RE: Andy Sheber Pitts s1s    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Andy Sheber Pitts s1s
Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: Andy Sheber Pitts s1s - 1/9/2013 12:11 PM
VincentJ
Score: 145
Last Login: 5/23/2013
Status: offline
Wow turned out super.   Thanks for the tips, the tape tip will definitely be helpful down the road.
_____________________________
VJ
Hide Signatures
(in reply to acerc)
       Post #: 501
RE: Andy Sheber Pitts s1s - 1/9/2013 6:11 PM
acerc
Score: 221
Status: offline
Glad to help when I can.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to VincentJ)
       Post #: 502
RE: Andy Sheber Pitts s1s - 1/9/2013 6:14 PM
acerc
Score: 221
Status: offline
The fuse has been sanded, the stabilizer and fin have been sanded as well  and installed. While that is drying I can get the rudder and elevator sanded.
Click to see fullsize image.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 503
RE: Andy Sheber Pitts s1s - 1/9/2013 8:07 PM
acerc
Score: 221
Status: offline
The elevator and rudder are sanded and in place. And I think I'm done for the day. I know this morning I said I wanted to get the strips in for the fuse panels but I don't have the 1/16th ply to cut them from.
  Later!
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 504
RE: Andy Sheber Pitts s1s - 1/10/2013 3:09 AM
acerc
Score: 221
Status: offline
Not much done today, some days are like that. I have to mow my clubs field tomorrow and will pick up the piece of 1/16 I mentioned earlier. On my plans there is a template for the cockpit opening. Is the template the size of the opening as if looking down from above or is it to be layed over the curvature of the wood and cut out?
Robert
Hide Signatures
(in reply to acerc)
       Post #: 505
RE: Andy Sheber Pitts s1s - 1/10/2013 3:17 AM
straitnickel
Score: 105
Status: offline
Measure the width of the template at the rear and see if it matchs the former at the rear of the cockpit.
I don''''t always crash, but when I do!
Hide Signatures
(in reply to acerc)
       Post #: 506
RE: Andy Sheber Pitts s1s - 1/10/2013 3:19 AM
straitnickel
Score: 105
Status: offline
If its wider than the former, will a curve make it fit?
Hide Signatures
(in reply to straitnickel)
       Post #: 507
RE: Andy Sheber Pitts s1s - 1/10/2013 3:20 AM
acerc
Score: 221
Status: offline
Yep! It does, thank's strait!
Robert
Hide Signatures
       Post #: 508
RE: Andy Sheber Pitts s1s - 1/10/2013 6:43 PM
acerc
Score: 221
Status: offline
I awakened around 3am this morning with a though of "Hey dumb dumb you can do this" in regard to the cockpit opening. So when I got home I measured the opening height on the side view and the width on the overhead view. Put the template in place, marked with chalk, measured, and cut. When this is dry I will epoxy a 1" strip of glass on the inside edge of the opening, just to give it a little strength.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 509
RE: Andy Sheber Pitts s1s - 1/10/2013 9:26 PM
acerc
Score: 221
Status: offline
I have installed the 1/16x3/8 ply for the fuse panels, the black lines. Did not take as many as I thought, most of in front of cockpit fell on the 1/4 ply formers.
Click for fullsize
Robert
Hide Signatures
(in reply to acerc)
       Post #: 510
RE: Andy Sheber Pitts s1s - 1/10/2013 11:05 PM
WacoNut
Score: 175
Status: offline
Hey Old Man that's looking pretty good
Won't be long and you will be putting the fabric on.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to acerc)
       Post #: 511
RE: Andy Sheber Pitts s1s - 1/10/2013 11:34 PM
john josey
Score: 110
Last Login: 5/19/2013
Status: offline
Robert, i dont quite understand - is there another panel that goes from the former where the front of your undercarrage sits to overlap the panel you have highlighted in black or is there only the one panel ?
Hide Signatures
(in reply to WacoNut)
       Post #: 512
RE: Andy Sheber Pitts s1s - 1/11/2013 12:10 AM
acerc
Score: 221
Status: offline
John there will be six panels. Two yellow and two green, one on each side. And one red and one blue, of which goes across the top of the fuse.
Click for fullsize
Robert
Hide Signatures
(in reply to john josey)
       Post #: 513
RE: Andy Sheber Pitts s1s - 1/11/2013 12:20 AM
WacoNut
Score: 175
Status: offline
Robert,
What are you going to make your panels from? I used 1/64 ply with good success on my 25% Waco. Steam it in a microwave for a couple minutes and it becomes very pliable. I added my panels after covering and gave then several coats of Polycrylic then primer and they were very convinceing for aluminum panels.
Later!!
Anthony
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 514
RE: Andy Sheber Pitts s1s - 1/11/2013 12:26 AM
acerc
Score: 221
Status: offline
Anthony, I'm going to attach 1/64 ply to some very thin aluminum and screw in place. I used the 1/64 on my 1/5 scale Waco and it did turn out well. Just want to try something different.
Click for fullsize
Robert
Hide Signatures
       Post #: 515
RE: Andy Sheber Pitts s1s - 1/11/2013 12:46 AM
WacoNut
Score: 175
Status: offline
Sounds good,
I usually try somehting new with each build.
Hide Signatures
(in reply to acerc)
       Post #: 516
RE: Andy Sheber Pitts s1s - 1/11/2013 12:53 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Yeah, that make's sense Robert. Cant wait to see the fullsize, dont think i'll get much sleep the night before !
Guy's, these aeroplanes are beautifull....what other delights have you got hiding away ?
Hide Signatures
(in reply to acerc)
       Post #: 517
RE: Andy Sheber Pitts s1s - 1/11/2013 1:06 AM
acerc
Score: 221
Status: offline
Thank's John! I need to finish the sanding on the top wing and get it mounted. I need the cabane's in place to cut the panels to fit arount them.
Robert
Hide Signatures
       Post #: 518
RE: Andy Sheber Pitts s1s - 1/11/2013 1:39 AM
WacoNut
Score: 175
Status: offline
John,
The Waco I posted a pic of is now in the WACO Museum in Troy Ohio on permenant display. I donated it last spring.
I have a 1/3 Waco going thru a rebuild now due to pilot error. Destroyed the fuselage
Sorry to hijack Robert!!
Anthony
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 519
RE: Andy Sheber Pitts s1s - 1/11/2013 2:15 AM
acerc
Score: 221
Status: offline
And here is the paper teplates for the 1/64 ply.
Click for fullsize
Robert
Hide Signatures
       Post #: 520
RE: Andy Sheber Pitts s1s - 1/11/2013 7:55 AM
vasek
Score: 147
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: WacoNut
Anthony
Hi WN, can you describe the process of steaming in the microwave ? sounds interesting! Thanks V.
Remember: Speed is life!
Hide Signatures
       Post #: 521
RE: Andy Sheber Pitts s1s - 1/11/2013 10:49 AM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: vasek
Hi vasek,
I cut the ply close to the size I need then put a eough water in a dinner plate to cover the bottom. Set the ply in the water and microwave for 1-1/2 to 2 minutes. This will essentially steam the plywood and make it very easy to bend. I put it on the plane and finish trim to size with scissors then secure it to the plane and let it dry. Once dried it will maintain it's shape. Works good for removeable panels as well.
Later!!
Anthony
Hide Signatures
(in reply to vasek)
       Post #: 522
RE: Andy Sheber Pitts s1s - 1/11/2013 3:16 PM
brianrfike
Score: 100
Last Login: 3/31/2013
Status: offline
Hey acerc,
Where can I get my hands on a set of these plans? I also saw a post earlier from Rick about a 1/4 scale version. Any help will be greatly appreciated!
Brian
Brian
Hide Signatures
       Post #: 523
RE: Andy Sheber Pitts s1s - 1/11/2013 3:32 PM
acerc
Score: 221
Status: offline
Hello Brian. Go back to one of those post by Rick and Pm him. He has the plans.
Robert
Hide Signatures
(in reply to brianrfike)
       Post #: 524
RE: Andy Sheber Pitts s1s - 1/11/2013 4:19 PM
acerc
Score: 221
Status: offline
Been workin on the wing bolt area. The current set up requires a 2-1/4" bolt. I installed a new ply bolt plate as seen in red. This will reduce the bolt length to 1". And also gives me a good point for an alignment dowel.
Click for fullsize
< Message edited by acerc -- 1/11/2013 4:41 PM >
Robert
Hide Signatures
(in reply to acerc)
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.500RCU1
