RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Andy Sheber Pitts s1s - 12/22/2012 5:54 PM
Melchizedek
Score: 100
Last Login: 5/21/2013
Status: offline
Ace,
Earlier when you had said you were using a templat and router to cut your ribs. I knew exactly what you meant (i am a cabinet maker).
Although, I had not thought of using the big guns on balsa. It makes perfect sense.
I will be making a little router table for my next airplane (scratch built with plan's).
I had invisioned gluing paper on all ribs, cutting close, and then sanding all to that fat line, one by one. (not so precise).
Thank you for your tutorials on how you build. Soaking it up !
Kevin
Hide Signatures
(in reply to acerc)
       Post #: 276
RE: Andy Sheber Pitts s1s - 12/22/2012 8:40 PM
acerc
Score: 221
Last Login: 5/22/2013
Status: offline
Glad to have been of some help Kevin.
I have been most the day cutting up the pieces for the wings, LE, TE, spars, ply ribs(for the center-but joint), servo trays, etc. The only thing I have actually put together was laminating the wing strut mounts. I think I have most everything cut. So as soon as the strut mounts dry I can start glueing it together.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to Melchizedek)
       Post #: 277
RE: Andy Sheber Pitts s1s - 12/22/2012 11:26 PM
acerc
Score: 221
Status: offline
Well the part in that last post where I said "most" is where I was at when my band saw blade broke. Last piece too, the trailing edge.
So I run to Ace and I'm 4 minutes late, they are closed. Humbug!!!
Robert
Hide Signatures
(in reply to acerc)
       Post #: 278
RE: Andy Sheber Pitts s1s - 12/23/2012 12:35 AM
acerc
Score: 221
Status: offline
Not a real productive day model wise. But I think the left half is ready for some glue. I will get on that in the morning.
By the way, the trailing edge seen in this pic was hand cut cut with a zona blade. Man I miss my band saw!
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by acerc -- 12/23/2012 2:42 AM >
Robert
Hide Signatures
(in reply to acerc)
       Post #: 279
RE: Andy Sheber Pitts s1s - 12/23/2012 1:36 AM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: acerc
20yrs ago i worked for a local kit manufacturer and my job was cowls, epoxy glass undercarrage, veneering the foam wings and the dreaded fusalage sides which had to be done using a router ! i'm not sure what it was Robert, maybe the blade was blunt, entering at wrong angle or simply too much left on the blanks, but it would 'grab' and catapult what you were holding to the other end of the workshop so ever since then i have been teriffied to go anywhere near a router !
I have managed to get round my 'fear' by using the disc sander.
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 280
RE: Andy Sheber Pitts s1s - 12/23/2012 1:40 AM
grover1
Score: 100
Last Login: 4/22/2013
Status: offline
acerc
Looking good
Did you get more than one copy of the plans for your templates or just scan the parts from the plans .
Hide Signatures
(in reply to acerc)
       Post #: 281
RE: Andy Sheber Pitts s1s - 12/23/2012 1:44 AM
acerc
Score: 221
Status: offline
I just scan the plans on a standard home scanner. You just have to take a measurement on the first copy of anything to make sure the scanner is sized right.
Robert
Hide Signatures
(in reply to grover1)
       Post #: 282
RE: Andy Sheber Pitts s1s - 12/23/2012 1:52 AM
acerc
Score: 221
Status: offline
JJ two issues with routers and balsa. One is balsa is to soft so I cut it with the band saw to withing a 1/4" of the template, this is so the balsa does not wrap around the router bit.  Second is the direction of feed, generally one feeds the wood in the same direction as the bit's rotation. Once again the balsa is to soft and the bit's will grab hold and, you know. Go against the rotation and its smooth as silk.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 283
RE: Andy Sheber Pitts s1s - 12/23/2012 1:56 AM
acerc
Score: 221
Status: offline
And by the look's of those ribs the disk sander works well for you. We all find what works for us.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 284
RE: Andy Sheber Pitts s1s - 12/23/2012 2:45 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
I think your right Robert, we as modelers seem to be able to adapt to what we have available without much problem (fortunatly)
Hide Signatures
(in reply to acerc)
       Post #: 285
RE: Andy Sheber Pitts s1s - 12/23/2012 7:08 PM
acerc
Score: 221
Status: offline
I just got home from a day of flying and am rather disheartened. A fellow club member has a Cub he just painted the wing's, tailfeathers, and a big stripe down the side, black. I flew it and did not even leave the ground ground before realizing I have a major issue with seeing black. Flew two circles by way of the wheels hanging down because all I could see was a big black dot. So the black is out for the Pitts. I have no idea what color scheme I will go with.
  I did pick up a new band saw blade.
Robert
Hide Signatures
(in reply to john josey)
       Post #: 286
RE: Andy Sheber Pitts s1s - 12/23/2012 7:19 PM
straitnickel
Score: 105
Status: offline
Sorry to hear that ace, Last summer I realized not all colors show well in the air, the sun has to hit it just right. For what it's worth, l know for a fact that my pitts challenger was the easiest plane to see I ever had.
I don''''t always crash, but when I do!
Hide Signatures
(in reply to acerc)
       Post #: 287
RE: Andy Sheber Pitts s1s - 12/23/2012 7:51 PM
Melchizedek
Score: 100
Status: offline
Sorry for your inability to see black well.
Can you see red.
Hot Rod Red always looks cool on a stunt plane.
I am doing my Kadet in translucent red and bright white.
Chin up Ace, it's Christmas
For unto us a child is born, unto us a son is given: and the government shall be upon his
shoulder: and his name shall be called Wonderful, Counseller, The mighty God, The everlasting Father,
The Prince of Peace.
Isaiah 9:6
Kevin
Hide Signatures
(in reply to acerc)
       Post #: 288
RE: Andy Sheber Pitts s1s - 12/23/2012 8:20 PM
Cub Flyer Fresno
Score: 115
Status: online
Amen Kevin!  The reason for the season!  That's also my favorite song from Handle's Messiah.
Hey Robert, remember when you asked my opinion?  Go for the Ford color scheme, come on, go for it!
Click for fullsize
Cub Brotherhood #65
Hide Signatures
       Post #: 289
TFF
Score: 148
Status: offline
All colors tend to go black the farther we fly out. Black starts out the worse. Years ago someone painted their pattern plane black and the pilot and the judges could not see it to do well. My Jungmiester is yellow with markings identical on top and bottom. I have to concentrate the whole flight; upside down looks the same as upright.
Hide Signatures
       Post #: 290
RE: Andy Sheber Pitts s1s - 12/23/2012 8:33 PM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Ah, that is a set back Robert. that was without a doubt the main reason i went with the dark yellow. My favorite colour for the pitts is the marion cole colours, but even they are not great for the sky's we get here on the west coast of scotland for 90% of the year.
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 291
RE: Andy Sheber Pitts s1s - 12/23/2012 8:39 PM
straitnickel
Score: 105
Status: offline
Overcast days?, I don't fly, my plane goes black in no time.
Hide Signatures
       Post #: 292
RE: Andy Sheber Pitts s1s - 12/23/2012 8:46 PM
straitnickel
Score: 105
Status: offline
I primed this plane in ligjt gray then painted with brite red. It came out kind of a satin finish. No shine to it made it very visiable. I notice the mirror finish reflects the sun disturbing my view. The sun at my back is a big help also.
Hide Signatures
(in reply to straitnickel)
       Post #: 293
RE: Andy Sheber Pitts s1s - 12/23/2012 8:57 PM
acerc
Score: 221
Status: offline
Thank's for the support guy's. I think I am going with a bit of a controversial scheme. Maybe even paint a cigarette on the lowewr rear fuse and rig a smoke system to come out at the end of it.
Click for fullsize
Robert
Hide Signatures
       Post #: 294
RE: Andy Sheber Pitts s1s - 12/23/2012 9:05 PM
john josey
Score: 110
Status: offline
LOL thats not a bad idea !
Hide Signatures
(in reply to acerc)
       Post #: 295
RE: Andy Sheber Pitts s1s - 12/23/2012 9:27 PM
TFF
Score: 148
Status: offline
They flew S2s but http://www.michaelmccrystal.com/2011/01/13/holiday-inn-acrobatic-flight-team/
Hard to beat a Red Devil
Hide Signatures
       Post #: 296
RE: Andy Sheber Pitts s1s - 12/23/2012 9:39 PM
acerc
Score: 221
Status: offline
Well thats definately different TFF.
Robert
Hide Signatures
(in reply to TFF)
       Post #: 297
RE: Andy Sheber Pitts s1s - 12/23/2012 10:05 PM
WacoNut
Score: 175
Status: offline
Hey Robert that used to be my brand of choice. I think I paid enough to Marlboro over the years to buy 3 Pitts.
Bummer about the black, I know what you mean about a plane being hard to see. I had a black Sporster-Bipe and it was hard to orient due to the color.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to acerc)
       Post #: 298
RE: Andy Sheber Pitts s1s - 12/23/2012 10:49 PM
Hinckley Bill
Score: 100
Status: offline
Hey Robert,
Cub Flyer is right on the mark....go for that Ford scheme...
And if you need additional pics of it...here's the site where you can see more:
https://picasaweb.google.com/TCPRCphotos/TrevorBrumSGIANTScalePitts#
This scheme is impossible not to see to say the least
Bill
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 299
RE: Andy Sheber Pitts s1s - 12/23/2012 11:20 PM
acerc
Score: 221
Status: offline
Thank's Hinckley but I really want to build a Top Gun contender. Not that I would compete, just want to see how close I can get to what I see there every year.
Robert
Hide Signatures
(in reply to Hinckley Bill)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.828RCU1
