RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: Andy Sheber Pitts s1s - 1/2/2013 1:40 PM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
A triangular structure is the strongest there is, so i would defo add the cross brace Robert. It may not be needed, but there is no benifit to not fiting it.
The cabane's on my own are a completely different set-up. TC has used 3mm piano wire with the aerofoil section being fabricated from oval shaped balsa halfs with the recess cut out the middle to fit over the piano wire. The piano wire is fixed to the fusalage with what can only be described as threaded eyelets. If you were to take a piece of threaded rod about 1" long and hammer one end flat then drill a hole that the piano wire can pass through then drill a hole in the fusalage side and pass the threaded part through, and a washer and nut to pull the wire tight against the fusalage side to the piont that you cand move it by hand but tight enough that the wire wont fall under it's own weight. With that done, you can make very small, accurate adjustments for alignment before you tighten the nuts fully, then smear the whole lot with epoxy.
Hide Signatures
(in reply to john josey)
       Post #: 401
RE: Andy Sheber Pitts s1s - 1/2/2013 2:39 PM
acerc
Score: 221
Last Login: 5/22/2013
Status: offline
Man you guy's have a way of making one paranoid. So, I went looking for a solution for a little more reinforcement with minimum weight gain. Here is what I came up with. In the pic the red circles are where the struts exit the fuse. At that point there is a 3/16 x 1/2" hardwood rail. The hardwood rail will actually have to be contoured for the struts, the black marker in the yellow circles. I will make a small bracket to fasten the cabane to these hardwood rails. I think this will add the needed support at the center of the cabane's.
Click to see fullsize image.
Click for fullsize
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 402
RE: Andy Sheber Pitts s1s - 1/2/2013 3:15 PM
john josey
Score: 110
Status: offline
I think thats a good idea Robert, it'll give you peace of mind.
Hide Signatures
(in reply to acerc)
       Post #: 403
RE: Andy Sheber Pitts s1s - 1/2/2013 4:45 PM
RickBoyer
Score: 100
Status: offline
Hey Robert,
I used airfoil shaped Chrome Moly, jig aligned and tig welded together, on my Pitts cabane assembly since the drawing called for using welded steel brake line (flattened in a similar fashion to your brass method). I also used flat stainless sheet machined down to a square profile with a hole drilled in the middle, to accept a machine screw and locking nut which secured the assembly in four places to the bulkheads.
Be careful with brass since it is allot softer than CM or stainless.....
Just say'n,
Rick Boyer
Top Gun 2004-2012
Pitts Special S-1S (#1)
Ryan STA
Pitts Special S-1S (#2)
Hide Signatures
       Post #: 404
RE: Andy Sheber Pitts s1s - 1/2/2013 5:00 PM
acerc
Score: 221
Status: offline
Hi Rick! How are you doing? What are you bringing to TG this year. I appreciate your concern and you may very well be right. But not having the welding equipment or skill I have to find other avenues. The cabanes will be bolted to the bulkheads and the hardwood runner at the top of fuse. If it turns out not to be strong enough I'll get to do it again. Now if someone (hint, hint) was willing to jig one up and weld it, I would be most appreciative. And willing to pay. I don't, personally, know anyone that is capable of doing such.
Robert
Hide Signatures
(in reply to RickBoyer)
       Post #: 405
RE: Andy Sheber Pitts s1s - 1/2/2013 5:48 PM
acerc
Score: 221
Status: offline
Any volunteers?
Robert
Hide Signatures
(in reply to acerc)
       Post #: 406
RE: Andy Sheber Pitts s1s - 1/2/2013 8:58 PM
acerc
Score: 221
Status: offline
Not much done today, just not in the mood I guess. But I have managed to get the wing cabane mounts made.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 407
RE: Andy Sheber Pitts s1s - 1/2/2013 11:56 PM
WacoNut
Score: 175
Status: offline
Robert,
Hard to tell from your pics but can you run music wire thru your streamlined tubing and silver solder a lug at each end for attaching to the mounts? I would then JB Weld the brass over the music wire.
This would help strength wise, I would be a bit skiddish of the brass. I think you will be fine with pulling and compression forces it is any side load forces you will encounter that worries me with brass. As squirrely as a Pitts can be on the ground and also doing snaps and such you will see alot of side load.
Not trying to worry you just an opinion.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 408
RE: Andy Sheber Pitts s1s - 1/3/2013 1:15 AM
john josey
Score: 110
Status: offline
I think the flying wires might be functional on your pitts Robert.
Hide Signatures
(in reply to WacoNut)
       Post #: 409
RE: Andy Sheber Pitts s1s - 1/3/2013 1:47 AM
acerc
Score: 221
Status: offline
Ok! All this over my cabanes got me thinking. I don't know why but a thought popped in my head and thought I'd try it.
Look at the photo. Now keep in mind I only weigh 170lbs. All my left foot is doing is keeping balance. There will be two, front and rear.
Click for fullsize
Robert
Hide Signatures
       Post #: 410
RE: Andy Sheber Pitts s1s - 1/3/2013 2:03 AM
flyingagin
Score: 114
Status: offline
Good expearment. Go for it
Ken
"As for Me and My House, We Will Serve the Lord"
Club Saito Member 775
Hide Signatures
(in reply to acerc)
       Post #: 411
RE: Andy Sheber Pitts s1s - 1/3/2013 2:18 AM
john josey
Score: 110
Status: offline
LOL Exellent Robert !  That clinches it !
Hide Signatures
(in reply to flyingagin)
       Post #: 412
RE: Andy Sheber Pitts s1s - 1/3/2013 2:33 AM
acerc
Score: 221
Status: offline
John you refered to yours as a TC. Who is that?
Robert
Hide Signatures
       Post #: 413
RE: Andy Sheber Pitts s1s - 1/3/2013 2:35 AM
flyingagin
Score: 114
Status: offline
My asking about compressive load at the center back in post 395 may have cuased some doubt about the cabanes. I really did not mean to do that and I want to apologize to you personally acerc and any others on this thread that took it that way.
Ken
Hide Signatures
       Post #: 414
RE: Andy Sheber Pitts s1s - 1/3/2013 2:44 AM
acerc
Score: 221
Status: offline
No apology neccessary, Ken. It was a perfectly logical question. It's just my anal head could not let go with just my simple belief that it was good. I think that test show's it will be plenty strong.
Think of it like this, if it was weak you would have saved a plane.
Robert
Hide Signatures
       Post #: 415
RE: Andy Sheber Pitts s1s - 1/3/2013 3:08 AM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: acerc
Ahhh now I did not think of that. Good thought
Ken
Hide Signatures
(in reply to acerc)
       Post #: 416
RE: Andy Sheber Pitts s1s - 1/3/2013 3:15 AM
john josey
Score: 110
Status: offline
Robert, TC....Toni Clark in germany the manufacturer of my own pitts kit. I would think the outline on both will be identical, it's just the construction method thats different.
Hide Signatures
       Post #: 417
RE: Andy Sheber Pitts s1s - 1/3/2013 3:22 AM
acerc
Score: 221
Status: offline
DUH! I know that one. Thought about getting one. Even emailed him on total price shipped. But my love of the build overcame the idea of a kit. Although the kit would have been much cheaper.
Robert
Hide Signatures
       Post #: 418
RE: Andy Sheber Pitts s1s - 1/3/2013 1:44 PM
RickBoyer
Score: 100
Status: offline
Hi Robert,
I still have the machine shop quality aluminum jig that I made for the cabanes and I can fabricate the cabane for you but I would'nt be able to turn it around for you until mid February due to work and travel. If this helps let me know, although it looks like the brass cabane assembly that you have fabricated will do fine.
Let me know if I can help,
Rick Boyer
Top Gun 2004-2012
Ryan STA
Hide Signatures
(in reply to acerc)
       Post #: 419
RE: Andy Sheber Pitts s1s - 1/3/2013 3:27 PM
acerc
Score: 221
Status: offline
Thank's for the offer Rick. That is very kind of you. I think I'll be ok with the brass.
Robert
Hide Signatures
       Post #: 420
RE: Andy Sheber Pitts s1s - 1/3/2013 3:44 PM
VincentJ
Score: 145
Status: online
Just want to chime in here and bring up two points.  First, it never ceases to amaze me how willing others in this hobby are to help other modelers in need.  In a crazy "what can you do for me" world it's refreshing to see help and concern from others.  Second point, nice legs there Robert.. LOL
VJ
Hide Signatures
       Post #: 421
RE: Andy Sheber Pitts s1s - 1/3/2013 4:34 PM
acerc
Score: 221
Status: offline
My brother, you need glasses!!
Thanks for the laugh!
Robert
Hide Signatures
(in reply to VincentJ)
       Post #: 422
RE: Andy Sheber Pitts s1s - 1/3/2013 4:58 PM
acerc
Score: 221
Status: offline
I was getting set up to start sanding and realised I had not installed shear webs in the top wing. When they are dry sanding will commence.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 423
RE: Andy Sheber Pitts s1s - 1/3/2013 8:54 PM
acerc
Score: 221
Status: offline
I'm still sanding. Will probably be most of tomorrow finishing up the sanding.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 424
RE: Andy Sheber Pitts s1s - 1/3/2013 11:01 PM
acerc
Score: 221
Status: offline
I quit! For the day. Got a club meeting to get to.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
