #: 273
RE: Andy Sheber Pitts s1s - 12/22/2012 6:51 AM
DGUY
Score: 115
Last Login: 4/5/2013
Status: offline
Robert, thanks for the pictures of the jigs. I hear ya about using the four magnets for real holding power...
Derrick
Spitfire Brotherhood #28
AMA # 919758
Hide Signatures
(in reply to acerc)
       Post #: 274
RE: Andy Sheber Pitts s1s - 12/22/2012 4:00 PM
acerc
Score: 221
Status: offline
For those that have not done this I thought I'd share how I cut my ribs. I make a copy of the rib in question on my copier. Then I glue the copy to some 1/4 ply with 3m spray adhesive. I then cut this rib on the band saw and do a fine edge finish with a sander. This is now a template. I put two screws thru the template that will hold several pieces of balsa. I then screw the balsa to the template, one towards the front and one toward the rear, and then route the balsa useing a laminate trim bit.. The bearing on the bit runs the ply while cutting the balsa. All 28 ribs come out identical.
Robert
Hide Signatures
(in reply to DGUY)
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
